Transmission Control Module Bad... anyone else??? - Cherokee SRT8 Forum
post #1 of 34 (permalink) Old 11-03-2009, 08:16 PM Thread Starter
Unhappy Transmission Control Module Bad... anyone else???
Hey guys, new member here. I bought my '07 gcsrt8 in april and have loved it, until it started acting crazy lately. On the first couple of accelerations when cold(after sitting all night) it would bog out at 2500rpm and feel like the brakes grabbed then after a couple of long seconds take off like a bat out of hell down shifting hard. I got it in to the dealer today they said I had a bad transmission control module as well as a bad gear shift control module. I was wondering if any of you have heard of these problems before and are they common in gcsrt8's or am I just that lucky. Hey by the way great site keep up the good work. Hopefully I will be at a meet and greet in the chicago area come spring time.
candpmcg is offline
post #2 of 34 (permalink) Old 11-04-2009, 05:20 AM
scoutermike's Avatar
Never heard of that one before
Alas. My fast Jeep has been replaced by a slow one.... 2013 Wrangler Rubicon 10th ann.
08 SRT Jeep Red Rock Crystal: Loaded - Mopar Hitch n harness, bWoody 4" CAI, K&N Drycharger, Predator & CMR tune by JB, Kooks headers & hi-flow cats, Mopar cat back, Lips fog light harness, BT Catch can, AEM UEGO A/F gauge, Power Bond UD pulley, Jet 180 t-stat, Road Magnet Performance Springs, Addco Sways & BWoody links, Delosh hood graphic and BuilderBill's Stage II valve body.
scoutermike is offline
post #3 of 34 (permalink) Old 11-04-2009, 05:29 AM
The gear shift module has gone out on several jeeps which seems to make the shifts slam but never heard of the trans module going bad.
robdeniro0 is offline
post #4 of 34 (permalink) Old 11-06-2009, 07:16 AM
NeverFastEnough's Avatar
More than likely the ESM. I had mine replaced recently under warranty...have you gotten the 'service park assist' message yet??
Why Shifter Lever Assy breaks on Jeeps
Steve K
'07 GC SRT8 - Not stock anymore!
'00 GC Limited - K&N CAI, Borla cat-back exhaust
NeverFastEnough is offline
post #5 of 34 (permalink) Old 11-06-2009, 07:30 AM
I would also check the Electronic Shift Module (ESM). I had mine replaced and it was causing a bunch of problems and fault codes. Look at the link above and i have posted here with problems that replacing the ESM fixed. Sorry i'm on my phone and can't find posts easy. Do a quick search on the ESM and you will see a bunch. Good luck and welcome!
SRT830 is offline
post #6 of 34 (permalink) Old 11-07-2009, 09:23 AM Thread Starter
hey thanks for the advise/info. the dealer is installing a tcm(transmission control module as well as the esm(electronic shift module aka gear shift module). they stated that they are having a hard time finding the tcm, the nearest is in canada somewhere.,i'm down in chicagoland so it will be a few days before i get to drive my beloved srt8. at least the weather is nice this weekend and i can still drive my '97 conv't transam. oh and yes the srt8 will blow the doors off of the ta but you can't put the top down on the srt8 either. see ya thanks again.
candpmcg is offline
post #7 of 34 (permalink) Old 11-08-2009, 09:36 PM
Send a message via AIM to PROBABLE CAUZ Send a message via MSN to PROBABLE CAUZ Send a message via Yahoo to PROBABLE CAUZ
the tcm shouldnt be hard at all to get. they are readily available online through many dealerships. try moparsupercenter they are a dealership and stock it.
PROBABLE CAUZ is offline
post #8 of 34 (permalink) Old 11-10-2009, 05:11 PM
The tcm is part of the pcm and the gear shift module is known as the electronic shift module and goes bad all the time. I work in a jeep dealer and do a esm at leat once a week. It is possible that the tcm/pcm was also bad or it could have been replaced for good measure.
ryanplayjoint is offline
post #9 of 34 (permalink) Old 11-10-2009, 06:00 PM
robpp's Avatar
ryan i can see you are very knowledgeable about jeeps but on the srt8 and the 5.7 hemi jeeps, the tcm is a seperate box located under the dash under behind the center stack. my 4.7 and i guess the 3.7 have the tcm as part of the PCM.
i do agreee that the esm probably is the culprit here.
robpp is offline
post #10 of 34 (permalink) Old 11-13-2009, 06:20 PM
Rob your a 100% right, I work on so many jeeps they just clump into one big cluster of parts. The nag or mercedez transmissions all have the tcm under the dash, such as 3.7, 5.7, and 6.1.
Ultimate Prowertrain Control Module thread and my problems. Blown7 WK1 Troubleshooting / Problems Discussion / Dealer Service 549 02-18-2013 02:43 AM
HHP Upgraded TCM (Transmission Control Module) nasiero WK1 Suspension / Driveline Discussion 9 09-11-2009 05:28 PM
Transmission Overflow? millers_srt WK1 Troubleshooting / Problems Discussion / Dealer Service 3 09-04-2009 03:17 PM
My Builder Bill Transmission Story sarge WK1 Suspension / Driveline Discussion 36 07-16-2009 11:59 PM
Wheel Alignment nycxed WK1 SRT8 General Discussion 5 05-02-2008 09:06 AM
