Ticking noise in engine - Cherokee SRT8 Forum
post #1 of 43 (permalink) Old 12-09-2012, 06:41 AM Thread Starter
Dam2far's Avatar
Hey fellow members, I have been hearing a ticking noise in the engine area when the vehicle is running. Whenever I bring the RPMs up it speeds up as well. Is this the lifters? What is the easiest way for me to fix this myself?
'07 GC SRT8
AFE CAI/Dark Tint LED Upgrade Taillight Solutions Package
Jet 180 TSTAT/Tuned by JOHAN/Moroso Catch Can/DCSpecial Halo Headlights/CORSA Exhust
Dam2far is offline
post #2 of 43 (permalink) Old 12-09-2012, 11:47 AM
DrSheldonCooper's Avatar
do you think it's coming from the top end of the motor or the bottom end? middle?
Dan
2010 YEEP
DrSheldonCooper is offline
post #3 of 43 (permalink) Old 12-09-2012, 12:44 PM Thread Starter
Dam2far's Avatar
It is coming from the top. It sounds like it is coming from the front left side in the manifold.
Dam2far is offline
post #4 of 43 (permalink) Old 12-09-2012, 12:47 PM
Tim H Calgary's Avatar
Lifter noise? Check your oil?.
Tim H Calgary is offline
post #5 of 43 (permalink) Old 12-09-2012, 12:52 PM Thread Starter
Dam2far's Avatar
Oil is good. Just got it done 2 weeks ago, and that was the first thing I did. I think it is a lifter noise.
I did a short video of the noise. Hope it helps.
Thanks for your help.
Dam2far is offline
post #6 of 43 (permalink) Old 12-09-2012, 12:57 PM
Did you check the oil though? Just cause you got it done 2wks ago doesn't mean anything unless you go check it yourself. Some places, even dealers, have to been known to only put 5qts in instead of the required 7qts.
J&D's SRT's is offline
post #7 of 43 (permalink) Old 12-09-2012, 12:58 PM
jumpback's Avatar
Wow that is a big tick, get it to a shop asap?
~Jeep SRT8~
jumpback is offline
post #8 of 43 (permalink) Old 12-09-2012, 01:00 PM Thread Starter
Dam2far's Avatar
Oil level is good and it is clean too.
Dam2far is offline
post #9 of 43 (permalink) Old 12-09-2012, 01:29 PM
Sound quality on my phone could be better, but is there any way it's an exhaust leak or definitely mechanical?
Jack_Toepfer is offline
post #10 of 43 (permalink) Old 12-09-2012, 01:34 PM
that sounds pretty bad
sounds like a valve train issue to me. take the valve covers off, pull out the fuel pump relay and have someone turn the motor over and see if you can pin point exactly where it's coming from. that's what i'd do.
The Following User Says Thank You to DrSheldonCooper For This Useful Post:
Dam2far (12-09-2012)
ticking/knocking noise. bad lifter? nycxed WK1 Troubleshooting / Problems Discussion / Dealer Service 19 07-09-2012 01:21 PM
Front left ticking noise snowpro WK1 Troubleshooting / Problems Discussion / Dealer Service 3 01-14-2012 04:04 PM
What is that ticking sound from the engine. jeepmystery WK1 Troubleshooting / Problems Discussion / Dealer Service 15 02-27-2010 12:48 PM
Engine Tapping or Ticking Noise PorscheSRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 7 03-04-2008 06:35 PM
Engine Ticking cneigel WK1 Troubleshooting / Problems Discussion / Dealer Service 12 10-10-2007 01:37 PM
