Just Passed Pa. Emissions with Stainless Works Headers - Page 4 - Cherokee SRT8 Forum
post #31 of 63 (permalink) Old 08-10-2011, 10:20 AM
Rose City GC SRT8's Avatar
Kudos to you, Rmon. This and BuilderBill's experience seems to affirm that this is the only reliable way to make headers and the O2 sensors happy for the '07 and up crowd. Subscribed, and looking to do headers in the future.
DAVE - Steel Blue '07, Mopar exhaust, Volant CAI, DCX depot CMR tune, Jet T-stat, BWoody springs and links, aftermarket camber-compensating upper control arms
Rose City GC SRT8 is offline
post #32 of 63 (permalink) Old 08-10-2011, 10:21 AM
Knuckles's Avatar
Originally Posted by rmon View Post
Thanks man. You'll love the set up. It's about a 15-20 min swap for the mid pipes on jack stands. Really easy. With the off road mids the the beast barks when you start it up and rumbles around town, and WOT is sick. But it never drones like some other set ups. To me it was like turning up a good music.
Anytime bro!! Yeah looking forward to more Bark at WOT!
Knuckles
Knuckles is offline
post #33 of 63 (permalink) Old 08-11-2011, 05:27 PM
Wintermute's Avatar
I have 1 7/8" headers and a Corsa cat back and I gained torque everywhere in the power band with my set up. If you have flat spots, your getting O2 error codes and have one black tailpipe you might want to think about replacing one or more of your O2 sensors especially since you've had a bunch of different exhaust combinations. At the very least check the side of the black tailpipe you might have a sensor that's loose. I replaced mine at 22K and was surprised how much better the car runs with the new O2 sensors.
Well, the dumb thing is I havent put the extensions on or put johans rear delete tune in yet so I think the sensors are just picking up ambient air right now. Hell I dont even know where they are after all the work I've had done. I'll put the tune in tonight and get the extensions and hopefully that clears up the codes and running rich. If not I'll check the sensors. Thanks for the advice.
2015 Porsche Macan S
2012 JGC Overland Deep Cherry
2010 JGC SRT8 Modern Blue - Sold
Wintermute is offline
post #34 of 63 (permalink) Old 08-11-2011, 06:29 PM Thread Starter
rmon's Avatar
I can tell you from experience that you can't run a tune in our application without rear O2 sensors connected even with the rear O2 sensors turned off. Johan and I tried every combination that he had on my Jeep with the off road mid pipe rear bungs plugged and it set codes every time. Your gunna see 0038/58 and 0138/58 either right at start up or after 5 to 50 miles. I had to buy rear O2 sensors for my off road pipes and connect them to run the tune with the rear O2's turned off. With the rear O2 sensors installed I now have about 600+ miles on my catless set up without setting any codes.
Rich
Vortech V3, Paramount transmission, and TCM, Dominator convertor, Stage 6 fuel hat, Inertia cam, StainlessWorks LTH, Wavetrac LSD, Modified Magnaflow Cat Back, Modern Muscle ported intake, Arrington 85mm TB, Tuned by Mike at OST
PB 11.56@118.3
street tune, full weight, all season tires, 93 octane
PB 11.17@122.3
Weld 17"wheels, timing and VP110 added, subwoofer left at home
rmon is offline
The Following User Says Thank You to rmon For This Useful Post:
mcopare (08-12-2011)
post #35 of 63 (permalink) Old 08-12-2011, 10:13 AM
Wintermute's Avatar
Jeezuz, seriously? So with cats in my midpipe I need 24" extensions installed for the rear O2's, and extensions for the front O2s as well ? I dont know where these things are in the stock locations. Whats the point of tuning out the rears if you still get a code ?
post #36 of 63 (permalink) Old 08-12-2011, 11:52 AM Thread Starter
rmon's Avatar
My impression is that turning off the rear O2 sensors eliminates their feedback to the PCM so that they don't "see" parameters outside of their specified guideliines. Eliminating them shows what is essentially an "open" circuit that HAL doesn't like and unfortunately it can't be tuned out. Maybe an expert can chime in with opinions and/or a better explanation.
rmon is offline
post #37 of 63 (permalink) Old 08-15-2011, 10:32 PM
Silvernine's Avatar
Nice job man good to hear everything worked out
Silvernine is offline
post #38 of 63 (permalink) Old 03-20-2012, 05:59 PM
Knuckles's Avatar
Hey Rich,
When you get a chance can you list the exact parts that you used to make the stock cat easily interchangable?
Thanks!
Knuckles is offline
post #39 of 63 (permalink) Old 03-20-2012, 06:06 PM
cmn1's Avatar
Originally Posted by Knuckles View Post
Hey Rich,
Thanks!
Jose, until you get rid of the two front codes you will not pass. You need to get those sensors closer to the exhaust stream.
cmn1 is offline
post #40 of 63 (permalink) Old 03-20-2012, 06:24 PM
Knuckles's Avatar
Yeah I know what you mean, but at this point everything is worth a shot because I only have 2 more weeks left.
Knuckles is offline
Pass Emissions in DENVER with Stainless Works Headers??? chitass WK1 Intake/ Exhaust Discussion 18 05-23-2010 09:40 AM
Stainless works Headers? turtle1678 WK1 Intake/ Exhaust Discussion 4 05-31-2009 08:35 PM
Stainless Works Headers turtle1678 WK1 General Performance Discussion 19 02-27-2009 10:45 PM
Stainless Works Headers on the way! Harrison@Stage6 WK1 General Performance Discussion 16 06-02-2008 07:44 PM
