GS MOTORSPORTS esp/fan mod, do you have yours? - Cherokee SRT8 Forum
post #1 of 13 (permalink) Old 08-16-2006, 11:59 AM Thread Starter
GSMSales's Avatar
Hey guys. Get rid of that 4-wheel factory traction control. Put all the power to the ground and have some fun guys.
Benefits
No Torque management (exact shifts no lag or delay)
No Traction control (100% freedom to Fry the tires or uninterrupted acceleration)
Low temp fan control for a much cooler running temp yielding much better overall performance
Race ESP Mod:
Completely deletes Traction control (esp.) and Torque management on shifts points. No more pauses between shifts and no traction hold back from the ECU at the flip of a switch.
Fan Control:
This mod Brings the fans on early keeping max temps on the motor down 10% or on the 180 degree thermostat at cruising speed( no codes) and is very effective in city driving or at the drag strip.
The kit is a pre made kit that you can install in your driveway in about 1/2 an hour and will result in you having the options mentioned on the fly via 2 small switches in a discrete location with in reach with no holes having to be drilled .
Same day ship, ready to roll out the door.
$199
E-mail me,
ryan@gsmotorsports.com
Ryan
GSMSales is offline
post #2 of 13 (permalink) Old 08-16-2006, 03:15 PM
Re: GS MOTORSPORTS esp/fan mod, do you have yours?
Benefits
Race ESP Mod:
Fan Control:
$199
E-mail me,
Just so noone will be surprised after installing this mod, it also completely eliminates ABS when engaged.
ARH1956 is offline
post #3 of 13 (permalink) Old 08-16-2006, 03:20 PM
split2112's Avatar
can you switch the mods on and off? or is it permanent?
split2112 is offline
post #4 of 13 (permalink) Old 08-16-2006, 03:46 PM
El Jefe's Avatar
it elminates your Anti Lock Brake System? thats no good....
El Jefe is offline
post #5 of 13 (permalink) Old 08-16-2006, 04:55 PM Thread Starter
GSMSales's Avatar
You can turn it on/off as you please. Same goes for the fan.
GSMSales is offline
post #6 of 13 (permalink) Old 08-16-2006, 05:03 PM
When the "Torque Mod" is being used the ABS is defeated. When you turn the Mod off & restart the vehicle all ABS functions return to normal.
ARH1956 is offline
post #7 of 13 (permalink) Old 08-16-2006, 05:58 PM
How is this mod different than just pulling the abs pump fuse? I pulled the fuse and the all the electronic nanny systems appear to be deactivated, but the torque management was still in effect when shifting. The truck didn't accelerate any differently than if the fuse was in. You say that the torque management is deactivated. I just want to make sure this is actually the case before ordering, since pulling the fuse didn't make any difference. Thanks.
blackstallion is offline
post #8 of 13 (permalink) Old 08-16-2006, 09:39 PM
The GSM mod has ZERO effect on the Torque Reduction portion in the ECU software related to transmission shift parameters. The only "torque reduction" it addresses relates to wheelspin.
ARH1956 is offline
post #9 of 13 (permalink) Old 08-17-2006, 01:59 PM
akatheproducer's Avatar
do you have the dyno tests for the cai
akatheproducer is offline
post #10 of 13 (permalink) Old 08-17-2006, 02:23 PM Thread Starter
GSMSales's Avatar
12-15HP. We're still working on the 4-wheel dyno at the shop and we'll be able to post the results at that point.
GSMSales is offline
GSM ESP/Fan Mod TX SRT8 WK1 General Performance Discussion 11 10-14-2009 09:28 AM
Best Intake mod and HP Results? SRT8 MAFIA WK1 Intake/ Exhaust Discussion 22 07-10-2006 10:07 PM
