Washer Tank Help - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 11-20-2012, 10:44 PM Thread Starter
LAFNGA5's Avatar
Washer Tank Help
Getting a custom washer tank made, should have pics up shortly (needed removed from the TT kit) however im trying to find the connectors that the stock washer tank pump would use so i can make extension harnesses for the pump & the low fluid indicator
anyone know where one could even begin looking or have a part # to start with
10's Best Be Coming
LAFNGA5 is offline
post #2 of 5 (permalink) Old 11-20-2012, 11:38 PM
Bradleyl22's Avatar
scott would you take a detailed picture of the plug i may be able to find something that will work at the shop. correct me if i'm wrong your looking to go from the stock male connector to a female to male extension to the female connector on the pump.
Bradleyl22 is offline
post #3 of 5 (permalink) Old 11-20-2012, 11:47 PM Thread Starter
LAFNGA5's Avatar
please pm me your email address and i can send pics of the connectors.
exactly what youre saying though, need a male and female connector side to plug into the factory harness and then into the washer pump.
if need be i will just end up cutting the stock wiring back about 2.5" and then just splice in the needed wiring for the washer pump and the low level indicator but would much rather use connectors for a quick and easy solution that involves to cutting of the stock wiring
LAFNGA5 is offline
post #4 of 5 (permalink) Old 11-21-2012, 12:02 AM
boosting's Avatar
Im confused, is it not possible to cut the stock wire and extend with some new wire and solder?
boosting is offline
post #5 of 5 (permalink) Old 11-21-2012, 12:04 AM Thread Starter
LAFNGA5's Avatar
absolutely is, i would just much rather prefer not cutting into the stock harness if the parts are available to just make a harness for it but if i need to cut and splice i will go down that road
LAFNGA5 is offline
Bwoody Washer Tank Fix WK2 Mongoose9400 WK2 SRT8 Intake/Exhaust Discussion 79 09-29-2013 06:55 PM
Washer Jet Relocation Relwarc WK1 Interior/Exterior Visual Modifications 17 02-23-2012 05:21 PM
HOW TO: Washer Jet Relocation Relwarc Tech Tips - DIY - How-To 2 03-16-2011 08:32 PM
HOW TO: Washer Jet Relocation Relwarc Tech Tips - DIY - How-To 1 03-16-2011 08:32 PM
Rear Washer BILLSHOE WK1 SRT8 General Discussion 8 07-23-2007 09:13 PM
