Cooling problems after cam install - Page 2 - Cherokee SRT8 Forum
post #11 of 23 (permalink) Old 11-08-2012, 07:40 AM
ekaz's Avatar
Idle it until it reaches normal temp on the gauge (215), then release the air via radiator cap or plug in the water pump. I prefer the radiator cap and have used the coolant tank cap before too.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #12 of 23 (permalink) Old 11-08-2012, 07:42 AM Thread Starter
kf12538's Avatar
I bought a lever operated pressure releasing cap and ran it at idle for a while. I did see many air bubbles coming up through the reservoir. However, I still have no flow into the engine at all. The radiator is still full and my defroster is blowing cold air. I can't believe the water pump would have just stopped working.
As far as the cam install, everything went fine. I am not happy with the cam I installed because it seems to be far more extreme than how it was advertised. It is a custom spec cam from Lunati and it has a radical idle (has died while running). I am hoping Johan will be able to remedy some of it. I didn't want to change the valve springs or add a stall converter.
Any more ideas on the cooling problem would be greatly appreciated. I am planning on taking out the thermostat and seeing if I can tell if the water pump is spinning when I turn the motor over.
RIPP gen 2 supercharger, Magnaflow catback, Black Ops control arms, end links, R1 drilled/slotted rotors, Black Ops carbon fiber front lip
kf12538 is offline
post #13 of 23 (permalink) Old 11-08-2012, 07:50 AM
Shawn1112's Avatar
No clue???
Shawn1112 is offline
post #14 of 23 (permalink) Old 11-08-2012, 07:52 AM
Shawn1112's Avatar
Quick question, when you refilled with coolant after cam install, where did you refill through?
post #15 of 23 (permalink) Old 11-08-2012, 08:21 AM
meeper's Avatar
when you put coolant back in a car, you need to start it up empty with the cap off, then start filling through the rad till the thermostat opens then you should be able to add more, air bubbles will flow out, you can run an engine with full rad and coolant will not pump out, however you have to put the cap on before you shut off the car and if the car is warm then you have to start the car before taking the cap off to check level doing so relieves the pressure in the system so it doesnt spray you. filling the bottle on the fender is very last once rad is filled
meeper is online now
post #16 of 23 (permalink) Old 11-08-2012, 08:38 AM
Shawn1112's Avatar
I was always under the impression you remove the water neck and T-stat and fill their first. At least thats what I did on my Charger a few times. I was told to do it that way from several people who work on these motors for a living. Then put t-stat and water neck back on and top off from above.
post #17 of 23 (permalink) Old 11-08-2012, 08:55 AM
meeper's Avatar
you dont have to, the rad cap is the highest point in system. ive worked on a few and never had any issues. only time u need to worry is when you see an allen head plug screw on the upper rad hose engine side, then thats higher than the rad cap and you need to fill there to get bubbles out, just like on the jeep 3.7/4.7L
post #18 of 23 (permalink) Old 11-08-2012, 08:57 AM Thread Starter
kf12538's Avatar
Also, I stripped out the bleed screw near the water pump.
kf12538 is offline
post #19 of 23 (permalink) Old 11-08-2012, 09:02 AM
meeper's Avatar
u dont even need to touch that
post #20 of 23 (permalink) Old 11-08-2012, 09:03 AM
meeper's Avatar
on a side note on thermostat install, you need to make sure that the small hole on it is towards the top
Cooling Fan going bad? Rocky31186 WK1 Troubleshooting / Problems Discussion / Dealer Service 23 07-07-2014 08:21 PM
Weird problems post Kooks header install DubaiGCSRT8 WK1 Intake/ Exhaust Discussion 30 07-13-2011 12:30 PM
Attempted to install my Jet 180 stat and AFE intake tonight. all kinds of problems.. Rez90 WK1 Troubleshooting / Problems Discussion / Dealer Service 23 03-01-2010 09:05 AM
Borla S install problems!Please need your HELP! (Moved) SrtJake WK1 Troubleshooting / Problems Discussion / Dealer Service 7 08-07-2009 12:00 PM
problems after Borla install gordy0079 WK1 General Performance Discussion 7 10-16-2007 01:51 PM
