vacuum gauge test - Page 4 - Cherokee SRT8 Forum
post #31 of 40 (permalink) Old 12-01-2012, 05:26 PM Thread Starter
nyjoed's Avatar
hahaha ill be the first to admit im ocd when it comes to how she runs.lol. i can imagine illk be putting myself thru changes when i get boosted.. ahhhhhh lol.
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #32 of 40 (permalink) Old 12-01-2012, 07:46 PM
Tim H Calgary's Avatar
Right there with yah man. If I hear anything it drives me nuts lol. "what is that!?!?" hah.
Tim H Calgary is offline
post #33 of 40 (permalink) Old 12-01-2012, 07:56 PM Thread Starter
nyjoed's Avatar
Hahaha isn't it the worse?!! Lol
nyjoed is offline
post #34 of 40 (permalink) Old 12-02-2012, 05:44 AM
Joe,
Inaccurate checks for bearing wear
A decrease in oil pressure
Engine noise
Fairly accurate check
Engine oil analysis (Blackstone is a very reputable with a quick response time)
http://www.blackstone-labs.com/
I believe we use the particle analysis at work it's about $25, contact them to
verify that's the test that will indicate bearing wear
Most accurate (most expensive)
remove connecting rod and main bearing caps inspect for visual wear and measure
the width of the bearing (a bearing may not have visual wear but can experience
hammering under detonation which makes the bearing wider)
I'd use the oil analysis, at work we use it on $$$$$$ engines.
Hope this helps,
Guy
SRT8-DOUGLAS SR is offline
post #35 of 40 (permalink) Old 12-02-2012, 08:03 AM Thread Starter
nyjoed's Avatar
Thank u guy! It does help. I appreciate it
nyjoed is offline
post #36 of 40 (permalink) Old 12-02-2012, 10:39 AM
If you haven't figured it out by now the vacuum your motor makes isn't rpm dependent, it is load on the motor. Other than idle rpm, which is usually as low as you cam guys can go, the gauge will fluctuate with throttle position and overall engine load.
When you floor it you'll see a drop in vacuum, but you'll realize that rpm climbs the whole time you're wot and that the vac gauge doesn't care if it is 3500 rpm or 5500.
Throw the blower on it and then you'll only be worried about the PSI half of the gauge!
Jack_Toepfer is offline
Tim H Calgary (12-02-2012)
post #37 of 40 (permalink) Old 12-02-2012, 11:38 AM
That's interesting Jack. I noticed on mine at idle if I rev it the vac will go to almost 20" from 14 but my cam is pretty mild. Thanks for the info. I didn't realize its from the throttle blade closing when you release the pedal. Starting to understand some of this stuff thanks to the fine folks of this forum
post #38 of 40 (permalink) Old 12-02-2012, 01:22 PM Thread Starter
nyjoed's Avatar
Mine sits pretty much at 15 at idle with slight slight movement cause of lope and web I slap open it she dropped to 0 then shot to about 22 or 23 then back down to 15. That's fine correct??
nyjoed is offline
post #39 of 40 (permalink) Old 12-02-2012, 01:39 PM
In park if you slowly increase the throttle your vacuum will increase as it should (from the research I've been doing). I think you and I are a bit a like Joe lol. I am always making sure she's running right. To me if you get higher vacuum in park and reving and not under load everything is sealing as it should. I would be far more concerned with low vacuum (not under load). When I get on her at WOT I see a hair over 8 psi on my boost gauge which leads me to believe I am not leaking anywhere. As you are aware not an expert and the stuff I quoted was from the internet lol.
I'd make another video but I have a partially torn belt at the moment.
post #40 of 40 (permalink) Old 12-02-2012, 01:42 PM
15" vacuum is normal, the flutter probably comes from cam overlap (the portion of the cam lobes that has the intake and exhaust valves open at the same time). I don't know how much overlap your cam has.
Guess I should have included this earlier....
Guy
The Following User Says Thank You to SRT8-DOUGLAS SR For This Useful Post:
nyjoed (12-21-2012)
Vortech Vacuum setup Rocky31186 WK1 Engine Performance/Superchargers/Turbos/Nitrous 17 06-29-2013 01:10 PM
Supercharged SRT8s...Where did you tie in your boost gauge? Which vacuum/boost line jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 27 06-22-2013 10:05 AM
Post Vortech Install - Lean and low Vacuum 09blksrt8 WK1 Engine Performance/Superchargers/Turbos/Nitrous 18 07-02-2012 05:29 PM
