Service AWD light is on!! Please help - Cherokee SRT8 Forum
post #1 of 11 (permalink) Old 11-19-2012, 02:04 PM Thread Starter
My service awd light is on. I replaced stock tranny with level ten built tranny and got the tcm reprogrammed and it drove fine with no light on. Well took to fastlane performance to tune and dyno. When I picked the jeep up light was back on and told the tuner and he said might have to reprogrammed again so I did. Drove around for about an hr after leaving the dealer got a bit to eat and turned it back on and the light is back on.. I've talked to the tuner and shop they have no idea said they didn't mess with the tranny. However they did remove my front drive shaft to dyno an unplugged the transfer case but I checked connection and unhooked the battery to try and reset but no luck..
Any insight on this would be greatly appreciated
jeepman420 is offline
post #2 of 11 (permalink) Old 11-19-2012, 02:56 PM
BJB
"guy with the crazy Jeep"
BJB's Avatar
Who reprogrammed the TCM and with what?? What is a level ten trans??
Why would they remove the front driveshaft when all that is required is to remove the actuator motor?
Is this the first Jeep they tuned??
Did you go to Hennessy???
Brian
BJB is offline
The Following User Says Thank You to BJB For This Useful Post:
Tim H Calgary (11-26-2012)
post #3 of 11 (permalink) Old 11-19-2012, 03:01 PM Thread Starter
Level ten performance transmission in New jersey
Fastlane performance said they have tuned a bunch and the tuner that works for them said he use to work for hennessey..
No I didn't hennessey is a ****ing joke and wouldn't help me with prior shit
post #4 of 11 (permalink) Old 11-19-2012, 03:56 PM
bushmaster3000's Avatar
I know when I forgot to plug in the transfer case wiring after installing my transmission this was instantly on my dash. Double check that no wires were pulled out or cut and make sure its snapped all the way in. Mine was a very very tight fight. Check the fluid as well. And I hate to ask...but did they put the front driveshaft back in? I'm with BJB, not sure why they removed the driveshaft and not the motor. Its probably not as big of a deal as the real axle, but I would make sure they installed the front driveshaft in the same orientation as it came out...because of balancing.
~~~~~ Special Thanks to~~~~
Skip at Demon Performance
Bada$$ Tuner Johan!
bushmaster3000 is offline
post #5 of 11 (permalink) Old 11-19-2012, 04:03 PM Thread Starter
Yes driveshaft is on.If the orientation is off would it cause the this problem?
post #6 of 11 (permalink) Old 11-19-2012, 04:47 PM
I dont think it would turn a light on.
post #7 of 11 (permalink) Old 11-26-2012, 01:44 PM Thread Starter
So I took it to the dealer and come to find out my TC is burnt up..and from the research I've done the TC motor has to be unplugged and or removed. I didn't have any problem before I took to get tuned..so did the shop cause this because they didn't unplug or remove motor because I watched them they did neither.???? Only removed front driveshaft.. Now they used a diablo tuner and I donno if the ESP was off..
post #8 of 11 (permalink) Old 11-26-2012, 01:47 PM Thread Starter
And I saw in my first post I said they unplugged ..typo*** they did NOT unplug
post #9 of 11 (permalink) Old 11-26-2012, 02:01 PM
Tim H Calgary's Avatar
I am no expert but if they had the driveshaft out with the t-case motor still in and ESP off that would be a very bad thing. With ESP off its a 50/50 split. I think during normal operating conditions the t-case only engages when it see's slip in the rear wheels.
Tim H Calgary is offline
post #10 of 11 (permalink) Old 11-26-2012, 04:38 PM
jmrice's Avatar
I had the exact same message and it turned out to be a bad transfer case motor. Had it tested at Arrington and them replaced there. Plugged in a new one and it was good to go!
jmrice is offline
service awd light jeepsrt8kev WK1 Troubleshooting / Problems Discussion / Dealer Service 6 01-21-2012 12:53 PM
4WD Service Warning Light CGriffin WK1 Troubleshooting / Problems Discussion / Dealer Service 3 11-27-2010 07:07 PM
Getting the Service 4wd System light Squilly D WK1 Troubleshooting / Problems Discussion / Dealer Service 8 09-11-2010 12:14 AM
service 4wd system light grocery gtr WK1 Troubleshooting / Problems Discussion / Dealer Service 4 09-10-2007 05:44 PM
Service 4wd Light NORCAL-SRTGC WK1 Troubleshooting / Problems Discussion / Dealer Service 2 07-31-2007 05:07 PM
