Attn Stage 6 Fuel Hat Owners!!! - Page 2 - Cherokee SRT8 Forum
post #11 of 52 (permalink) Old 07-16-2012, 05:59 PM
autenb's Avatar
Originally Posted by YoungMedic23 View Post
Y'all should replace those lines with bamboo shoots Harry
Harry... look on NLOC. Those guys had the same guys in the Lightnings before they started to use a stainless Y & some fancy brand of submersible lines.
-Gates products are usually top notch though. Call Peritek?
Brian Auten -Typically easier found on BookFace or YouTube these days.
"BasicB1" on FB.
Twin Turbo 392. Ported Intake, 94mm N20 TB. Custom Thitek heads. Demon Mid-Length Headers & Cam, Borla S, Cutouts, SHR War Viking, 3400RPM Stall, S6 2-Step
Full Fore Fuel System 3-450lph pumps, 1650cc FIC injectors.
Eibachs, QA1's, End links, JBA UCA's. AlamoHydroGraphix Dipped 22"s & Demon Perf Drag wheel/tire setup. Tuned by Joel.
autenb is offline
The Following User Says Thank You to autenb For This Useful Post:
Harrison@Stage6 (07-16-2012)
post #12 of 52 (permalink) Old 08-07-2012, 08:55 AM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
Went to get a coffee Friday, and on the way home my Jeep stalled out on me right in the middle of an intersection. 0 fuel pressure on the gauge. Had to get towed home, and then had it towed to ESP yesterday. Just got word that the feed line popped off. Pumps were installed 2000 miles ago.
StangSlayerMA is offline
post #13 of 52 (permalink) Old 08-07-2012, 09:05 AM
autenb's Avatar
This is not what I want to hear. Are you guys using a stainless Y with a retention ring on the end?
Please get this corrected... Skip will b sending a fuel hat for me here soon... But I can't afford to have these issues guys.
-Brian
autenb is offline
post #14 of 52 (permalink) Old 08-07-2012, 09:06 AM
autenb's Avatar
Please delete..
autenb is offline
post #15 of 52 (permalink) Old 09-21-2012, 12:03 PM
10JGCSRT8's Avatar
I think I may have an issue with my hat. I've been having problems starting the jeep and its been stalling everytime i would come to a red light or stop sign...dont have a fuel pressure gauge. it seems like its not getting enough gas. if it was an issue with the fuel hat would I loose all fuel pressure?
- DEMON PERFORMANCE CUSTOM 88MM TURBO & 419
9.30 @ 150!-
Brian
2014 Ford Raptor SCrew
10JGCSRT8 is offline
post #16 of 52 (permalink) Old 09-21-2012, 12:13 PM
It depends what the problem is. My main feed hose blew off and I lost all fuel pressure. The Jeep stalled out, and wouldn't start at all. If there is a split in one of the hoses, the pumps may not be able to maintain full pressure, but still allow it to run. I would think you would notice that as you accelerated though, not coming to a stop or at idle.
post #17 of 52 (permalink) Old 09-21-2012, 12:17 PM
Tim H Calgary's Avatar
Interesting. Appreciate you being upfront about the issue . Hopefully there is a reasonably simple solution.
Tim H Calgary is offline
post #18 of 52 (permalink) Old 09-21-2012, 12:19 PM
autenb's Avatar
Mine looked pretty tightly attached when I received it from the guys down @ Stage6, so I didn't touch it. Just pulled the old one out, slapped the "new" one in.
I'll b sure and letcha know if I have any problems with it.
autenb is offline
post #19 of 52 (permalink) Old 09-21-2012, 01:02 PM
10JGCSRT8's Avatar
acceleration is fine under partial throttle..this morning I was coming to work and was cruising around 75 on the highway not in boost, as soon as i hit boost it started bogging and sounded like i was running out of gas.
post #20 of 52 (permalink) Old 09-21-2012, 01:48 PM
Blown-WK's Avatar
Kind of ironic but my fuel line split this morning on the way to work. I could instantly tell something was wrong because it almost stalled out when i had to stop for a red light. I noticed the fuel pressure jumping around between 15 and 50psi. I babied it back home and it was bucking and sputtering every time i had to slow down or make a right turn. Once I got home and turned it off it wouldn't restart until I primed the key a few times to build some fuel pressure but you could see the pressure leaking down as it sat. Time for some Stage 6 love when the boys get back from VMP. Amazing how a $2 piece can ruin your morning
-CHRIS-
10.61 @ 129
Blown-WK is offline
The Following User Says Thank You to Blown-WK For This Useful Post:
10JGCSRT8 (09-21-2012)
Attn: NY owners... mrkrabs318 WK1 SRT8 General Discussion 2 01-27-2012 05:15 PM
ATTN!!! European Owners!!!!!! TXBLU WK1 Interior/Exterior Visual Modifications 50 04-10-2008 03:42 PM
ATTN Los Angeles Area Owners marc4sgr WK1 SRT8 General Discussion 3 11-23-2007 11:36 AM
