dead battery replaced now jeep dying )-: - Cherokee SRT8 Forum
post #1 of 9 (permalink) Old 05-05-2011, 07:10 PM Thread Starter
pimpski25's Avatar
i came out to my jeep after work and the battery was dead... it was original battery on an 06 srt8 jeep. so not a big deal 5 plus years out of a battery, thats about right... when replaced... the jeep fired right up but then kept dying out on me... it finally started acting like it's supposed to and i drove home... then when pulling in my drive it dies on me again... please help!
pimpski25 is offline
post #2 of 9 (permalink) Old 05-05-2011, 10:14 PM
CentralTexHemi's Avatar
What did you replace it with and is it possible the grounds are loose?
2007 SRT8 Jeep GC-Sold 7/28/2011
2011 Porsche Cayenne S
2012 Shelby GT500-10.6 @ 128
2014 Porsche Cayenne GTS (on way)
CentralTexHemi is offline
post #3 of 9 (permalink) Old 05-05-2011, 11:28 PM
SRT-MANA's Avatar
Send a message via AIM to SRT-MANA
Any CEL or Mods ?
SRT-MANA is offline
post #4 of 9 (permalink) Old 05-06-2011, 07:36 AM
the1stkim's Avatar
Send a message via Yahoo to the1stkim
check all connections, and then the alternator
the1stkim is offline
post #5 of 9 (permalink) Old 05-06-2011, 10:52 AM Thread Starter
pimpski25's Avatar
Yes to both... CEL is on... And the mods are as follows...
Indy stage II heads, PPP ported intake, MM ported throttle body, comp cams custom cam, kooks headers and cats, magnaflow exhaust, 80lb injectors, dual walbro fuel pump. I have had the CEL for a while though... It was a misfire that set it off. I've been having sole problems with limp mode as well... From what I've read on that, it's most likely in the shifter. Tried cleaning the bands but most likely will have to bite the bullet and buy the new shifter assembly. Any help on both issues would be greatly appreciated. Also I had red lightning bolt come on the dash once or twice... Throttle body sensor??
post #6 of 9 (permalink) Old 05-06-2011, 11:39 AM
Could be a tuning issue with your mods
post #7 of 9 (permalink) Old 05-06-2011, 03:01 PM
Escape's Avatar
Did you re-install your tune? Since the battery died it probably lost all the adaptives and is now having to relearn. Happened to me this winter when the Jeep was outside for a few weeks.
I also noticed that right before the battery died it was adding more fuel on bank 2 since the O2 sensor I assume was not getting the proper voltage and sending a weak signal to the PCM. It learned to live this way and when the new battery was installed it died a few times as it learned to live with a weak signal and was now getting a perfect signal. You should be OK but I'd check your trims just to be sure and reinstall the tune.
I try to reinstall my tune about every 3 months as for some reason my Jeep has angry Gremlins that live in it or Alzheimers I'm not sure which...lol . Once I reinstall everything is back to perfect
Your may want to try upping your idle 50 in P/N and 100 in D/R
XRT 8 Turbo
Forged, Stroked, Blown, Bottle Fed & so much more!
Escape is offline
post #8 of 9 (permalink) Old 05-07-2011, 11:31 AM
Im leaning to the side with tuning issues and not sure why you need the dual fuel pump with your mods and could be the source of your issues with fuel trims out of whack, IDK man
post #9 of 9 (permalink) Old 05-07-2011, 06:15 PM
I was going to say the tune may be off as well, but if you have tried that then I don't know.
2008 Jeep SRT-8 Red Rock 2.4 Whipple SOLD
2013 Ford Raptor Super Crew 6.2 SOLD
BOYCHIKS is offline
Battery Dead Need another NOW but which CentralTexHemi WK1 Troubleshooting / Problems Discussion / Dealer Service 19 11-27-2010 04:17 PM
Replaced battery in keyfob and now no buttons work AZDEUCE WK1 Troubleshooting / Problems Discussion / Dealer Service 2 05-31-2010 03:52 PM
Anyone ever have to a battery replaced in a 3G iPhone Harrison@Stage6 Off-Topic Discussion 21 04-20-2009 06:24 PM
Battery Dead Again BILLSHOE WK1 SRT8 General Discussion 22 03-06-2009 01:33 AM
Dead Battery Again!! Harrison@Stage6 WK1 Troubleshooting / Problems Discussion / Dealer Service 15 01-19-2009 06:12 AM
