New Trans cooler = checking fluid level ? - Cherokee SRT8 Forum
post #1 of 21 (permalink) Old 06-27-2007, 02:30 PM Thread Starter
Plan on installing new transmission cooler (Earls) in series with in-radiator stock cooler and since we don't have a dipstick, I was planning on filling the cooler with fluid before hooking up the braided lines (I am using AN fittings). Anyone see an issue with this ? Maybe a little more for amount in lines ?
Is there some way to purchase a dipstick from DCX ?
thanks,
Dave
2007 JGCSRT8
DavesSRT8 is offline
post #2 of 21 (permalink) Old 06-27-2007, 02:47 PM
jlandbl's Avatar
I believe this one will work:
http://www.etoolcart.com/index.asp?P...OD&ProdID=7029
2006 Jeep Grand Cherokee SRT8 - Silver (SOLD)
jlandbl is offline
post #3 of 21 (permalink) Old 06-27-2007, 03:01 PM
Originally Posted by jlandbl
Thank dipstick will work but you should be able to find it on ebay for cheaper. Just do a search for mercedes transmission 722.6, like this one http://cgi.ebay.com/ebaymotors/722-6...QQcmdZViewItem
I installed a transmission cooler on mine in series. Check out my writeup on the LX forum for pics and details
http://www.lxforums.com/board/showth...+cooler&page=6
sunnysrt8 is offline
post #4 of 21 (permalink) Old 06-27-2007, 04:37 PM Thread Starter
Thanks to both for replies ! Sunnysrt8, I see you used the LX forums grocery list from Summit, as I did. So, did you run the braided lines back to where it transitions to rubber and cut there ? do you use the barb fitting to go into the rubber ?
so, confirm please:
What is the flow ? i.e is the front line in the trans the return or feed ?
could you just tell me how you ran the lines ? i.e. front line is feed OUT of trans,then into new cooler, out of new cooler, into top of stock cooler out of bottom of stock cooler, then back to rear trans line ?
I am going to do the long threaded rod mount, going through the bottom and top holes into the bumper.
THANKS for the great pictures !
Dave
post #5 of 21 (permalink) Old 06-27-2007, 04:40 PM Thread Starter
One other item. the 1st dipstick says NAG1, and 2nd is Mercedes 722. will both work for the JEEP trans ?
Dave
post #6 of 21 (permalink) Old 06-27-2007, 06:42 PM
Mango's Avatar
Dave you're nuts! I love it. Can't wait to see your results. When are you guys hitting E-town again?
JT
Mango is offline
post #7 of 21 (permalink) Old 06-27-2007, 07:32 PM
damn tranny cooler huh,,gets me thinking if will help or shift lag by cooling the tranny fluid??
mrfreeze is offline
post #8 of 21 (permalink) Old 06-27-2007, 10:54 PM
I bought one from the stealer $7
LittleDonnie is offline
post #9 of 21 (permalink) Old 06-28-2007, 05:26 AM Thread Starter
Mango:
if we get the Borla on in time, this Friday night.
Learned alot about transmissions and fluid temps from last vehicle I had. Anything over 200 degrees sustained is not good. Monitoring this vehicle with Dashhawk has shown me there are peaks over 200 degrees, with most daily driving being in the 150-170 range, which is OK. 180 thermo helped lower, as did fan mod, but I noticed the sloppiness in transmission when temps were higher.
post #10 of 21 (permalink) Old 06-28-2007, 11:57 AM
Mango's Avatar
Dave, is the track a madhouse on Friday nights? I might come up.
Mango is offline
Trans temp high ? New Dashhawk option DavesSRT8 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 9 05-16-2007 12:56 PM
