Bucking when turning wheel all the way tight? - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 11-10-2012, 05:16 PM Thread Starter
ltleo's Avatar
Exclamation Bucking when turning wheel all the way tight?
Ever since this dam storm I started to notice a weird kinda bucking when I turn tight into driveways. Kinda loses power steering and like the front wheels are bucking when turned tight.
any ideas? I checked power steering level, it was at the low end of normal, so I filled. I did have a problem a few months ago with my rac and pin that was replaced via warnty.
Any thoughts? Smooth shifting on driving no noise. Just very tight turning and trying to move?
Thanks for the help.
All Motor......... Just old fashion CI .. Nothing to see here... Just drive by..
ltleo is offline
post #2 of 5 (permalink) Old 11-10-2012, 05:26 PM
That guy..
Rocky31186's Avatar
Transfer case locking up.. Search for transfer case issues.. you will find this exact problem 100 times
06 GCSRT8
BT Catch Can, K&N Intake - Johan Tooned - Toyo Proxes4 - Eibach Lowering Springs - 6000k HID's - Magnaflow Exhaust - R1 Concepts - FRI Lil Boy 0* - Vortech V3
Rocky31186 is offline
post #3 of 5 (permalink) Old 11-10-2012, 07:52 PM Thread Starter
ltleo's Avatar
What would cause that? Thanks for the tip I will search it. I just had my diffs flushed by my dealer about five hundred miles ago
ltleo is offline
post #4 of 5 (permalink) Old 11-10-2012, 09:02 PM
Mine got better after I had an alignment done to fix my inner tire wear. Still did it slightly but not as bad
PB: 7.92@87.47 1/8 mile
A.V.GCSRT8 is offline
post #5 of 5 (permalink) Old 11-11-2012, 03:37 PM Thread Starter
ltleo's Avatar
So what should I tell my dealer so I don't get the change fluid cover up fix? The good thing is I already had my truck brought in and documented for our transfer noise with traction control off a few times, so this should fall under a progression I hope.
ltleo is offline
Tight Steering Wheel dj.robbase WK1 Suspension / Driveline Discussion 5 04-25-2013 12:27 AM
Vibration through steering wheel on slow tight turns jvs0302 WK1 Troubleshooting / Problems Discussion / Dealer Service 8 10-22-2012 09:58 AM
Procharger Guys....How Tight is Tight When It Comes to the Belt? jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 20 04-30-2012 10:42 AM
Steering wheel makes a squeeking sound when turning like a bearing or something turtle1678 WK1 Troubleshooting / Problems Discussion / Dealer Service 6 06-06-2009 04:47 PM
Ha, Tight! Jred22 Off-Topic Discussion 13 08-13-2008 10:51 AM
