T-stat upgrade - what, where, and how to - Page 3 - Cherokee SRT8 Forum
 1Likes
post #21 of 241 (permalink) Old 11-30-2007, 01:14 PM
Originally Posted by bmartin9122 View Post
As a follow-up, 0.5mm difference is very little. In fact, 1mm is roughly the thickness of a dime. So imagine 1/4 the thickness of a dime added to the outside edge of the thermostat. It is just not very much, and it is readily accommodated by the rubber gasket without any threat of damage.
Of course, some will claim this is a problem, so grind away if you must.
That .5mm difference may not seem like a lot but it's certainly enough to tear the flimsy rubber gasket (it did on mine) which is enough to cause a leak. Thankfully mine let go in my own driveway (after a 2 hr drive believe it or not) as evidenced by the significant coolant trail left behind. Had it burst on the road there's a very good chance I wouldn't have noticed until damage to the cylinder heads due to overheating occured.
Good thread, good pics, good info. Just take the extra time to do it right, that's all.
GotStroke? is offline
post #22 of 241 (permalink) Old 11-30-2007, 01:16 PM
guyrobert's Avatar
Just to be clear on this, if we were to grind we would be grinding down the diameter of the T stat not the seat where it sits?
08 Silver GC SRT 8 - Corsa exhaust, BWoody CAI & sway bars
06 Ram SRT 10 RC Grey - JMB CAI, B&M Shifter LT headers HI-Flow cats Borla Catback SCT 93 Octane tune
06 Ram SRT 10 RC Red Rock - bone stock
75 Buick Lesabre ragtop 455 White - beater
75 Buick Lesabre ragtop 455 Brown - built
75 Buick Lesabre ragtop 455 Red - 2007 BCOA Gold Senior
57 Cadillac Eldorado Biarritz Red - restored (for sale)
75 Buick Electra, 78 Ford f 250 pickup, 03 Ford Exploder limited,
guyrobert is offline
post #23 of 241 (permalink) Old 11-30-2007, 01:17 PM
The outside circumference of the T-stat itself, where the gasket seats against the T-stat.
post #24 of 241 (permalink) Old 11-30-2007, 02:38 PM Thread Starter
bmartin9122's Avatar
Send a message via MSN to bmartin9122
I am sorry to hear of your bad experience. I can honestly say this is the first time I've heard of that happening. How long did it last before failure?
Like I mentioned before, I had no problems with my Mag in the 2 years I ran like this. In fact, I even swapped the t-stat twice - the first time with a 170 then later with a 180. The gasket looked fine with no apparent damage.
-Bryan
09 Ram 1500 Lone Star Edition
06 Ram Megacab CTD
79 GMC Sierra Grande K15 for sale!
08 GC SRT8 gone
06 Magnum SRT8 gone
05 Magnum RT gone
bmartin9122 is offline
post #25 of 241 (permalink) Old 11-30-2007, 02:58 PM
Around 4-5 mos. before letting go. No condolences necessary, it was a learning experience.
post #26 of 241 (permalink) Old 11-30-2007, 03:45 PM Thread Starter
I've cleaned up the thread a bit more and added GotStroke?'s comments.
post #27 of 241 (permalink) Old 12-05-2007, 11:02 AM
Toothmonger's Avatar
Send a message via AIM to Toothmonger
Awesome pics and write up and follow up comments for us wrench noobs. Thanks bmartin and GotStroke.
Joe
Toothmonger is offline
post #28 of 241 (permalink) Old 12-05-2007, 11:14 AM
waydennis's Avatar
I did mine this morning before going to work.
Found the black rubber hanging off the old thermostat, I am very glad I caught it before it broke loose.
Used sand paper to grind down the new tstat in about 5 minutes. It was not going in without some reduction...
Thanks again for the great writeup...
Silver 2006 Jeep GC SRT8 - Wrinkle Red BWoody CAI, Jet 180 Stat, Diablo 93 Octane Tune, R1 Drilled and Slotted Rotors, Satisfied GS6 Brake Pads, Vredestein Tires, 13.039 @ 104.87
Plum Crazy Charger R/T Daytona #367 of 1400
Silver 2001 Chrysler Sebring Convertible
Squeaky Satisfied Pro-Ceramic Pads <=Worn out
Red 2002 Dodge Durango - Sold
Silver 2004 Dodge Stratus R/T- Sold
waydennis is offline
post #29 of 241 (permalink) Old 12-05-2007, 11:46 AM
Matt McKenzie's Avatar
Send a message via Yahoo to Matt McKenzie
Bmartin, I am on my work computer and can't see your pictures, about how much coolant comes out, so what size of a bag do I need. After work I am going straight to the shop to put my CAI on and want to do this at the same time. If I lose that fluid, will I have to get some more right away????
Matt McKenzie is offline
post #30 of 241 (permalink) Old 12-05-2007, 11:59 AM Thread Starter
Sorry.... a one-gallon HEAVY DUTY freezer bag holds the spillage nicely. It will only get about half full, and the extra bag thickness will thwart most attempts by sharp edges to rip it open.
The overflow reservoir has plenty enough extra to tolerate spilling all of it without causing any problems.
Thanks for your comments - I've added a bit more clarification to the step-by-step.
180 T-Stat install? UPGRADE FAN SPEEDS! jessiethe3rd WK1 General Performance Discussion 0 01-19-2010 05:54 PM
jet 180 t-stat nyjoed WK1 General Performance Discussion 9 01-10-2010 08:59 AM
T-Stat and Cap Mod LonghornSpencer WK1 General Performance Discussion 3 12-08-2008 01:53 PM
HOW TO: T-stat upgrade - what, where, and how to bmartin9122 Tech Tips - DIY - How-To 4 02-05-2008 06:58 PM
180 T-stat Goldengreek5 WK1 General Performance Discussion 63 03-15-2007 09:29 PM
