Thermostat part number - Cherokee SRT8 Forum
post #1 of 3 (permalink) Old 06-30-2006, 08:12 AM Thread Starter
Untouchable's Avatar
I have heard so many different opinions on thermos. What is the part number your guys use for the 180, what is the part for the 195. thanks, I just needed a definitive answer since I have the day off and would like to pop it in
Untouchable is offline
post #2 of 3 (permalink) Old 06-30-2006, 08:46 AM
Re: Thermostat part number
Not sure on the 180. I went with the Stant 195 balanced sleeve. Got it from Pep Boys...Not cheap, was 20 something bucks. Works well, dropped temp 12-15 degrees overall on most driving conditions. Make sure you get the o' ring gasket correctly fitted on lip. Part # is 14429.
teda is offline
post #3 of 3 (permalink) Old 06-30-2006, 01:41 PM
180 degree
NAPA #532080
Stant #45478
192-195 degree
NAPA #532090
Stant #???
These will work. But,they are not the by-pass type t-stat.
A better fit is the napa# 154 It is a 1990 mazda mpv with the 3.0L V-6
this is still not a perfect fit. It's a 64mm not a 63mm. I had to do a little file'n and had to cut 2 coils off the by-pass spring to match the stock hemi spring pressure. It's 180* stat. and has the big flow opening.
My 203* (stock) stat is back in
The first tank of gas I did not notice mpg loss. By the 2nd and 3rd tank mpg's were bad.
I have a 5.7 ram not a 6.1 You might be ok or not, just beware. If I bought a chip to tell the ecm that 180* was full op temp it would(should)work.
hemicon is offline
Low temp thermostat Rboosted717 WK1 General Performance Discussion 3 02-26-2009 01:11 AM
Thermostat Part Numbers PhoenixGTS WK1 SRT8 General Discussion 28 06-27-2006 10:43 PM
Thermostat Hotscott7 WK1 SRT8 General Discussion 3 06-18-2006 09:42 AM
