Building Bella_SRT8 - Single Turbo Build - Page 4 - Cherokee SRT8 Forum
post #31 of 342 (permalink) Old 12-24-2012, 03:19 PM Thread Starter
Originally Posted by Harrison@Stage6 View Post
Forget an 88mm on a stock block. Unless you're wanting over 1000rwhp, a 7675CEA BB is all you need. Trust me.
And that I will. Can't argue with the experience you have. That's for sure. 76mm It is.
10.37 @ 132 - 1.522 60ft
**bone stock motor record**
82mm AD turbo kit
SHR gen3 Viking trans w/ 3800 ProTorque stall
Fore dual 450lph fuel system
AD tuned on E85 with HP Tuners
17" welds - Hoosier slicks(R) - M&H radials(F)
SYCK SRT is offline
post #32 of 342 (permalink) Old 12-25-2012, 08:46 PM
what supporting mods are needed for the PTE76 ? and what are the power gains? i do alot of business with pte and up until now was considering a blower.
bigrpowr is offline
post #33 of 342 (permalink) Old 12-25-2012, 08:55 PM Thread Starter
Well i can speak from experience of the turbos with my car, but supporting mods will be the same regardless of turbo or blower. You will be forcing more air into the engine, so you would need to increase the amount of fuel and tuning as well.
It is also dependent on what your goals are too... if you only planning on pushing 4-5psi of boost into the engine, you might be able to get away with a KB boost a pump or similiar setup with a slight upgrade injector size. But if you want lets say 10psi of boost, it is safer to swap upgrade fuel pumps and go with a bigger set of injectors.
The biggest difference between blowers and turbos are the efficiency of each setup. You will usually see higher gains from a turbo vs a blower on the same psi. This is the NORMAL case. there are always exceptions. But i know individuals running 10psi out of their blowers producing 550whp and i am pushing 8psi and have dynoed more then 600whp.
**just want to make clear i am speaking from past experiences with previous vehicles and my current vehicles- have not yet boosted the SRT8**
SYCK SRT is offline
post #34 of 342 (permalink) Old 12-25-2012, 09:03 PM
Yeah I was referring to drivetrain and valve train. I have multiple twin turbo diesels , one making 775/1500 tq with pte 76mm over a Pte 63mm. It'll make 1100 on the juice. The other is a triple turbo setup with a pte 106 over a pte 82mm over a pte 66mm , triple compounded making 1200+ at low boost (100 psi). Just wondering about trans and valve float. Figured a blower would be easy 525 at the wheels and a lot less headache. For big power I will always choose turbo power.
bigrpowr is offline
post #35 of 342 (permalink) Old 12-25-2012, 09:08 PM Thread Starter
ah gotcha, as far as drivetrain i will let others chime in when it comes to the SRT8. Because i will be curious on that as well.
My guess is the drivetrain and valve train would be very capable of handling up to about 550whp.
anything over that i would think the weak point would be the Transfer Case. i also do know a member on here just recently ordered a trans because his was not holiding up to a procharger D1 kit. But he had over 100k miles i believe.
SYCK SRT is offline
post #36 of 342 (permalink) Old 12-25-2012, 09:33 PM
Muellge's Avatar
Pink lug nuts ftw! A site first!
Five Door League...
Muellge is offline
The Following User Says Thank You to Muellge For This Useful Post:
post #37 of 342 (permalink) Old 12-25-2012, 09:38 PM Thread Starter
haha just told my wife you said this and she said YAY! i made a good choice. lol.
SYCK SRT is offline
post #38 of 342 (permalink) Old 12-25-2012, 09:39 PM
Goodluck on the build. Also, I read your build timeline on your Camaro... damn you have had one heck of a ride with that. Keep up the good work.
August (Gus)
STL SRT8 is offline
The Following User Says Thank You to STL SRT8 For This Useful Post:
post #39 of 342 (permalink) Old 12-25-2012, 09:41 PM Thread Starter
haha thanks man! And yes the 3 year journey has had its sets of ups and downs. Just glad i got it back and can finish what i started.
SYCK SRT is offline
post #40 of 342 (permalink) Old 12-26-2012, 09:49 AM
ekaz's Avatar
I would get a set of blue top solenoids or a valvebody for the trans at least. A trans upgrade is inevitable, either one of those will buy you some time.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
The Following User Says Thank You to ekaz For This Useful Post:
2014 with single turbo 10JGCSRT8 WK2 SRT8 Engine Performance/Superchargers/Turbos/Nitrous 86 12-19-2013 05:33 PM
Is this what a Single or Twin Turbo Jeep sounds like as a DD? Knuckles Off-Topic Discussion 13 08-23-2012 09:37 PM
Single Turbo and Twin Turbo on the dyno today!! Harrison@Stage6 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 102 01-24-2012 01:06 PM
Not a single muffler with a turbo!?!? hoseclamp WK1 Engine Performance/Superchargers/Turbos/Nitrous 13 08-13-2010 07:50 AM
anyone looking for a 93 rx7 single turbo THE 1 WK1 SRT8 General Discussion 5 02-08-2008 01:21 PM
