coolant leak, can't find it, please help - Cherokee SRT8 Forum
post #1 of 13 (permalink) Old 11-27-2012, 09:49 AM Thread Starter
wakeSRT8setter's Avatar
We have a 2008 SRT8 Jeep and recently the upper radiator hose blew but we got that all replaced, pressure tested and everything. Sunday we went for a long drive (3 hours each way), popped the hood when we got back, and the coolant tank is completely dry. The car never got really hot or anything.
Fast forward, yesterday we drove to my buddies shop, topped off the tank, drove it home and let it sit overnight.
This morning, no signs of leaks under the car but the tank is down quite a bit.
Any ideas on this?
2008 Jeep SRT8
2008 Malibu Wakesetter
2002 Dodge Viper GTS ACR
2012 Arctic Cat Wildcat SXS
2012 Nissan Murano - company car
wakeSRT8setter is offline
post #2 of 13 (permalink) Old 11-27-2012, 09:54 AM
ekaz's Avatar
When you replaced the radiator hose, did you burp the system to get the air out?
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #3 of 13 (permalink) Old 11-27-2012, 09:55 AM
bcm0018's Avatar
Could it have been air pockets in the radiator? Something you can do is they sell dye that glows under UV light that is used to find leaks.
09 SRT8GC HHP built stroker 604/555 - 10.753 PB
bcm0018 is online now
post #4 of 13 (permalink) Old 11-27-2012, 10:20 AM Thread Starter
buddies shop did the hose so I am just looking for any/all possibilities so we can narrow down the problem. Keep them coming, thanks in advance!
post #5 of 13 (permalink) Old 11-27-2012, 10:27 AM
Tim H Calgary's Avatar
You can bet on air in the system imo.
Tim H Calgary is offline
post #6 of 13 (permalink) Old 11-27-2012, 11:51 AM Thread Starter
enough air to go through the whole tank on the passenger side? Where is the best place to blurp the system, maybe it was done at the wrong point?
any other ideas?
post #7 of 13 (permalink) Old 11-27-2012, 12:15 PM
Have you checked your oil? eliminate anything internal.
post #8 of 13 (permalink) Old 11-27-2012, 12:39 PM
bcm0018's Avatar
any other ideas?
My air bubble was large enough for my motor to start overheating
post #9 of 13 (permalink) Old 11-27-2012, 12:44 PM
nyjoed's Avatar
Always refill at the radiator cap first then let her go thru a heat cycle or 2 then burp her a couple times and u should be ok.
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #10 of 13 (permalink) Old 11-27-2012, 01:34 PM
Definitely sounds like air. Bursting a hose causes significant coolant leak, it isn't controlled like replacing it alone. Top it off again and check it in a couple days.
Jack_Toepfer is offline
Coolant Leak? limeylee WK1 Troubleshooting / Problems Discussion / Dealer Service 23 01-27-2017 03:09 PM
Coolant leak QUICKSRT10/SRT8 WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 12 04-04-2012 10:04 PM
Coolant leak at 9,000 miles SRT8Lady WK1 Troubleshooting / Problems Discussion / Dealer Service 8 06-02-2011 01:48 PM
Coolant leak bkoval04 WK1 Troubleshooting / Problems Discussion / Dealer Service 2 05-25-2010 08:06 PM
Coolant Leak BahnBlastR WK1 SRT8 General Discussion 2 09-01-2006 03:49 PM
