Please help. Problems after K&N installation - Cherokee SRT8 Forum
post #1 of 16 (permalink) Old 12-12-2012, 02:31 PM Thread Starter
Hello!
Today I have installed my K&N Aircleaner on my 2006 6.1 SRT8 but something must have gone terribly wrong.
The installation itself was not that hard, but for some reason when I wanted to do the first test, I encountered some problems:
- engine-signal-light on the dashboard is on
- engine will not go over 4000 RPM and keeps stuttering
- Even with a cold engine the cooling-fan is running at full speed.
What have I done wrong?
The only observation I have to make is about the air-intake-temperature sensor. It was very hard to take it out of the original air-tube, so I had to use some force. Might it be broken? No visible damage on the sensor, but maybe by twisting it out of its original place, perhaps it got damaged internally.
Anybody can give me any advice? Is there anything else that I could have overseen?
Thanks for you time.
SRT8-Brazil is offline
post #2 of 16 (permalink) Old 12-12-2012, 02:40 PM
hotrodcalvert's Avatar
If its throwing a service light, read it with a diablo or go to a local autoparts store and have them read it for you, once you know the code, it will be easier to diagnose
Colby
The "Silver Bullet" ---- 2006 Jeep SRT8 - Gone but definitely not forgotten
hotrodcalvert is offline
post #3 of 16 (permalink) Old 12-12-2012, 02:42 PM Thread Starter
Thanks for your reply, but I am living in the middle of nowhere in Brazil. Will be hard to find anybody with this equipment and the next Jeep-Dealer is pretty far away.
The Following User Says Thank You to SRT8-Brazil For This Useful Post:
hotrodcalvert (12-12-2012)
post #4 of 16 (permalink) Old 12-12-2012, 02:46 PM
Well if you dont have a local autoparts store that has an OBD-II scanner, then yes unfortunately, a trip to the dealership may be required, but they shouldnt charge you for just a code read..............the part about you not being able to go over 4K rpm, is that while driving or in park?
post #5 of 16 (permalink) Old 12-12-2012, 03:15 PM Thread Starter
It was in parking. I didn't have the courage yet to drive. Actually I cannot drive it right now because the car is undergoing some cosmetical work on the painting and any dirt I would pick on the road would do bad to this work. This will take 2 more days so If somebody could for example confirm that the sensor is the cause of the problems I could at least organize spareparts for the time being.
post #6 of 16 (permalink) Old 12-12-2012, 03:20 PM
bushmaster3000's Avatar
Start by asking yourself what did I change? Usually human error some where.
~~~~~ Special Thanks to~~~~
Skip at Demon Performance
Bada$$ Tuner Johan!
bushmaster3000 is offline
post #7 of 16 (permalink) Old 12-12-2012, 03:27 PM
AROD's Avatar
Your engine wont rev above 4k in park.
Did you touch the sesnor at all with bare hands ? - was it dirty at all ?
Try disconnecting your Neg. battery teminal, pump your brakes 4-5 times then reconnect and try to start. If you get another CEL you likely have a bad sensor.
was this a cold air intake, ram intake .. something else ?
also, did it come with an extension for the sensor ? - other members have had issues in the wires themselves. Just make sure its plugged all the way in the socket, has clean terminal, and clean sesnor tip ( electrical cleaner works wonders )
AROD is offline
The Following User Says Thank You to AROD For This Useful Post:
Tim H Calgary (12-12-2012)
post #8 of 16 (permalink) Old 12-12-2012, 04:32 PM Thread Starter
@ bushmaster: I went over this like three times and the only thing I came up with was the sensor.
@Arod: I will try this tomorrow. I think that I have touched the sensor with the bare hands because when It didn't want to get out, I was reaching with my hand into the tube to find out how it might be stuck.
What I have installed is a cold air intake. No rewiring. All "plug and play".
I have already doublechecked the conectors but I will have a closer look at the censor-tip. It looks just a little bit "dusty".
If I don't have electric cleaner here, is alcohol alowed?
post #9 of 16 (permalink) Old 12-12-2012, 04:49 PM
AROD's Avatar
The code may also be due to the fact that your ECU hasn’t yet "learned" that you have a new intake system. If you give it time it will self learn ( to a point ) and hopefully eliminate the code on its own - this usually requires driving around for a day or so.
keep in mind, its best to get a tune whether its custom, or a canned OTS ( off the shelf ) tune that comes with a handheld device such as a predator, trinity etc.
If you plan on keeping the jeep i would suggest picking up a used pred. there are LOTS for sale on here. you can load a CAI tune as well as pull any trouble codes down the road. Its a decent investment for piece of mind. After all, a CEL could be as little as a loose gas cap
EDIT:
*** The reason a tune is a good idea is because when you add a more efficient intake you cause more air flow. Meaning you also need more fuel to compensate** The computer may adjust on its own, but it's hard to be certain.
AROD is offline
post #10 of 16 (permalink) Old 12-12-2012, 05:02 PM
Yeah like Arod said, a handheld tuner is your best friend. The whole thing about not being able to rev over 4K while sitting still and in park is prolly your factory rev limiter kicking in, so I wouldnt worry about that, you can try unhooking your battery for a few min and hooking it back up to see if that will clear your light, but prolly like he said, unless the sensor was damaged, your truck isnt used to the new abundance of air coming into the intake and hasnt learned how to compensate for it yet.
Problems after Bored Throttle Body Installation meeper WK1 Intake/ Exhaust Discussion 15 04-02-2012 05:53 PM
aFe CAI installation T-BoneHemi WK1 Intake/ Exhaust Discussion 9 07-15-2009 11:48 PM
I need some Amp installation help. Grip Grip WK1 Audio/Video/Nav/UConnect/Electronics 11 11-30-2008 05:38 PM
PCM installation.. How to.. maansy WK1 SRT8 General Discussion 1 10-25-2008 04:58 AM
