TCM problem perhaps? - Cherokee SRT8 Forum
post #1 of 37 (permalink) Old 11-06-2012, 02:52 PM Thread Starter
hotrodcalvert's Avatar
Thought I had given up on this issue, until it decided to rear its ugly face again today............I recently had my ESM module and shifter assembly replaced due to the fact that my truck had been shifting too soon to the next gear and falling on its face with the shifts, which Im not used to, being that I have Johan's tune and it keeps the shifts very firm and hard (which I like)...........dealer ran the codes and that part popped up faulty, so I replaced it to no avail - full cost out of pocket, no warranty................well today, as I was merging onto the interstate, I got caught behind a slow accelerating dumptruck, once the pass lane opened up, i was around 60mph at the time, I didnt punch it, but gave it enough throttle to kick down to pass the truck, and it absolutely WOULD NOT accelerate or increase RPM one bit for approximately 5-10secs, which surprised the hell out of me of course and caught me off guard, it held at the speed and RPM I was at instead, so I completely backed out of the throttle, I was kinda scared to get back into it, but I did and it picked right back up. Took it immediately to the dealer and of course, with my luck, they didnt read one single code. So now that I have replaced the ESM module, and the dealer is reading absolutely no codes, where do I go from here? I spoke with Bill about possible TCM issues and potentially replacing that, but dont wanna replace another part that isnt broken like the dealer screwed me over with that ESM module install. Just a confused and concerned Jeep owner with no idea where to go next.
Colby
The "Silver Bullet" ---- 2006 Jeep SRT8 - Gone but definitely not forgotten
hotrodcalvert is offline
post #2 of 37 (permalink) Old 11-06-2012, 02:57 PM
ekaz's Avatar
I'll have to look for the thread, but there was a guy on LXF having the same issue. I don't recall what came of it though. I'll see if I can find it.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
The Following User Says Thank You to ekaz For This Useful Post:
hotrodcalvert (11-06-2012)
post #3 of 37 (permalink) Old 11-06-2012, 03:02 PM Thread Starter
OK appreciate it sir, I dont mind fixing the problem, if I could just pinpoint the problem, haha
post #4 of 37 (permalink) Old 11-06-2012, 03:05 PM
ekaz's Avatar
Well not much help but sounds like the exact same issue..I'll bump the thread to see if I can generate some activity.
http://www.lxforums.com/board/f71/th...reeway-322054/
ekaz is offline
post #5 of 37 (permalink) Old 11-06-2012, 03:09 PM Thread Starter
Yea it sounds like it, aside from the fact that mine has been falling on its face on the shifts for months now, and Im afraid to keep driving it in fear of tearing up something in the tranny, because when it shifts, its not letting the RPM's rise to the proper point when shifting to the next gear, it shifts too soon, and the RPM's just tank and you can tell the tranny kinda bogs from having to pull up from that low RPM in that gear.
post #6 of 37 (permalink) Old 11-06-2012, 04:23 PM Thread Starter
Just a nuisance more than anything, plus Johan and Harrison both have looked at datalogs and cant see anything wrong, so something aint showing its face, ggrrr
post #7 of 37 (permalink) Old 11-06-2012, 04:35 PM
SPEEDDEMON's Avatar
Ok I don't have much experience with this but I believe it has to do with the communication between the PCM and the TCM so I would try swapping those out with new/reformatted ones and seeing if that makes a difference. Some time ago, when I first got my Jeep, I floored it on the highway before I knew of the ESM cleaning issue and the Jeep just shut down, which was quite scary. I then learned of the ESM cleaning issue but never cleaned it. A few months ago, I had swapped out my TCM from Bill's one to the Stock one when I went to put in my Backup PCM in. When I drove that day, the vehicle would not let me go past 45 mph no matter how hard I floored it. When I got by the shop, to format my backup PCM, and swap it out with my main PCM, everything went back working fine. Now as a precaution, I have also cleaned my ESM, but what I do know, is that there needs to be clear communication between those three devices as they can cause you lots of problems and even cause you to believe something is wrong with your engine or your transmission etc I also have three different TCM's that I can swap out but none of them have ever given me any issues!
, Innovate MTX-L Wideband
Fluidyne Customized Radiator
More to come
SPEEDDEMON is offline
post #8 of 37 (permalink) Old 11-06-2012, 05:06 PM
Knuckles's Avatar
Have you tried to reset the adaptives on your Rig and is your TCM set to 3.73 Axel Ratio? What TCM are you running stock or MPTCM, or PTCM?
Knuckles
Knuckles is offline
post #9 of 37 (permalink) Old 11-06-2012, 05:23 PM Thread Starter
Ive reset the adaptives numerous times, never messed with the ratios, and its still the stock TCM.
post #10 of 37 (permalink) Old 11-06-2012, 05:43 PM
Knuckles's Avatar
Oh ok..... Try a Mopar TCM and see how it reacts... Maybe a local member can borrow you one or let you try it for a bit...
Knuckles is offline
HID problem :( dirtrcr WK1 Lighting Discussion 9 04-26-2012 10:24 AM
TCM Problem? housemouse100 WK1 Troubleshooting / Problems Discussion / Dealer Service 5 04-25-2012 08:14 AM
Diablo Tuner Problem/tcm Problem SRTB WK1 Troubleshooting / Problems Discussion / Dealer Service 6 08-22-2009 02:28 PM
Big Problem.... frankofiore WK1 Troubleshooting / Problems Discussion / Dealer Service 8 09-05-2008 03:25 PM
I Think I Just May Have A Problem OurZoo WK1 SRT8 General Discussion 29 08-20-2007 03:06 PM
