Heads/Cams Vendors Advise ready to buy now - Cherokee SRT8 Forum
post #1 of 6 (permalink) Old 06-27-2007, 11:10 PM Thread Starter
KINGMONKEY's Avatar
Ok Vendors bring it on and senior posters advise,What system now. Will the new heads/cam show a code for service Advise,I'm ready to buy the best system and what is the true HP/TORQUE gain,I want the %#&% works bring it on PM the price.
KINGMONKEY is offline
post #2 of 6 (permalink) Old 06-27-2007, 11:13 PM
FastSRT8GC's Avatar
I like the Dynamic heads with the Hellfire cam.
FastSRT8GC is offline
post #3 of 6 (permalink) Old 06-27-2007, 11:20 PM
Go with the HHP stage 2.100 or so rwh.plus way quicker shifts
UDLOSE is offline
post #4 of 6 (permalink) Old 06-27-2007, 11:24 PM Thread Starter
KINGMONKEY's Avatar
fastsrt8
Has it added alot of power? Sound different than stock and can it be read while pluged in for service?and how much was it.
Jeff
post #5 of 6 (permalink) Old 06-27-2007, 11:27 PM Thread Starter
KINGMONKEY's Avatar
What is the hp now.I know the reprogram can be read in service.Some dealers are ok with it ,some not
post #6 of 6 (permalink) Old 06-27-2007, 11:49 PM
FastSRT8GC's Avatar
fastsrt8
Jeff
I did too many mods at once. I will say the flow #'s were excellent and held good flow through the entire test. The claims are 70-100HP. The cam is mild and with stock exhaust or even a catback should be indistinguishable at the dealer. The problem is the PCM needs to be upgraded to up the idle speed. No codes. I think you can get them for around 3k or less.
Stock 322HP now 508 with the heads cam headers and vortech. ASM claims 120 at the flywheel, So the 70-100Hp should be there.
What color do you have (or plan to get)? ekool Cherokee SRT8 Polls 39 06-11-2006 02:47 PM
