Ultimate Prowertrain Control Module thread and my problems. - Page 55 - Cherokee SRT8 Forum
post #541 of 550 (permalink) Old 02-15-2013, 04:41 PM
AussieSRT@TTC's Avatar
BTW where is that hardware switch in CMR that shuts off the ABS torque reduction request?
im pretty sure if anywhere youll find it in
scalars
right click on top of table select edit and screen will populate a little different than you have seen before,
930rwhp pump unleaded 93oct .... that is all
0-1000m in 17.8 sec @ 295kmh
quarter mile to come soon
AussieSRT@TTC is offline
post #542 of 550 (permalink) Old 02-15-2013, 09:59 PM
Muellge's Avatar
Originally Posted by Blown7 View Post
Yep all you have to do is mention anything about money and then posts get reported..NSV blah, blah. whatever. Nobody ever says "Gee this fellow or that fellow brings more to the forum in knowledge or help than most vendors".
But I don't spend much time here anymore I'm just way too busy just trying to survive and I just wanted this thread to have a somewhat happy ending for those that may have the questions.
I tried being a vendor a couple years ago but I didn't have an extra million Canadian dollars laying around.
Like I said, get the tuner you mentioned as a exclusive tuner source to add you as a rep and problem solved. You solve problems this solution should be obvious and easy. The dudes that pay to be here get chippy when you develop a market but don't pay like they do, even if it is a 5 year can bus epic that might let us one day do a burnout and then switch back to four shoe traction.
Five Door League...
Muellge is offline
post #543 of 550 (permalink) Old 02-17-2013, 04:28 AM Thread Starter
Blown7's Avatar
Yep the forum vendors that pay get results even if the results ain't so good..
<cross forum bashing comments removed>
Just because someones a vendor don't mean they are any good.
Anyways back on track..
Did i mention Tim Millikens a bum?? Takes your money and tools like DS....Got that Google search bots??
So in other discussion areas I predict within a short amount of time that people will be switching from the NGC4 PCM's and using the GPECII PCM's from the 2011+ WK 2'sand installing them in to the WK1's..
Why? Tun-ability for boost..The NGC series didn't do it for the Hemi stuff, only SRT4's using NGC3 using a Motorola 555 Spanish Oak processor and the GPECII using the higher speed MPC 5554 does it seamlessly.
I don't think the WK2's will make much more power reliably using boost on a stock 392 as that engine was a badly designed engine from the get go.. but use a engine based on the 6.1 block and I do believe a WK2 will be a better driving vehicle than a WK1 .
Other will argue that the WK1 PCM can be tuned for boost quite well... my argument is the operating system was never designed to see boost so your just manipulating MAP voltages to try to tune for boost ...you just do not have the extra cells in the MAPS to add for the extra points that should be there to see positive pressure.
Besides all that.. it will be cool to have electronic waste gate to really regulate the boost pressures and not have to rely on a spring.
My entire focus for myself is to eliminate the ETC... with that in place your always going to deal with microprocessor pulse width modulation time latency. No matter how you slice it ....the computer controls the throttle and I just cannot allow that to happen.
OK I'm going back to the bench and hope to have some real tech next post ..
John Wayne
Blown7 is offline
post #544 of 550 (permalink) Old 02-17-2013, 01:20 PM
BJB
"guy with the crazy Jeep"
BJB's Avatar
Jeff, did you wish UV a happy B-day? Its his day today...
Brian
BJB is offline
post #545 of 550 (permalink) Old 02-17-2013, 05:01 PM Thread Starter
Blown7's Avatar
Not sure on that but over time it was harder and harder to get ahold of him. Until he vanished.
Poof...
Blown7 is offline
post #546 of 550 (permalink) Old 02-17-2013, 05:03 PM Thread Starter
Blown7's Avatar
I actually was thinking today as I was playing with a Dodge truck PCM..
Why can't the Dodge truck PCM run the NAG1 in the Jeep?
Both have 5 speeds....
Blown7 is offline
post #547 of 550 (permalink) Old 02-17-2013, 07:20 PM
Re: Ultimate Prowertrain Control Module thread and my problems.
Because the control systems are completely different...
J
Sent from my SPH-D700 using AutoGuide.Com Free App
JerseyBoy@Stage6 is offline
post #548 of 550 (permalink) Old 02-17-2013, 08:19 PM
BJB
BJB's Avatar
Poof...
Look likes he enjoys Starbucks if your stumped on gift ideas...
BJB is offline
post #549 of 550 (permalink) Old 02-17-2013, 08:37 PM
BuilderBill's Avatar
I'm with Blown7 on the Tim M. deal.
I put him in the same category as DynoSteve.
Both people I surely wish I NEVER met or dealt with....
Bill
BuilderBill is offline
post #550 of 550 (permalink) Old 02-18-2013, 03:43 AM Thread Starter
Blown7's Avatar
J
Well it was just a thought, I haven't played with any truck stuff in CMR and I didn't know how much adjust-ability is in CMR to modify the truck transmission program to run a NAG1.
The Hemi PCM and the truck PCM use the same 5554 processor with the Hemi only using ETPUA to run the engine and the Dodge uses ETPUA for the engine and ETPUB to run the transmission. As I said just a thought....another way to tune the TCM side..
Yea with all the money I sent he should be able to put a down payment his own franchise...
Bill
Yea there sure have been quite a people like that in the Hemi world thru the years.. GSM, DS,I can't remember many others...
I must say though for all the folks that have come and gone you still have a Sterling reputation that offsets the others.. be well my friend.
Blown7 is offline
