LED mod, resistor needed? - Page 2 - Cherokee SRT8 Forum
post #11 of 21 (permalink) Old 12-26-2012, 07:30 PM
SRTat3U's Avatar
I have the same problem with 2 194 in the back row still no fix????
SRTat3U is offline
post #12 of 21 (permalink) Old 12-27-2012, 08:38 AM Thread Starter
SRT8Fanatic's Avatar
Haven't tried yet, but now I have motivation to get it fixed! I'll let you know soon!
SRT8Fanatic is offline
post #13 of 21 (permalink) Old 01-12-2013, 02:23 PM
SRTat3U's Avatar
Any updates on fix ? I found a resistor kit on eBay but not sure if should pull trigger
SRTat3U is offline
post #14 of 21 (permalink) Old 01-12-2013, 04:51 PM Thread Starter
I didn't install anything yet, but I planned on ordering a 6-ohm >25watt resistor to wire in parallel with the back hatch light. This will draw roughly 2 amps and should load the circuit enough to make it work correctly. I may shoot for a 1 amp fix to see if that works. (12-ohms, >25watt)
These are available at Newark, mouser, or digikey for like $1.
post #15 of 21 (permalink) Old 02-08-2013, 07:50 AM
bcm0018's Avatar
There are a few options:
1. Put a regular bulb in the tailgate.
2. Put a 1.5K ohm resistor on the map light.
Here is a thread with similar discussion.
Dimming interior lights ok with led?
09 SRT8GC HHP built stroker 604/555 - 10.753 PB
bcm0018 is offline
The Following User Says Thank You to bcm0018 For This Useful Post:
SRTat3U (02-08-2013)
post #16 of 21 (permalink) Old 02-08-2013, 07:54 PM
SRTat3U's Avatar
Thanks a ton did you just get one from radio shack or online
SRTat3U is offline
post #17 of 21 (permalink) Old 02-08-2013, 09:03 PM
meeper's Avatar
I didn't need anything special with my led install because I bought the correct can bus style led bulbs
meeper is online now
post #18 of 21 (permalink) Old 02-11-2013, 06:41 AM
bcm0018's Avatar
Your welcome. I just went to radio shack. With how cheap resistors are shipping would probably cost more than the actual resistor.
bcm0018 is offline
post #19 of 21 (permalink) Old 02-17-2013, 12:27 PM
Led interior ltg not dimming
I used a 194 lamp holder witha filament cargo area lamp in it, wired in parallel with the cargo light fitting(with led). This I ty wrapped into the body of the tailgate, the Leds all dim correctly now. Leaving the glove box lamp as a filament lamp does not work as it has its own switch isolating it from the other interior lighting.
Roddaz is offline
post #20 of 21 (permalink) Old 02-17-2013, 04:52 PM
meeper's Avatar
why are we still talking about all these hack job work arounds when the correct LEDs for our application are out there and same price as the normal ones....
Tags
interior, led, light, resistor, watts
A/C Problem - Resistor Change? (Moved) CuJo WK1 Troubleshooting / Problems Discussion / Dealer Service 3 05-02-2012 10:54 AM
A/C Problem - Resistor Change? CuJo WK1 Troubleshooting / Problems Discussion / Dealer Service 0 06-14-2010 09:05 PM
resistor install nyjoed WK1 SRT8 General Discussion 22 05-30-2010 03:54 PM
Resistor install pics for dual color LEDs eddiefig WK1 Lighting Discussion 4 03-10-2010 10:59 AM
Anyone try an IAT Resistor mod? GotStroke? WK1 Intake/ Exhaust Discussion 18 03-01-2007 07:19 PM
