Factory HID headlights not working properly, dealer refusing to fix under warranty - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 05-16-2017, 09:11 PM Thread Starter
i have an 08 with the oem auto level hids, which are acting up & making the jeep a pain to drive at night. the sensors worked fine up until this past winter.
most of the time the headlights were pointed completely down, making it difficult to drive at night. in the rare case they were pointed up & at normal level, they would jitter & bounce all over the place. they would still auto level at startup, but otherwise they were not working properly.
the crappy weather has finally subsided where i live, so i decided to take it in to the dealer to have things checked out. i have a maxcare warranty so i figure everything will be fixed & i will be on my way. boy was i wrong.
service advisor calls me back and says: "yea the jeep has a level sensor performance code, but since your lowered theres nothing we can do about that. the module can't compensate for the lowered ride height so unless you install the factory springs your going to have to live with the lights pointed down"
i call back & state that this is a common issue with these sensors to go bad due to where the sensors are located. there are plenty of jeeps on this forum, stock & lowered who have had issues with the factory hid sensors/modules. i also proceed to tell him that there is a manual adjustment on the back of the lights & asked if he could get the tech to raise them up. i also stated that i would like more information on the code that was thrown so i can research it. he says he will have the tech look at it again.
not long after that i get a phone call. its the service advisor again. same deal as before: "yea theres no adjustment on the lights & the tech erased the code, you can come pick the jeep up"
i ended up raising the lights up on my own so i could at least drive at night. they still jitter/bounce all over & the auto level at startup has stopped working as well. whenever i hit the gas they raise up a lot, when i let off they drop. here is a jeep on youtube with similar issues:
later that day i talk to my close friend, who is a tech at another local jeep dealer. he proceeds to tell me chrysler is cracking down on claims because of issues in the past & that anything over $1000 maxcare requires a rep to come out & look at the vehicle. he agreed that the eibachs are probably not to blame, and that they probably used that excuse to avoid any type of problems that may arise if a rep were to come out for approval & find out the jeep was lowered. i told him that i am tempted to write a letter/email to chrysler, but he merely stated that I'm probably pissing up the wrong tree, as they are tired of getting screwed and are rejecting claims left & right for the simplest things.
regardless I'm kinda ticked off & seriously contemplating selling the jeep. any info from you guys would be greatly appreciated.
2quic4u is offline
post #2 of 5 (permalink) Old 05-16-2017, 10:30 PM
Have you checked BOTH leveling sensors? There's one on the front upper control arm, and one on the rear above the axle. On my 08, I discovered the metal bracket was severely corroded and perforated. I could not find just the bracket, as you need to purchase the entire sensor. A few hours of metal fabrication and I made one.
2008 GC SRT8 - Kooks Jet-Hot ceramic coated long tubes with hi-flow Magnaflow cats, Borla T-type, SLP under drive pulley, Volant CAI with brake duct mod, Predator tuned, Eibach Pro-kit springs, QA1 rear shocks, twin- sub Kickers
RamAir is offline
post #3 of 5 (permalink) Old 05-16-2017, 10:47 PM Thread Starter
Both of the sensors look good. One is on the stem on the front a arm & the other one is mounted to the rear upper control arm, both on the passanger side. My money is on the headlamp mounted sensor, but i could be wrong. This is just frustrating.
2quic4u is offline
post #4 of 5 (permalink) Old 05-17-2017, 12:58 PM
slate5.9's Avatar
I no longer have my 08' but mine was doing this as well. I had it in the shop for other work and mentioned what was going on. They said a software update would remedy the problem. I thought for sure it was mechanical. Nope, software flash fixed the problem. They didn't charge me for it either since it was in the shop getting other stuff done.
Matt
2008 GCSRT8, Red Rock Crystal, All options except engine block heater
1998 GC5.9, Deep Slate, Sold
slate5.9 is offline
post #5 of 5 (permalink) Old 05-17-2017, 04:40 PM Thread Starter
I have heard of a software update being available when the sensors are actually fine & not shorted out. I dont think mine are bad honestly & that all it needs is a flash. Sucks cause they are basically refusing to do anything unless i ditch the eibachs.
2quic4u is offline
jeep t stat not working properly 07 jeep srt8 WK1 SRT8 General Discussion 8 12-17-2014 07:03 AM
Auto headlights and HID not working STL07 SRT8 WK1 Lighting Discussion 11 01-21-2013 08:32 AM
AWD not working properly?!? kmitch80 WK1 Troubleshooting / Problems Discussion / Dealer Service 8 03-06-2011 11:35 PM
Dealer is refusing to do service work on Jeep JohnsonSRT8 WK1 SRT8 General Discussion 9 09-10-2009 07:55 PM
Auto headlights and HID not working togeather STL07 SRT8 WK1 SRT8 General Discussion 4 03-31-2009 08:27 AM
