vacuum gauge test - Page 2 - Cherokee SRT8 Forum
post #11 of 40 (permalink) Old 11-30-2012, 07:23 PM
DrSheldonCooper's Avatar
Originally Posted by nyjoed View Post
wouldnt crank and bearin wear give you a lower reading?
not really.
the only way something can escape the combustion chamber is through the intake/exhaust valves (if they're bent/not seating properly), any of the piston rings, or if you have a blown head gasket.
DrSheldonCooper is offline
post #12 of 40 (permalink) Old 11-30-2012, 07:24 PM
also, a normal gasoline engine at idle should be somewhere between 17-22 inches of vacuum, if memory serves me correctly.
post #13 of 40 (permalink) Old 11-30-2012, 07:27 PM
Tim H Calgary's Avatar
With my cam/supercharger I am at 14 and change with no movement once it warms up to operating temp. I lied to you good sir!
Tim H Calgary is offline
post #14 of 40 (permalink) Old 11-30-2012, 07:28 PM Thread Starter
nyjoed's Avatar
Originally Posted by DrSheldonCooper View Post
not really.
Thus you would figure this out by the way the needle moves then correct?
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #15 of 40 (permalink) Old 11-30-2012, 07:30 PM Thread Starter
nyjoed's Avatar
What cam ya running?? Can u shoot a video of the gauge? I think I made a good investment as mine is shaking back and forth fast but in a very short span. I would say it move back and forth real fast between 15-15 and a half at most. Heeeeeelp!!! What issue does this give me?
nyjoed is offline
post #16 of 40 (permalink) Old 11-30-2012, 07:34 PM
well, if you have a bent valve, chances are you'll have a misfire and a MIL on. you can do a compression test to determine a bad valve. if you have a bad head gasket, your engine will over heat and you can check your coolant to see if it's being mixed with engine oil.
post #17 of 40 (permalink) Old 11-30-2012, 08:00 PM
I shot a quick video for you joe PM me your e-mail and I'll fire it to you.
post #18 of 40 (permalink) Old 11-30-2012, 08:06 PM Thread Starter
nyjoed's Avatar
joed1080@yahoo.com thank u sir.
nyjoed is offline
post #19 of 40 (permalink) Old 11-30-2012, 08:07 PM Thread Starter
nyjoed's Avatar
Can the shake be from overlap in the cam also tho??
nyjoed is offline
post #20 of 40 (permalink) Old 11-30-2012, 08:08 PM Thread Starter
nyjoed's Avatar
Tim are u running a cam in ur jeep?
nyjoed is offline
Vortech Vacuum setup Rocky31186 WK1 Engine Performance/Superchargers/Turbos/Nitrous 17 06-29-2013 01:10 PM
Supercharged SRT8s...Where did you tie in your boost gauge? Which vacuum/boost line jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 27 06-22-2013 10:05 AM
Post Vortech Install - Lean and low Vacuum 09blksrt8 WK1 Engine Performance/Superchargers/Turbos/Nitrous 18 07-02-2012 05:29 PM
