Starter location - Cherokee SRT8 Forum
post #1 of 18 (permalink) Old 11-30-2012, 10:59 PM Thread Starter
PR Danny's Avatar
Send a message via AIM to PR Danny
Starter location
Trying to find out a quick question where is the starter located on the jeep ?
PR Danny is offline
post #2 of 18 (permalink) Old 12-01-2012, 02:32 AM
chance575's Avatar
Drivers side, next to a large hunk of metal called the engine
10 GC SRT8, Maggie
chance575 is offline
post #3 of 18 (permalink) Old 12-01-2012, 04:04 AM
That guy..
Rocky31186's Avatar
It's burried up above the front driveshaft, behind a heat shield. It's a pain to get to.
06 GCSRT8
BT Catch Can, K&N Intake - Johan Tooned - Toyo Proxes4 - Eibach Lowering Springs - 6000k HID's - Magnaflow Exhaust - R1 Concepts - FRI Lil Boy 0* - Vortech V3
Rocky31186 is offline
The Following User Says Thank You to Rocky31186 For This Useful Post:
PR Danny (12-01-2012)
post #4 of 18 (permalink) Old 12-01-2012, 10:47 AM
kmitch80's Avatar
which sucks ass because mine is on its last leg. and they're not cheap. $180 I'm layin under the jeep now trying to figure out how to attack this thing. front driveshaft removal looks like a must.
Sent from my DROID BIONIC using AutoGuide.Com Free App
PWR 426
kmitch80 is offline
The Following User Says Thank You to kmitch80 For This Useful Post:
post #5 of 18 (permalink) Old 12-01-2012, 11:36 AM
kmitch80's Avatar
got it out. took about an hour. its a pain to get to but a little patience goes a long way with this.
kmitch80 is offline
post #6 of 18 (permalink) Old 12-01-2012, 01:37 PM Thread Starter
PR Danny's Avatar
thanks for the help guys
PR Danny is offline
post #7 of 18 (permalink) Old 02-13-2013, 06:07 PM
jricher82's Avatar
So I'm trying to get my starter out, removed all 12 bolts around the flanges on the front driveshaft. Was able to tap on it and get the front flange to separate but can't get the rear flange to separate from the transfer case so I can pull the drive shaft out. Did you have this issue? Once I can get that damn thing out I can finally rebuild my starter and get the beast back on the road again.
Any and all help is more than welcome! Thanks guys!
JP - "If you're not first, you're last."
2008 Jeep Grand Cherokee SRT8 - Magnaflow Exhaust / BT Oil Catch Can / Coil Over suspension / SRT Grill Badge / Pilot Stubby Antenna / Taillight Solutions Wire Harness
jricher82 is offline
post #8 of 18 (permalink) Old 02-14-2013, 07:20 AM
cmn1's Avatar
The front drive shaft should compress. There is no need to remove the rear driveshaft.
cmn1 is offline
post #9 of 18 (permalink) Old 02-14-2013, 07:24 AM
jricher82's Avatar
Starter location
I'm not removing the rear driveshaft. The rear "part" or flange of the front driveshaft won't separate from the transfer case. I didn't touch the rear driveshaft, I know it doesn't have to come out.
post #10 of 18 (permalink) Old 02-14-2013, 07:25 AM
ekaz's Avatar
Like he said, the front drive shaft should compress enough to get it out.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
Starter again..... Tcnj80 WK1 Troubleshooting / Problems Discussion / Dealer Service 6 02-24-2012 02:11 AM
Remote Starter Grizz WK1 SRT8 General Discussion 1 11-20-2010 09:04 AM
Starter went wicked_police WK1 Troubleshooting / Problems Discussion / Dealer Service 10 10-01-2010 07:04 PM
Location..Location..Location (Moved) Limey In FLA Off-Topic Discussion 4 07-23-2009 12:08 AM
Remote Starter SassySRT8 Midwest / Great Lakes 5 03-03-2008 09:16 PM
