Feels like Engine is Cutting Cylinder(s) - Cherokee SRT8 Forum
post #1 of 32 (permalink) Old 12-09-2012, 03:44 PM Thread Starter
bushmaster3000's Avatar
Under mild to high acceleration it feels like the car drops a cylinder(s). If I'm going 70 MPG and stomp it the car downshifts rev's up to like 5K then feels like it drops a cylinder then continues on to its highest RPM, at this point it runs good. Taking off from a dead stop under WOT it gets up to about 4-5 grand and pulls hard but at this RPM it once again starts sputtering and then acts up. Slams to second gear, gets up in RPM and same thing. Feels like its cutting cylinders. At idle sometimes the car feels like it drops a cylinder and my A/F goes way lean. I'm guessing unburnt fuel?
Here's what I've tried:
-Replaced two coils on cylinders that said misfires.
-Pulled all the plugs and made sure they were gapped correctly
-Fuel pressure good
-Ran logs and sent to Johan, said things were good on his side.
-Going to get a cord for my Trinity to plug into my a/f gauge.
So anyone have advice?
-Maybe Camshaft Positioning Sensor?
Thanks in advanced.
~~~~~ Special Thanks to~~~~
Skip at Demon Performance
Bada$$ Tuner Johan!
bushmaster3000 is offline
post #2 of 32 (permalink) Old 12-09-2012, 03:52 PM
BJB
"guy with the crazy Jeep"
BJB's Avatar
How do you know the fuel pressure is good?
Brian
BJB is offline
post #3 of 32 (permalink) Old 12-09-2012, 03:52 PM
nyjoed's Avatar
belt slipping? not sure that would cause a misfire tho?
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #4 of 32 (permalink) Old 12-09-2012, 03:52 PM
nyjoed's Avatar
wouldnt it shopw in his fuel pids to johan? or lean a/f?
nyjoed is offline
post #5 of 32 (permalink) Old 12-09-2012, 03:54 PM
Knuckles's Avatar
What are your pluggs gapped at and how much boost you running?
Knuckles
Knuckles is offline
post #6 of 32 (permalink) Old 12-09-2012, 04:09 PM
WIPLASH's Avatar
Tune related?
I'm gettting frustrated
with modding
WIPLASH is offline
post #7 of 32 (permalink) Old 12-09-2012, 04:17 PM
DemonPerformance's Avatar
He's running a full return style system with twin 405s etc...believe his base is set right at 60~ and is boost ref'd as well
Can't see it being belt related at his boost level really, only about 9 psi or so
Think he's got them down to .032 at about 9psi ish
Originally Posted by yungsrt View Post
Tune related?
Everything looks good on the tune side...
Skip Demon Performance
1-888-312-3666
DemonPerformance is offline
The Following User Says Thank You to DemonPerformance For This Useful Post:
Knuckles (12-09-2012)
post #8 of 32 (permalink) Old 12-09-2012, 04:17 PM Thread Starter
I have a fuel pressure light in the cabin and mechanical regulator.
post #9 of 32 (permalink) Old 12-09-2012, 04:33 PM
BJB
BJB's Avatar
I have a light inside the cabin too that shows that the boost reference is working and turning the full pump to "race mode" but without a fuel pressure gauge you cant be certain. I had a problem last summer were the fuel tank (custom tank) had a blocked vent and causing a vapor lock. Fuel pressure gauge was one of the ways I found it... And the other way was Jersey told be to let it rip with the gas cap removed!
You really cant depend on any bells or lights. A fuel pressure gauge will tell you a lot. Things happen so fast without it your just guessing. With that being said I still havent been able to log fuel pressure with the trinity.
BJB is offline
The Following User Says Thank You to BJB For This Useful Post:
post #10 of 32 (permalink) Old 12-09-2012, 04:42 PM
Knuckles's Avatar
When was the last time the jeep was running fine and since then have you done any work to the Jeep?
Knuckles is offline
Engine cutting out Cylinder 8 misfire jdoc7 WK1 Troubleshooting / Problems Discussion / Dealer Service 39 10-28-2016 09:26 AM
Has anyone noticed engine cutting out? Delta Victor WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 77 03-31-2016 01:01 AM
Engine cutting out, HELP Jred22 WK1 Troubleshooting / Problems Discussion / Dealer Service 41 12-31-2009 10:10 AM
4*4 cutting top rpm WK1 Troubleshooting / Problems Discussion / Dealer Service 6 11-23-2009 06:22 AM
cutting cookies in snow=check engine light mandan007 WK1 Troubleshooting / Problems Discussion / Dealer Service 6 12-27-2008 07:29 AM
