Attn Stage 6 Fuel Hat Owners!!! - Page 5 - Cherokee SRT8 Forum
post #41 of 52 (permalink) Old 11-16-2012, 02:06 PM
Marathon Man
TonySRT8's Avatar
My pressure didn't get weak. Its been 60 psi and was showing that this morning, cause I always sit in the jeep and let it warm up before heading out. It just shut off like it stalled. Didn't notice it running differently or anything. It was only when I pulled off to the side of the road and tried to restart it that I saw it sitting at zero. Only about 2 miles from my house to where it shut off on me.
Beast has been sold.
'07 GCSRT8 Black, Daily Driver, 41K Miles, Loaded minus rear DVD
PB 11.17@118 with 1.57 60' uncorrected
Vortech, Snow Meth, Paramount Drivetrain, MHP TCM, Wavetrac, Stage 6 Fuel System, Borla S, QA1 Shocks, 5K HIDs, BWoody Springs, NT05's, R1 Brakes, Medic CF Hood, Stillens.
TonySRT8 is offline
post #42 of 52 (permalink) Old 11-16-2012, 02:38 PM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
That's exactly what happened to mine....no warning, no gradual pressure loss, it just lost all pressure at a stop sign.
StangSlayerMA is offline
post #43 of 52 (permalink) Old 11-16-2012, 03:05 PM
1BAMFR's Avatar
Looks like I made it about 9 months. Jeep died on my way to work today.
Had it towed to my buddies shop, but won't know more until monday when he can get around to it.
On a plus side, looks like I have an appointment now to have the front wavetrac installed.
Been there done that too.....my fuel line blew out in the middle of the line and at the top.....zero fuel pressure. Kinda of an easy fix once you drop the gas tank out of it.
1BAMFR is offline
post #44 of 52 (permalink) Old 11-16-2012, 06:21 PM
rmon's Avatar
I've been there and done that too. Twice. The explaination makes sense because the hose splits and the reinforcing mesh stays intact. So the rubber has to be failing internally. The rubber also seems to soften and you can see the reinforcing mesh outlined on the outside of the hose. Here's a couple pics of what my top hose looked like when it failed. I noticed a slight drop in pressure and had some starting issues for about a week. I probably had a pinhole that finally turned into the split in the photo. When it split I nosed over with zero fuel pressure and coasted to the side of the road. Then it was flatbed time for me too. The second time I noticed the same slight pressure drop and dropped the tank and found a split under a hose clamp. Looking back I probably over tightened the clamp and broke through the coating. I had the use of a lift and had the hose replaced and the tank back up in about an hour and a half the first time and a little over an hour the second time. The first time wasn't bad and the second time was an easy fix.
Name:	top hose 21.jpg
ID:	25643 Click image for larger version
Name:	top hose1.jpg
Rich
Vortech V3, Paramount transmission, and TCM, Dominator convertor, Stage 6 fuel hat, Inertia cam, StainlessWorks LTH, Wavetrac LSD, Modified Magnaflow Cat Back, Modern Muscle ported intake, Arrington 85mm TB, Tuned by Mike at OST
PB 11.56@118.3
street tune, full weight, all season tires, 93 octane
PB 11.17@122.3
Weld 17"wheels, timing and VP110 added, subwoofer left at home
rmon is online now
post #45 of 52 (permalink) Old 11-16-2012, 06:43 PM
Live For Today!!!
SRT8_Paratrooper's Avatar
hey HB, Should I be concerned with this?
Stage6/PWR 393 TT Beast
Jerseyboy Tuning
Paramount Performance
The First STAGE6 Twin Turbo Jeep And First Jeep With TWINS UP FRONT!!!
SRT8_Paratrooper is offline
post #46 of 52 (permalink) Old 11-17-2012, 12:10 PM Thread Starter
Sadly Ryan, you should be a little worried. We didn't find out about this until after yours was built.
It looks like we may just start pushing the FORE hat as we are dealers for them. It sucks bc our system works flawlessly with the exception of have to deal with this issue. Bad thing about the FORE hat is you have to be a return style system. Not everyone needs a return system. Plenty of people including us have made stupid safe power on a non return system. All this bc of shitty hoses. Lol. After redoing our kits though with the new way, current customers should be good to go. I don't want to scare people by any means.
We've never hidden this problem from any if y'all. Glad we have figured out the issue. It's definitely a cheaper solution to the FORE hat. In the end..... I guess it just comes down to the build and what you guys really want.
Harrison@Stage6 is offline
The Following User Says Thank You to Harrison@Stage6 For This Useful Post:
Knuckles (11-17-2012)
post #47 of 52 (permalink) Old 11-17-2012, 12:24 PM
LAFNGA5's Avatar
harrison, you can run the fore hat with the stock parts aside from the fuel hat
10's Best Be Coming
LAFNGA5 is offline
post #48 of 52 (permalink) Old 11-17-2012, 02:00 PM
Live For Today!!!
So should i have Jim look at the hat while the jeep is at the hemi shop? is this something they can fix now so it isn't a problem later. it sucks because i dont have a fuel pressure gauge mounted inside.
post #49 of 52 (permalink) Old 11-17-2012, 09:10 PM
Marathon Man
TonySRT8's Avatar
Harrison, instead of cutting the hose to fit. Can we get it made to the correct size so that it all remains coated? I still don't know what my exact issue is, but I'd hate to go thru this again in another year.
TonySRT8 is offline
post #50 of 52 (permalink) Old 11-17-2012, 09:39 PM
Knuckles's Avatar
I was thinking the same thing Tony.....
Knuckles
Knuckles is offline
Attn: NY owners... mrkrabs318 WK1 SRT8 General Discussion 2 01-27-2012 04:15 PM
ATTN!!! European Owners!!!!!! TXBLU WK1 Interior/Exterior Visual Modifications 50 04-10-2008 02:42 PM
ATTN Los Angeles Area Owners marc4sgr WK1 SRT8 General Discussion 3 11-23-2007 10:36 AM
