crabbing / skipping on tight turns - Cherokee SRT8 Forum
 6Likes
post #1 of 15 (permalink) Old 05-16-2017, 10:56 PM Thread Starter
Guys,
What would cause this? , the 4WD system i didnt think was engaged whilst going slow just in RWD? ?
seems when i turn at low speed its binding up a bit
Cheers
Matt
Metomlin is offline
post #2 of 15 (permalink) Old 05-16-2017, 11:55 PM
I would say transfer case taking a dump
Rob1129 is offline
post #3 of 15 (permalink) Old 05-16-2017, 11:59 PM Thread Starter
i just rebuilt it! haha not ideal looks like ill be heading back to RWD then.
could it be the motor playing up?
Metomlin is offline
post #4 of 15 (permalink) Old 05-17-2017, 03:20 AM Thread Starter
Ok i have just removed the motor from transfer case and the problem has disappeared, i can see the issue it seem the transfer case is in full time 4wd or something.
Wwhen i fix the motor back onto the transfer case the bolts dont line up, it seems the motor is a little bit out so you have to twist it slightly right to line up the bolts.
Also if i turn the ignition on with the motor removed from the T case but connected to the power it doesnt seem to move or change , maybe someone can let me know if its suppose to rotate or anything?
Metomlin is offline
post #5 of 15 (permalink) Old 05-17-2017, 09:48 AM
Mine would do the same with the transfer case motor in it would bind and when i removed the motor it would go away i replaced the transfer case and i havent heard a bind since
Rob1129 is offline
post #6 of 15 (permalink) Old 05-17-2017, 09:50 AM
I would recomend not to turn it on lol supposely it does a 180 turn.....when i put my motor back in it was around 1/4 of an inch off i had to twist it a lil
Rob1129 is offline
post #7 of 15 (permalink) Old 05-17-2017, 10:53 PM Thread Starter
Ok so mine has now done a 180 degree turn off the transfer case, is there way to get it back or not?
Metomlin is offline
post #8 of 15 (permalink) Old 05-17-2017, 11:20 PM
SPEEDDEMON's Avatar
Get a buddy, and one of you enable and disable traction control with the trinity, it should line up after a while, then you can connect it. Do not force it manually or you may damage the motor.
Jfra likes this.
, Innovate MTX-L Wideband
Fluidyne Customized Radiator
More to come
SPEEDDEMON is offline
The Following User Says Thank You to SPEEDDEMON For This Useful Post:
Passmg2 (05-18-2017)
post #9 of 15 (permalink) Old 05-17-2017, 11:54 PM Thread Starter
ok thanks mate, will try it tonight
cheers
Matt
SPEEDDEMON likes this.
Metomlin is offline
post #10 of 15 (permalink) Old 05-18-2017, 01:40 PM Thread Starter
Any chance you can explain the process
Does the car need to be switched on and running or just ignition on ?
I know how to use the Diablo just I can't get it to line up
Metomlin is offline
Binding in driveline on tight turns -cold 884487 WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 1 12-09-2016 05:18 PM
Bluetooth Skipping? zoidberg WK2 Audio/Video/Nav/UConnect/Electronics 2 04-02-2016 05:03 PM
Vibration through steering wheel on slow tight turns jvs0302 WK1 Troubleshooting / Problems Discussion / Dealer Service 8 10-22-2012 08:58 AM
Procharger Guys....How Tight is Tight When It Comes to the Belt? jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 20 04-30-2012 09:42 AM
Tank Turns 1 and Jeep turns over 20,000 miles T-Time Pics & Video Showoff Section 16 07-06-2008 01:28 AM
