High pitched squeal from inside engine - Cherokee SRT8 Forum
post #1 of 22 (permalink) Old 12-30-2008, 03:38 PM Thread Starter
SilveRT8's Avatar
For the last week, there is a constant high pitched squeal coming from inside my engine, at first it seemed to come from the air filter but it gets very loud when I remove the oil fill cap, so it's coming from inside the valve cover or engine. My regular mechanix tought of an air leak from the intake, so he did a smoke leak test but nothing showed, no vacuum leak, oil is fine, drives OK too. Today I started the engine cold and the squeal was not there, shut the engine, restarted and it was back again. Any ideas or suggestion ? 06 with 29K miles
Claude
Claude
06 Silver GC SRT8 600+HP,SOLD
Predator+PCM, Bwoody CAI +links,Kooks LT,HF cats,Borla T,Ported Intake,Trans TCM,170 Tstat,catch can,A/F meter,Weathertech.
1/4 mile 12.16@113.79, 1.69 60', 7.75 1/8th,
VIDEO of 12.16 run
13 Viper GTS White /08 Viper Vert Black SOLD
12 Caddy CTS-V Wagon /12 HD CVO EG 135"
SilveRT8 is offline
post #2 of 22 (permalink) Old 12-30-2008, 03:42 PM
Wild guess, but possibly the intake is cracked and it is sealed when it is cold but when it warms up it expands. Like I said it is a wild guess.
chevyconvert is offline
post #3 of 22 (permalink) Old 12-30-2008, 03:46 PM
LonghornSpencer's Avatar
What oil and weight are you running?
My Jeep is for gone...
Take care of her Steve (midwestsrt8)
HOOK 'EM HORNS
Many will forget what you said.
Some will forget what you have done.
Most will never forget how you made them feel.
LonghornSpencer is offline
post #4 of 22 (permalink) Old 12-30-2008, 03:52 PM
aplatero1984's Avatar
Hey Claude,
I had a Durango with a 5.9L in the shop a few days back with the same concern. It was coming from the PCV valve. It could be the same thing on your Jeep. Just a guess though, wouldn't hurt to check into.
Also, does the sound get louder as the speed(RPM) increases?
aplatero1984 is offline
post #5 of 22 (permalink) Old 12-30-2008, 04:03 PM Thread Starter
SilveRT8's Avatar
No cracked intake as it would have shown on the smoke leak test.
Noise seems pretty constant and not vary with engine speed. I will double check for the PCV valve. Running the recommended Mobil 0-40W. Thanks for the suggestions, keep them coming as I'm clueless about this and hate to bring it to the dealer
Claude
SilveRT8 is offline
post #6 of 22 (permalink) Old 12-30-2008, 04:15 PM
The only thing else I could think of that could cause a squeal sound would be the belts?
post #7 of 22 (permalink) Old 12-30-2008, 04:25 PM
Claude
I have read that under certian circumstances the 0-40W will cause a slight whining noise and if you were to run a slightly higher (15/50 I think) it would go away. Do a search on google for "srt engine whine" I think the LX crowd have the issue more than us
post #8 of 22 (permalink) Old 12-30-2008, 05:06 PM
veyronSRT8@TTCreations's Avatar
call me dumb for throwing this out but could it have something to do with a pulley bearing going bad?
veyronSRT8@TTCreations is offline
post #9 of 22 (permalink) Old 12-30-2008, 08:01 PM
DevssrT's Avatar
Is it your CAI making that whistle sound??...ive noticed that my jeep does this more often when its colder out...
2006 Silver Jeep Grand Cherokee SRT8 - RIP
DevssrT is offline
post #10 of 22 (permalink) Old 12-30-2008, 08:05 PM
grocery gtr's Avatar
Bet It Is The Hoses On Your Catch Can Turn On Your Truck And Squeeze The Hoses Mine Were Cracked On The Inside.........do You Have Steelbraided Lines?
grocery gtr is offline
Ultimate Prowertrain Control Module thread and my problems. Blown7 WK1 Troubleshooting / Problems Discussion / Dealer Service 549 02-18-2013 03:43 AM
white smoke, bad smell from exhaust at start up AFTER 180 therm install rumplemenz WK1 Troubleshooting / Problems Discussion / Dealer Service 25 12-06-2008 06:46 AM
Help! At least help me understand this code...... silver06 WK1 Troubleshooting / Problems Discussion / Dealer Service 10 05-27-2008 11:50 AM
Break-in Procedures AaronC WK1 SRT8 General Discussion 2 08-05-2006 08:03 AM
High Pitched Squeal Sheri'SRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 26 08-01-2006 08:13 PM
