Attn Stage 6 Fuel Hat Owners!!! - Cherokee SRT8 Forum
post #1 of 52 (permalink) Old 07-12-2012, 03:48 PM Thread Starter
It seems we've had a few failures pop up in the last week or two. Some hoses on the feed side have cracked and a few feed lines have popped off causing the trucks to shut down and lose fuel pressure. If it happened to you, please post up what happened. Also let us know if your fuel lines have swelled at all.
We have written a letter today to Gates explaining about their fuel lines cracking. They're the only ones we know of that make submersible fuel lines. We are exploring other options and we will be beefing up my fuel system this weekend and will see how mine is holding up since I have about 30K on my setup.
One or two here and there is no biggie but now a few more have popped up and we ain't diggin' that. We've always stood behind out products and will continue to do so. Most have been reattaching the fuel lines and have been good since, but it still shouldn't have happened. We thank you guys for your support and we'd appreciate any and all feedback you guys can give us. Thanks.....
Harrison
Harrison@Stage6 is offline
The Following 7 Users Say Thank You to Harrison@Stage6 For This Useful Post:
hoseclamp (08-08-2012), Knuckles (07-12-2012), m4xm1l10n (07-12-2012), mklaus (08-07-2012), Muellge  (07-12-2012), StangSlayerMA (07-12-2012), TOMMYSRT (07-16-2012)
post #2 of 52 (permalink) Old 07-12-2012, 03:52 PM
CHUCKTOWNSRT8's Avatar
I wouldn't even know where to look. Are you talking about in the tank?
[SIGPIC][/SIGPIC]
CHUCKTOWNSRT8 is offline
post #3 of 52 (permalink) Old 07-12-2012, 04:31 PM Thread Starter
Yes. The fuel hat in the tank.
We got a reply from Gates. They would like pictures of any split hoses that anyone may have. Thanks guys.
post #4 of 52 (permalink) Old 07-12-2012, 05:09 PM
cmn1's Avatar
Haven't had any issues yet and I do monitor it in my logs which I log everywhere I go.
cmn1 is offline
The Following 2 Users Say Thank You to cmn1 For This Useful Post:
Harrison@Stage6 (07-16-2012), Muellge  (07-12-2012)
post #5 of 52 (permalink) Old 07-12-2012, 05:23 PM
Muellge's Avatar
does deadmanhose make something? I recall this problem popping up with earlier different source fuel hats, including one I had, because of the type and size clamps being used. If you're using normal worm clamps, that could be the issue. If using "fuel line" clamps (which have a similar but "different" method of compressing the fuel line against the nipple, with rounded edges and no sharp edge contact, then maybe just a bad run of gates hoses? good luck with fix and a big hats off (pun intended) to this vendor for not burying the cat turd. Good show.
Five Door League...
Muellge is offline
The Following User Says Thank You to Muellge For This Useful Post:
post #6 of 52 (permalink) Old 07-12-2012, 05:56 PM
chance575's Avatar
Ive had submersible lines in my gto with a hat setup for 6 years and they are gates. I've had no issues.
10 GC SRT8, Maggie
chance575 is offline
post #7 of 52 (permalink) Old 07-12-2012, 06:12 PM
YoungMedic23's Avatar
Y'all should replace those lines with bamboo shoots Harry
YoungMedic23 is offline
The Following User Says Thank You to YoungMedic23 For This Useful Post:
autenb (07-16-2012)
post #8 of 52 (permalink) Old 07-12-2012, 06:46 PM
Coksmith&Master-Pintsman
navyavi469's Avatar
Nothing tops my Fuel System from KRC.... Good catch on the fuel Hoses harry, another stand-up example of Stage 6 standing behind their work and fixing what needs to be fixed.
* 2006 WK1 JEEP SRT8 (THE FIRST) TURBO BUILD, 743AWHP/860AWTQ *SOLD*
__CREDITS: S6 Motorsports, Paramount, AJ Hemituner, Johan, LPM Engines
* 2013 WK2 JEEP SRT8 ALPINE (DAILY DRIVER/VISUAL MODS)
__CREDITS: BWoody Performance, Taillight Solutions
*I have plans, yes... I have plans
navyavi469 is offline
The Following User Says Thank You to navyavi469 For This Useful Post:
post #9 of 52 (permalink) Old 07-12-2012, 08:39 PM
Marathon Man
TonySRT8's Avatar
Thanks for the headsup Harrison. Just another reason to have a fuel pressure gauge. I'll let you know if I see a fuel pressure issue. But so far its been fine and I know if I do have the issue you will take care of me.
Beast has been sold.
'07 GCSRT8 Black, Daily Driver, 41K Miles, Loaded minus rear DVD
PB 11.17@118 with 1.57 60' uncorrected
Vortech, Snow Meth, Paramount Drivetrain, MHP TCM, Wavetrac, Stage 6 Fuel System, Borla S, QA1 Shocks, 5K HIDs, BWoody Springs, NT05's, R1 Brakes, Medic CF Hood, Stillens.
TonySRT8 is offline
post #10 of 52 (permalink) Old 07-16-2012, 10:26 AM
rmon's Avatar
Harrison
Mine was the common hose that split coming out of the "T"connector. It was about two inches long and the reinforcing mesh was separated as well. The other hoses and the clamps which were the non- worm type were fine. The day I did the r&r I was rushing bc of having to wrestle with a full gas tank and had to buy new hose while the Jeep was on the rack. I had to hurry bc another job was coming into the shop and I didn't want to hold it up. So I didn't even get pictures. I thought about it the next day, but when I stopped by the owner said he already threw everything away. Wish I had saved the hose bc it was a pretty big split. BTW FWIW I think following up on this issue is a great thing and shows real concern for you customers. Technically it's a hose problem and a lot of vendors wouldn't care and would just point fingers or try to sweep the problem under the rug. Thanks again for the follow up and thanks for all the help with the initial install Harry. Sorry I couldn't be more help.
Rich
Vortech V3, Paramount transmission, and TCM, Dominator convertor, Stage 6 fuel hat, Inertia cam, StainlessWorks LTH, Wavetrac LSD, Modified Magnaflow Cat Back, Modern Muscle ported intake, Arrington 85mm TB, Tuned by Mike at OST
PB 11.56@118.3
street tune, full weight, all season tires, 93 octane
PB 11.17@122.3
Weld 17"wheels, timing and VP110 added, subwoofer left at home
rmon is online now
The Following User Says Thank You to rmon For This Useful Post:
Attn: NY owners... mrkrabs318 WK1 SRT8 General Discussion 2 01-27-2012 05:15 PM
ATTN!!! European Owners!!!!!! TXBLU WK1 Interior/Exterior Visual Modifications 50 04-10-2008 03:42 PM
ATTN Los Angeles Area Owners marc4sgr WK1 SRT8 General Discussion 3 11-23-2007 11:36 AM
