Cooling problems after cam install - Cherokee SRT8 Forum
post #1 of 23 (permalink) Old 11-07-2012, 09:27 AM Thread Starter
kf12538's Avatar
I just finished installing a new cam (not happy with outcome), drained all the coolant and replaced with new. I started it up and ran it to find there is no coolant flow going on. None of the coolant in the radiator is getting to the motor. I have checked the thermostat in boiling water to verify it is opening. Is there just too much air in the system? What is the next step?
RIPP gen 2 supercharger, Magnaflow catback, Black Ops control arms, end links, R1 drilled/slotted rotors, Black Ops carbon fiber front lip
kf12538 is offline
post #2 of 23 (permalink) Old 11-07-2012, 09:29 AM
ekaz's Avatar
You definitely have air in the system or your water pump froze. Is there coolant in the tank? Has the level dropped at all?
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #3 of 23 (permalink) Old 11-07-2012, 09:47 AM
Dman70's Avatar
This happened to me too. I had to burp the system (release pressure) a couple of times on my drive home to get the air out.
2009 Silver SRT8 Option 1 and 2
Dman70 is offline
post #4 of 23 (permalink) Old 11-07-2012, 10:54 AM
Shawn1112's Avatar
Exactly what Dan said
Shawn1112 is offline
post #5 of 23 (permalink) Old 11-07-2012, 11:13 AM
SRT8VIC...'s Avatar
Do you have a stant radiator cap, thats an easy way of purging the system a few times after purging it from the water pump.
Victor The Great!
PB:
Mods: Its A Beast!
SRT8VIC... is offline
The Following User Says Thank You to SRT8VIC... For This Useful Post:
Knuckles (11-07-2012)
post #6 of 23 (permalink) Old 11-07-2012, 11:16 AM Thread Starter
kf12538's Avatar
The radiator and reservoir is full of coolant and nothing is dropping. How do I purge the air out? I have a non-pressure releasing radiator cap from autozone.
kf12538 is offline
post #7 of 23 (permalink) Old 11-07-2012, 11:53 AM
SRT8VIC...'s Avatar
Get a brand stant 18 lbs locking radiator cap at your local auto parts store. Install this new rad cap, let the car run for 30-40 min and pull the red lever up and you will see air burst into the reservor then pull lever back down to lock. do that a few times and that will get the air out. Another method is purge from the water pump. In the area where the throttle body is at, under that on the water pump you will see a hex screw plug, you would loosen that up to release air and tighten back in to seal close.
You can do either one or both like I did.
post #8 of 23 (permalink) Old 11-07-2012, 05:19 PM
Shawn1112's Avatar
I would think he would start over heating if it idles for 30-40 minutes?
post #9 of 23 (permalink) Old 11-07-2012, 06:05 PM
SRT8VIC...'s Avatar
Possibly, Im suggesting at idel and not drive cycle. I would imagine owner would purge system using either method before reaching that point of overthe heating. This is what I did and worked great. Driving the rig with air in system is asking for trouble period! He can overheat quick and bust a head gasket.
post #10 of 23 (permalink) Old 11-07-2012, 06:35 PM
Details on the bad experience with the cam might help diagnose the problem. There is a lot that can go wrong with that job.
Jack_Toepfer is offline
Cooling Fan going bad? Rocky31186 WK1 Troubleshooting / Problems Discussion / Dealer Service 23 07-07-2014 08:21 PM
Weird problems post Kooks header install DubaiGCSRT8 WK1 Intake/ Exhaust Discussion 30 07-13-2011 12:30 PM
Attempted to install my Jet 180 stat and AFE intake tonight. all kinds of problems.. Rez90 WK1 Troubleshooting / Problems Discussion / Dealer Service 23 03-01-2010 09:05 AM
Borla S install problems!Please need your HELP! (Moved) SrtJake WK1 Troubleshooting / Problems Discussion / Dealer Service 7 08-07-2009 12:00 PM
problems after Borla install gordy0079 WK1 General Performance Discussion 7 10-16-2007 01:51 PM
