Put in 195 thermo, now car tuns hotter - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 07-01-2006, 03:28 PM Thread Starter
Untouchable's Avatar
before it would sit at 215, now it hangs between 230-240, almost in the red. All I did was replace the stat with Stant 14429, which is a 195 degree part. It fit perfect, though the internals were nothing like the stocker. there was minimal coolant loss so I didnt add any. Any ideas as to why this is happening?
Untouchable is offline
post #2 of 5 (permalink) Old 07-01-2006, 09:10 PM
Re: Put in 195 thermo, now car tuns hotter
You should have lost 1/3 to 1/2 gallon of coolant & should have added it back until it was completely full again. It sounds as if it is possible your coolant level was low before you started.
ARH1956 is offline
post #3 of 5 (permalink) Old 07-01-2006, 11:50 PM Thread Starter
you know, I thought of that as soon as I posted. I ll check it out first thing. Thanks
post #4 of 5 (permalink) Old 07-02-2006, 10:34 AM
AaronC's Avatar
Also, you should make sure there is no air in any of the coolant hoses. By squeezing the hoses you can "burp" the system.
AaronC is offline
post #5 of 5 (permalink) Old 07-02-2006, 11:44 AM Thread Starter
did it this AM. worked well, she now runs about 8 degrees cooler. I actually did burp the pipe and purged some air out. Went for a 60-mile cruise today with an average 15.7 mpg.
