Rear end Frame Knocking - Cherokee SRT8 Forum
post #1 of 12 (permalink) Old 12-01-2012, 10:30 AM Thread Starter
jricher82's Avatar
I recently put the SRT on jack stands to remove the wheels and tires so I could plastidip them. I placed the stands where anyone else would, like I've done hundreds of times before.
After replaced all the wheels and taking the truck for a drive, I've noticed an audible knock coming from the rear from time to time when I hit a good enough bump or a dip in the road.
I've gotten underneath and can see something's making contact with the frame right near the brake hose bracket mount above the rear tires. Most of the time it comes from the passenger side but I've heard it from the driver side too.
One morning when it got cold and my tire pressure was low, it knocked more frequently. As the pressure rose in the tires when they get warm, it's not a frequent. (just out of curiosity, what PSI are you guys running your tires at, mine are usually between 3-35 PSI)
I've never had this problem before and it baffles me how lifting the truck temporarily would cause this problem. Anyone else experience anything like this? Any suggestions? Thanks
JP - "If you're not first, you're last."
2008 Jeep Grand Cherokee SRT8 - Magnaflow Exhaust / BT Oil Catch Can / Coil Over suspension / SRT Grill Badge / Pilot Stubby Antenna / Taillight Solutions Wire Harness
jricher82 is offline
post #2 of 12 (permalink) Old 12-01-2012, 06:28 PM
make sure lugs are tightened. something easy to check. tq to 100 ft lbs.
tonyl27 is offline
post #3 of 12 (permalink) Old 12-01-2012, 06:34 PM Thread Starter
jricher82's Avatar
Trust me, they're all tightened and torqued down to specs. That's not the Issue. Thanks tho, appreciate it
post #4 of 12 (permalink) Old 12-01-2012, 08:28 PM
can you narrow it down by the speed your going relative to when you hear the sound?
tonyl27 is offline
post #5 of 12 (permalink) Old 12-01-2012, 08:34 PM
btw, I had a knocking sound from the front right before. i thought the worst of it, bearing or bent wheel. I started with checking the lugs, it was a tad loose but this isn't the case for you.
With that said, carefully examine from the inside of your wheel to see if any slight bends. Maybe take a picture of where you think contact is being made?
tonyl27 is offline
post #6 of 12 (permalink) Old 12-01-2012, 09:06 PM
nyjoed's Avatar
After market exhaust hitting the top of the rear diff housing??
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #7 of 12 (permalink) Old 12-02-2012, 07:10 AM
LASRT's Avatar
I would say maybe exhaust but a picture sure would help.
LASRT is offline
post #8 of 12 (permalink) Old 12-02-2012, 08:45 AM
D VADER
D VADER's Avatar
The fact that it started just after jacking up the Jeep would eliminate the exhaust unless he some how put pressure on the pipes when jacking?
Commander Vader's Star Ship. Black on black of course.
Volant dual intake CAI, BT Catch Can, Jet 180 Thermostat. BWoody end links and Predator. 5" tips, RaceMesh rear louvers, R1 Rotors, Hawk ceramics. TruFiber Charger Hood, Mopar rear spoiler. Painted satin window trim. Nitto Motivo.
Hybrid- Burns gasoline & Rubber
D VADER is offline
post #9 of 12 (permalink) Old 12-02-2012, 12:30 PM
I shoot for about 36-37 PSI at the ambient temperature.
So if it is 60F in garage and 30 outside, I set the pressure at about 38-39 PSI.
2015 Challenger Hellcat incoming - delivered to dealer 10/8, 395 days after order
2010 GC SRT8
2009 Challenger SRT8
waumo is offline
post #10 of 12 (permalink) Old 12-02-2012, 02:08 PM Thread Starter
jricher82's Avatar
Think ill add a few lbs to the tires and see what that does. Never touched the exhaust.
REAR Axle/End not centered on frame... any resolutions?? silverbullet WK1 SRT8 General Discussion 16 06-22-2015 12:58 PM
knocking sound la77amx WK1 Troubleshooting / Problems Discussion / Dealer Service 0 07-22-2011 11:03 PM
rear sub frame broken on 2006 300C SRT8 cbutler32 WK1 Troubleshooting / Problems Discussion / Dealer Service 3 01-20-2010 11:55 PM
Pic request- stock exhaust mount at rear frame rail scottina06 WK1 SRT8 General Discussion 0 01-31-2008 11:23 AM
Knocking? JDR07 WK1 SRT8 General Discussion 3 01-24-2007 08:44 PM
