Check engine light on....error code P2096...Please help!!! - Cherokee SRT8 Forum
post #1 of 13 (permalink) Old 01-23-2009, 11:37 PM Thread Starter
My check engine light has been on for the last two days....I got the light to go away by clearing the computer with the battery dis-connect method but it came back on. I took it to auto-zone so they could hook up the diagnostic computer and it was throwing the code P2096. What does that mean? My Jeep is stock. I have no idea what it could be, but I did just get my transmission replaced from the dealer if that matters. I just want to know if it is something I can fix myself because the dealer is an hour away from me.
06blackbeast is offline
post #2 of 13 (permalink) Old 01-24-2009, 06:05 AM
robpp's Avatar
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
Set Condition:
If the PCM multiplies short term compensation by long term adaptive as well as a purge fuel multiplier and the result is below a certain value for a calibrated amount of time over two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
EXHAUST LEAK
ENGINE MECHANICAL
1/2 O2 SENSOR
(K141) O2 SENSOR 1/2 SIGNAL CIRCUIT
(K299) O2 1/2 HEATER CONTROL CIRCUIT
(K904) O2 RETURN DOWNSTREAM CIRCUIT
FUEL CONTAMINATION
_____________________________________________
Since you said new trans, i would get under there and check all the wires from the O2s and make sure they didnt pinch or forget to reconnect anything.
robpp is offline
post #3 of 13 (permalink) Old 01-24-2009, 08:53 AM
brianm's Avatar
jeez rob where do you get all this info lol
" am gonna pick a fight "
DEBADGED AND REBADGED , STILLEN HEADLIGHT COVERS , VOLENT CAI , RAM MEDIC HOOD ,,NEFFY WRAPPED INTERIOR,BLACK OPS CARBON FIBER REAR STEP AND FRONT LIP INSERT , MOPAR REAR SPOILER ,BORLA S CATBACK , EBC DRILLED AND SLOTTED ROTORS , VIPER STRIPES ,PAINTED HEADLIGHTS WITH HALOS AND FOG LIGHTS WITH HALOS FROM DC SPECIAL, GLOSS BLACK USA SPEC WHEELS, LOWERED ,TUNED BY JOHAN ,,,,,,TOTALLY UNIQUE IN UK
brianm is offline
post #4 of 13 (permalink) Old 01-24-2009, 08:57 AM
hemi.jon's Avatar
Send a message via AIM to hemi.jon
biranm if you google the error code it comes up.
or you can go here
http://www.obd-codes.com/trouble_codes/
hemi.jon is offline
post #5 of 13 (permalink) Old 01-24-2009, 09:07 AM
brianm's Avatar
or you can go here
thanks mate
brianm is offline
post #6 of 13 (permalink) Old 01-24-2009, 09:09 AM
shorestyle031's Avatar
phil i would go to the dealer for that
08 BMW M Roadster
Sold: 07 SRT8
shorestyle031 is offline
post #7 of 13 (permalink) Old 01-24-2009, 10:03 AM
robpp's Avatar
Originally Posted by brianm View Post
thanks mate
All that gives you is the title of the fault. If you want the probable cause and the steps for finding the issue, they are from the Service Manual. I have a CD version copied to my laptop.
Brian, let me know if you need one.
Rob
robpp is offline
post #8 of 13 (permalink) Old 01-24-2009, 11:31 AM Thread Starter
Thanks robpp! Here is what I was thinking....I bet they had to unbolt the exhaust to replace the tranny and when they re-installed it, they didnt line it up correctly. I am saying this because I just noticed an interesting rattle coming from my exhaust which sounds like an exhaust leak to me....I'll check it out today.
post #9 of 13 (permalink) Old 01-24-2009, 11:44 AM
CentralTexHemi's Avatar
Does it sound like a helicopter or choppy also look for any exhaust soot (black) around the exhaust connections
2007 SRT8 Jeep GC-Sold 7/28/2011
2011 Porsche Cayenne S
2012 Shelby GT500-10.6 @ 128
2014 Porsche Cayenne GTS (on way)
CentralTexHemi is offline
post #10 of 13 (permalink) Old 01-24-2009, 11:44 PM Thread Starter
Thanks Tex! Yeah, it was a choppy sound.
I did figure out the problem...... I was under the jeep checking all of the exhaust connections when one of my o2 sensors was extremely loose! This was definatley the problem. It looked like they had just put it in place and forgot to tighten it because all the other ones were fine. Air was definately getting in there and I could wiggle it with the lightest touch. Also, they cut the factory tie strap that held the o2 sensor wire up high and away from the heat of the pipes and didn't put a new one on! I could see the old tie strap that had been cut still on there. The wire was just dangling there about half an inch above the pipe, I was surprised it hadn't melted yet. That is some real heat-resistant rubber insulation they have over those wires! So I used my own tie strap and cleaned up the wiring. Also the dealer forgot to tighten the bolts all the way where the stock muffler hooks up to the flanges. After all this, I went over everything under the jeep around the transmission with a fine tooth comb. Other than what's mentioned above, everything else was fine under the jeep and looked good. I have since then reset the CEL and it has not come back on and the exhaust leak noise has disappeared. I'll tell you what though, mechanics at dealers need to slooooow down and quit doing everything so rushed!
Check Engine Light Aaron WK1 Troubleshooting / Problems Discussion / Dealer Service 14 05-19-2011 07:57 PM
Check engine light and shifting issue. Cell Mass WK1 SRT8 General Discussion 3 01-23-2009 03:53 PM
Check Engine Light B&G PhillyJeep WK1 SRT8 General Discussion 6 12-16-2007 10:29 PM
Break-in Procedures AaronC WK1 SRT8 General Discussion 2 08-05-2006 07:03 AM
BAD GAS?? --- check engine flashing upon acceleration SRSSRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 6 05-23-2006 02:07 AM
