Why Shifter Lever Assy breaks on Jeeps - Page 11 - Cherokee SRT8 Forum
post #101 of 126 (permalink) Old 11-02-2012, 04:44 PM
stang99x's Avatar
Driven it three days now after cleaning, and it hasn't happened since. (and it was happening constantly when it got bad the other night)
07 Steel Blue Volant 180Tstat muffler delete Predator BT catch can(best Hemi mod ever) Tinted Tails
stang99x is offline
post #102 of 126 (permalink) Old 11-10-2012, 11:00 PM
SPEEDDEMON's Avatar
Has anyone tried the Dorman ESM or know anything about their reputation...I am wondering if it is better quality than Oem, some aftermarket products are, and they say they have been in business since 1918 http://www.amazon.com/Dorman-601-001-Electronic-Shifter-Module/dp/B008J1OR8S/ref=sr_1_1?ie=UTF8&qid=1352610101&sr=8-1&keywords=dorman+601-001
, Innovate MTX-L Wideband
Fluidyne Customized Radiator
More to come
SPEEDDEMON is offline
post #103 of 126 (permalink) Old 11-19-2012, 01:10 PM
I have been putting off fixing my truck, Well after reading the previous post about his jeep dying in the intersection, i finnally cleaned my board off today. I drive tractor trailer and just envisioned the nightmare if mine died. Anyways the truck is much better now. The last few days with cold up here it was really starting to act up.
2006 with 77,000 on it. Truck has been stock its whole life, so i doubt the previous owner ever cleaned the board off. Of course i buy the truck and three weeks into owning it I get the common symptoms. Glad I have been lurking here for years. I knew exactly what was wrong.
Curt S is offline
post #104 of 126 (permalink) Old 11-19-2012, 01:52 PM
Tim H Calgary's Avatar
If anyone ends up replacing their ESM go to factorymoparparts.com (I am in no way associated with them). 440 there vs the 1300 the dealership quoted me. I cleaned mine but that only bought me a few weeks. Good luck all!
Tim H Calgary is offline
post #105 of 126 (permalink) Old 11-24-2012, 11:40 AM
Cleaned mine on the 19th, see post above, happy to report not a hint of issues since.
Curt S is offline
post #106 of 126 (permalink) Old 12-04-2012, 01:08 PM
Update 3. After a week this got my drivin habits down and i was really enjoying the shift points. Well two days ago it started screwing up again. Damn. Ill try cleaning again. Hopefully it will work permently.
Curt S is offline
post #107 of 126 (permalink) Old 12-04-2012, 01:27 PM
I just replaced my ESM and sadly the gears all circled on me again... Now this only happens when I first key on the vehicle and have never had limp mode. Wonder if it's just not seeing the ESM on start up. All I have to do is key it off and back on and it goes away. Shifting is much better since replacement. I donated my old ESM to research (forum member) hopefully he'll have some insights.
post #108 of 126 (permalink) Old 12-07-2012, 08:52 AM
Thank you thank you thank you
The OP of this thread is my hero. Had exactly the same issue and with google's help found this thread. The dealer wanted to replace the TCM which would not have helped and would have cost me $700.
This fix was pretty simple. Biggest problem was remembering how to put it back together. Hint, next time take pictures. I did see carbon deposits between the pads which I'm sure were causing the problem.
Love this forum and the people who are on it. Oh, and my SRT8.
moleson10 is offline
post #109 of 126 (permalink) Old 01-16-2013, 12:23 PM
I want to take apart the ESM module on my 2007 Grand Cherokee and clean the graphite contacts. Does any one know if this procedure requires you to reprogram the computer after completing the reassembly?
rmiller55 is offline
post #110 of 126 (permalink) Old 01-16-2013, 12:56 PM
Nope just put it back together and plug it back in and you are good to go.
