Check TPM System <-- Error message I'm getting on my '08 - Cherokee SRT8 Forum
post #1 of 10 (permalink) Old 03-02-2009, 11:24 AM Thread Starter
QBNKID's Avatar
I found two older similar threads but vehicles involved where not '08 specific IIRC, and according to the dealer the '08's have a different TPM System (not sure).
So I decided to start a new fresh thread about it. .
OK so I’ll summarize it from the start.
1. I had to get rear passenger tire fix do to a nail in it, so I had it patched (not plugged).
2. Next day I started having this error message on the EVIC “Check TPM system”
3. I still get the correct PSI reading on all 4 tires.
4. Took it to dealer and they couldn’t fix via StarScan.
5. There’s a wireless tool they take to each tire to report data back to StarScan but the tool was only good for years up to ’07, they didn’t have one for ’08 (bummer).
6. So they decided to replace both sensors, the one inside the tire and the one on the wheel well behind the tire, called Wireless Control Module (WCM).
7. They road tested it and said that it was fixed.
8. Got home (25 miles away), had the jeep off for about an hour then got back on the jeep and same error message came back on the EVIC… It always happens about a minute or two after the jeep is started, one ding sound followed by “Check TPM system” and then it shows the tire PSI screen, then I had to hit the step button for it to go away and everything is back to normal until the next time I start up the jeep again.
Anyone else experienced this same error with theirs and found a solution?
I think the dealer ran out of options to figure this one out.
Any ideas what I should try next?
Thanks!
//Mario// - 2008 JEEP SRT8
PB: 60ft... 1.539 - 1/8 Mile... 7.408 @ 91.27 - 1/4 mile... 11.726 @ 115.18
Performance Mods: HHP 426 Stroker/Heads/Cam/Headers/Trinity/87MM TB/Paramount Valve Body/
Ported-Polished Intake Mani/Corsa Catback/3600 Stall Converter/PTCM/
Bwoody 4" CAI/R1 Concept D&S Premium Rotors/Bridgestone 275/315 RF
Summer Tires
Visual Mods: Eibach Lowering Springs/Bwoody End Links/Black Pillars/Antenna Delete/
20% Side Tints-50% Front Tint/Black Taillights/Chrome Delete/Retractable Front Plate/
Stillen Covers/Killer Glass/Switchback LEDs/Interior LEDs/Reverse Prejector LEDs
QBNKID is offline
post #2 of 10 (permalink) Old 03-02-2009, 05:25 PM
veyronSRT8@TTCreations's Avatar
hmmm, i don't have an 08' but perhaps the TPM system doesnt like patched tires???
veyronSRT8@TTCreations is offline
post #3 of 10 (permalink) Old 03-02-2009, 05:54 PM
waydennis's Avatar
I put 11K miles on a patched tire on my 2006 with no issues.
After getting new tires, I got this message for about 4 days. It finally went away and did not come back. Pressure always seemed to be correct.
Silver 2006 Jeep GC SRT8 - Wrinkle Red BWoody CAI, Jet 180 Stat, Diablo 93 Octane Tune, R1 Drilled and Slotted Rotors, Satisfied GS6 Brake Pads, Vredestein Tires, 13.039 @ 104.87
Plum Crazy Charger R/T Daytona #367 of 1400
Silver 2001 Chrysler Sebring Convertible
Squeaky Satisfied Pro-Ceramic Pads <=Worn out
Red 2002 Dodge Durango - Sold
Silver 2004 Dodge Stratus R/T- Sold
waydennis is offline
post #4 of 10 (permalink) Old 03-02-2009, 06:25 PM
DevssrT's Avatar
Hey Mario, I got this message earlier this winter when it was frigid out....was getting that message, then flash to low psi, then show the psi indicator and show how low the psi was in my 2 rear tires....in addition, my low tire psi orange icon lit up on my dash.
I then took it over to a gas station, filled up each tire to 36 psi (as per my pen handheld psi gauge), hoped in my Jeep, drove for a lil bit, everything went away. However, now my psi indicator windown shows the psi for each tire to always be at around 44-46 when warm out, and 39-41 when its cold out (like tonight).
Not sure if this is your issue, but hope you get it resolved.
2006 Silver Jeep Grand Cherokee SRT8 - RIP
DevssrT is offline
post #5 of 10 (permalink) Old 03-02-2009, 06:29 PM
Miss Understood
Vinnysrt8's Avatar
Send a message via AIM to Vinnysrt8
There could be some moisture in the valve and in the cold weather it might be screwing it up
53 Studebaker 383stroker find out the 1/4 soon
72 SS Nova 468BB 11.7
88 Warlock boat 468BB 80mph
01 BATBOAT BLOWN 1100HP 121MPH
04 KFX700
07 Jeep SRT8 Black BLOWN AND KICKING ASS 11.4 at 116mph
10 SS/RS Camaro 12.9 inferno orange
13 Jeep Grand Cherokee DD
Vinnysrt8 is offline
post #6 of 10 (permalink) Old 05-14-2009, 03:31 PM Thread Starter
QBNKID's Avatar
Update: Dealer replaced another part in order to fix this problem and it seems they got it fixed this time.
The part is called "Wireless Ignition Node" (WIN). Located on the Ignition switch I believe.
They explained to me that it's the part that receives the signal from the TPM sensors in the tires and the Wireless Control Module (WCM) on the wheel well, which they originally replaced.
If anyone else has this issue, let the dealer know to change the WIN before anything else.
QBNKID is offline
post #7 of 10 (permalink) Old 07-01-2010, 09:59 AM
GrundleBear's Avatar
Thanks!
Im having the exact same problem. 2008, it does it when i start it up itll beep once than go away until I start up the Jeep again....tire pressure is always fine...Im going to take it to the dealer and have them replace this Wireless Ignition Node you speak of
GrundleBear is offline
post #8 of 10 (permalink) Old 07-09-2010, 06:25 PM
m4xm1l10n's Avatar
Having this issue as well started 2 days ago , Have an appointment with the dealer on Tuesday , but everything seams fine WTF ..
07 JEEP SRT8 _ SOLD
Tuned By Johan
12.13 @ 110 N/A Cam & Headers
6.90 @ 101 & 10.93 @ 122 Boosted @ 9lbs
m4xm1l10n is offline
post #9 of 10 (permalink) Old 07-09-2010, 06:51 PM
Don't know if you have a trintiy hooked up but when I do I had my TPM light on,must be some interference with the WIN receiving the signal,took trinity out and all was back to normal.
07JEEPGCSRT8 is offline
post #10 of 10 (permalink) Old 07-09-2010, 07:08 PM
i took mine in...they said they replaced the WIN....took it home. And its still doing it. I have to take it back on Wednesday. Really bleeping annoying
Self Service and coolant flush...Questions???!!! Get$$$Man WK1 SRT8 General Discussion 10 10-21-2008 12:58 PM
Check tire press. system display twgcsrt8 WK1 Troubleshooting / Problems Discussion / Dealer Service 27 02-04-2008 01:35 AM
STS Universal Turbo System BigLew WK1 Engine Performance/Superchargers/Turbos/Nitrous 23 01-29-2008 06:43 AM
help with a buyer checklist diesel123 WK1 SRT8 General Discussion 19 11-25-2007 01:34 PM
