howling noise at high speeds - Cherokee SRT8 Forum
post #1 of 11 (permalink) Old 08-03-2009, 07:22 AM Thread Starter
dsalogia's Avatar
For the last few months at 50-80 mph, something under the car howls when foot is off gas peddle cruising. Its gotten worse. Is it the transfer case? Noise goes away when u hit the gas. Without music on its pretty loud and annoying. Also, vibration at the steering wheel has gotten worse around the same speed. Can anyone tell me what it is. I have an 06 with 38k
07 Red Rock
Borla, K&N CAI, BT catch can, Toooooned, R1 + Stoptechs
dsalogia is offline
post #2 of 11 (permalink) Old 08-03-2009, 10:03 AM
CentralTexHemi's Avatar
Maybe?
http://www.wkjeeps.com/tsb/tsb_wk_2100506.pdf
2007 SRT8 Jeep GC-Sold 7/28/2011
2011 Porsche Cayenne S
2012 Shelby GT500-10.6 @ 128
2014 Porsche Cayenne GTS (on way)
CentralTexHemi is offline
post #3 of 11 (permalink) Old 08-03-2009, 11:38 AM Thread Starter
dsalogia's Avatar
Already had this done a year ago. Could it need to be done again? Are they gonna charge me considering I'm at 38k
dsalogia is offline
post #4 of 11 (permalink) Old 08-03-2009, 12:03 PM
veyronSRT8@TTCreations's Avatar
is it coming from the rear (as in louder for the passengers in the rear)? if so i would think it could be the rear diff? transfer case could also be the culprit (may want to find out if they really did replace it for you when they were supposed to have done it)... i would check fluid levels for sure....and ask Bill.
veyronSRT8@TTCreations is offline
post #5 of 11 (permalink) Old 08-03-2009, 12:05 PM
Yeah howling at high speeds could be rear diff and shuddering at high speeds could be a bent driveshaft. Take a look under the jeep and make sure your rear pinion seal is not leaking, its located on the back of the rear diff where the rear driveshaft connects to it. If your rear driveshaft went out of whack it could of caused the rear diff to go back as well.
post #6 of 11 (permalink) Old 08-14-2009, 04:43 PM
pinion ringing
PETERSRT-8/10 is offline
post #7 of 11 (permalink) Old 10-01-2012, 01:56 PM
Has anyone else experienced this and found a fix for it?
I'm experiencing the same thing... It's a higher pitched howling noise that occurs when I let off the gas on the highway at any speed about 45-50mph, and then goes away when I start to apply light throttle again. At speeds slower than 45mph, there is no noise at all. I don't have any vibration in the steering wheel either.
2008 Jeep Grand Cherokee SRT-8
TurboKR is offline
post #8 of 11 (permalink) Old 10-01-2012, 02:35 PM
championjeep's Avatar
My money is on a rear diff, maybe pinion nut has backed off a little giving you too much play. You let off the gas and that little bit of movement at those speeds causes the noise. When accelerating or steady on the gas there is continuous pressure applied and no noise is present. Thats my guess anyways.
"This country, with its institutions, belongs to the people who inhabit it. Whenever they shall grow weary of the existing government, they can exercise their constitutional right of amending it or their revolutionary right to dismember it or overthrow it."
-Abraham Lincoln, April 4th 1861
championjeep is offline
The Following User Says Thank You to championjeep For This Useful Post:
TurboKR (10-02-2012)
post #9 of 11 (permalink) Old 10-02-2012, 02:16 PM
Thanks for your input, I'll check it out.
Wish I would have asked this question about 2 weeks ago before changing the rear diff fluid.
TurboKR is offline
post #10 of 11 (permalink) Old 10-02-2012, 02:41 PM
LoudPedal's Avatar
Presents the same as mine did. Under warranty at 32k miles I had the ring and pinion replaced. Problem solved.
SOLD...07..Black....Tune by Johan, BO's CF, Billet Tech, Bwoody CAI-End Links-Track bar, RM Springs, Mopar Catback, QA1 Shocks, Extreme HIDs.
LoudPedal is offline
The Following User Says Thank You to LoudPedal For This Useful Post:
TurboKR (10-07-2012)
OBD 2 Codes list hemi.jon WK1 Troubleshooting / Problems Discussion / Dealer Service 8 10-30-2013 05:32 AM
Lubrication of brake caliper pins promo718 WK1 SRT8 General Discussion 45 03-11-2009 06:56 PM
Exhaust noise at high RPM Gus WK1 Troubleshooting / Problems Discussion / Dealer Service 0 08-21-2008 10:06 AM
tires and shaking at high speeds? jordo9998 WK1 Troubleshooting / Problems Discussion / Dealer Service 9 01-13-2008 03:46 PM
Howling Noise From Rear End !!!! NextLevel WK1 SRT8 General Discussion 10 09-11-2007 06:54 PM
