those with painted rear sensor strips - Page 3 - Cherokee SRT8 Forum
post #21 of 35 (permalink) Old 08-04-2011, 08:08 AM
Muellge's Avatar
cleaned with an adhesive remover, but did not brush it up with fine sand paper or anything. I suppose using some 220 or a soft brass wire brush would promote adhesion, but I really haven't had problems with adhesion. Just pull your masking quickly before a strong bond forms and you get some peel with the tape.
Five Door League...
Muellge is offline
post #22 of 35 (permalink) Old 11-24-2011, 07:43 PM
dsalogia's Avatar
How do you remove that strip...is it double sided tape and clips?
07 Red Rock
Borla, K&N CAI, BT catch can, Toooooned, R1 + Stoptechs
dsalogia is offline
post #23 of 35 (permalink) Old 11-24-2011, 08:20 PM
YYCSRT8's Avatar
Can't remove the rear strip without first removing the rear fascia. It's held in place with spring clips on the backside.
2009 SRT8 - Magnacharged
YYCSRT8 is offline
post #24 of 35 (permalink) Old 11-25-2011, 05:27 AM
SRT8 POWER's Avatar
Send a message via MSN to SRT8 POWER
You have to take of the rear bumper and then remove the clips!
Regards,
Manuel
440 N/A Beast in the making!!!
SRT8 POWER is offline
post #25 of 35 (permalink) Old 11-25-2011, 06:31 AM
dsalogia's Avatar
So lemme get this straight, I have to remove the whole rear bumper first just to get the chrome off? That sucks. Can I do it without lifting the whole srt?
dsalogia is offline
post #26 of 35 (permalink) Old 11-25-2011, 07:32 AM
YYCSRT8's Avatar
Unfortunately you'll have to pull the rear bumper if you want to remove the chrome strip. It's really not that tough and the Jeep doesn't need to be raised. Instruction can be found on the wkjeeps site.
YYCSRT8 is offline
post #27 of 35 (permalink) Old 11-26-2011, 05:06 PM
dsalogia's Avatar
What about the pop rivets in wheel well? Do I need special tool for those?
dsalogia is offline
post #28 of 35 (permalink) Old 11-26-2011, 05:12 PM
YYCSRT8's Avatar
Yes, you'll need to drill out the existing rivets. You'll also need a rivet tool to attach the new ones. The rivets and tool can be found online and they're fairly inexpensive.
YYCSRT8 is offline
post #29 of 35 (permalink) Old 11-28-2012, 04:58 PM
jvs0302's Avatar
Ok bumping back up this thread.
For those of you who painted the rear sensors, what kind of prep did you or your bodyshop do? I know for the rear strip they should sand down the chrome and use adhesion promoter, but what about on the sensors?
Also does anyone have pics of a brilliant black painted rear strip??
John
2010 Brilliant Black SRT8
Mopar intake | Corsa exhaust | Trinity | MTX-L wideband | Jersey Boy tuned | BT catch can | BT underhood kit | Eibach springs | BWoody swaybar links | Summer: Bridgestone Dueller HP Sport RF 275/315 on OEM wheels | Winter: Pirelli Scorpion Ice & Snow RF 275 on satin black reps | R1 Premium Slotted/Cross Drilled rotors | Stoptech pads | DC Customs headlights | TS LED taillights | TS painted moldings |
jvs0302 is offline
post #30 of 35 (permalink) Old 11-28-2012, 05:10 PM
LASRT's Avatar
Sensors just take a part sand down and paint nothing un normal.
LASRT is offline
Rear Chrome Sensor Bezel ? steinism WK1 SRT8 General Discussion 3 07-31-2009 08:37 AM
Painted To Match Roof Rails Park Sensor Strip teda WK1 Interior/Exterior Visual Modifications 11 07-15-2009 06:04 AM
rear suspension level sensor? MattM WK1 Suspension / Driveline Discussion 6 02-24-2008 02:59 PM
