Ticking noise in engine - Page 3 - Cherokee SRT8 Forum
post #21 of 43 (permalink) Old 12-10-2012, 01:03 AM
Check your plugs sometimes they can be loose and cause a nosie like that
steelbluejeep is offline
post #22 of 43 (permalink) Old 12-10-2012, 05:45 AM
viking757's Avatar
Originally Posted by Btelander View Post
Make sure you dont have an exhaust leak.
x2 when the engine is cool check the torque on the exhaust manifold bolts. On my old 5.7 I had one that loosened up a bit and made a similar ticking noise. Re torqued them all and it was gone.
viking757 is offline
post #23 of 43 (permalink) Old 12-10-2012, 06:39 AM
JEEP IN 2014's Avatar
I just went through this two weeks ago and it was the header gasket that went bad. I was sold that it was a top end/lifter issue, but paid to have the header gasket replaced and that got rid of the noise. Just another victim of aftermarket gaskets for longtube headers going bad. In the end it was $21 in parts and 7 hours in labor to have the gasket replaced.
2006 Jeep GCSRT-8
Mods:Mopar CAI-SW Long Tube Headers-Corsa/Mopar Exhaust-Diablo Predator-Custom Tune-FRI Little Boy +4 Camshaft-QTP cutouts
JEEP IN 2014 is offline
post #24 of 43 (permalink) Old 12-10-2012, 08:06 AM
Blown-WK's Avatar
Definitely sounds like a bad lifter. One of mine made the same noise.
-CHRIS-
10.61 @ 129
Blown-WK is offline
post #25 of 43 (permalink) Old 12-11-2012, 06:12 PM Thread Starter
Dam2far's Avatar
Gave up and brought it to the shop. I'll find out what is wrong with it soon.
Plus, I found that my fan blade is rubbing.
What will go wrong next?
Thanks for your inputs and help. I tried most of the recommended methods with no success.
Cheers!
Jude
'07 GC SRT8
AFE CAI/Dark Tint LED Upgrade Taillight Solutions Package
Jet 180 TSTAT/Tuned by JOHAN/Moroso Catch Can/DCSpecial Halo Headlights/CORSA Exhust
Dam2far is offline
post #26 of 43 (permalink) Old 02-09-2013, 11:08 PM
Mine just started doing the same thing as yours. I thought it was the driver's side exhaust manifold gasket so I replaced it. No luck. Did you ever find what was wrong with yours?
Juan
malo is offline
post #27 of 43 (permalink) Old 02-10-2013, 07:13 AM Thread Starter
Dam2far's Avatar
I have stored it until I can save the dough to fix it. When we are not sure exactly what it is, we don't know how expensive it could be. I will be brining it to the shop within the next couple of weeks.
Sent from AutoGuide.com App
Dam2far is offline
post #28 of 43 (permalink) Old 02-10-2013, 11:35 AM
Most Likely a lifter is gone bad they are not that much to buy like
300 bucks for lifters whole set and new pushrods there like 2bucks each
And your gonna need 2 head gaskets like 400 in parts and while your there
You might as well do the cam that up to you
post #29 of 43 (permalink) Old 07-18-2013, 06:28 AM Thread Starter
Dam2far's Avatar
I have purchased the lifters and while we are at it, I gave also got a PWR cam with mean street cylinder heads and all the appropriate needed for the install. The install will be I two weeks. Good thing because I just got the code that my #4 cylinder is misfiring.
Thanks for all your help guys.
I'll let you know how "Christine" sounds when she is all fixed up.
Dam2far is offline
The Following User Says Thank You to Dam2far For This Useful Post:
Tim H Calgary (08-01-2013)
post #30 of 43 (permalink) Old 08-01-2013, 09:34 PM
Hope all goes well and everything gets fixed. I went the other route and fixed mine permanently by trading it in on a '12 Charger SRT8.
malo is offline
ticking/knocking noise. bad lifter? nycxed WK1 Troubleshooting / Problems Discussion / Dealer Service 19 07-09-2012 02:21 PM
Front left ticking noise snowpro WK1 Troubleshooting / Problems Discussion / Dealer Service 3 01-14-2012 05:04 PM
What is that ticking sound from the engine. jeepmystery WK1 Troubleshooting / Problems Discussion / Dealer Service 15 02-27-2010 01:48 PM
Engine Tapping or Ticking Noise PorscheSRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 7 03-04-2008 07:35 PM
Engine Ticking cneigel WK1 Troubleshooting / Problems Discussion / Dealer Service 12 10-10-2007 02:37 PM
