Manual Cell Fix under $20!!! - Cherokee SRT8 Forum
post #1 of 6 (permalink) Old 06-16-2007, 10:35 AM Thread Starter
http://www.vtcoa.com/forums/showthread.php?t=2176
I have used this on my 06 STi (sold) , and my 06 viper truck works like a charm and less than $20 and you can get them at pepboys!
I figured i would post it here to share my info. . . sorry im too lazy to re-write it out!
Good Luck!
turbo_neon is offline
post #2 of 6 (permalink) Old 06-16-2007, 11:29 AM
cmn1's Avatar
How about copy and paste
Ok I have been using this (under $20) spacer to eliminate CEL for sometime and I have over 100 miles on my SRT-10 with headers and no cats and no CEL. I also have used this on other vehicles of mine and works fantastic!
Ok I know pep boys has these usally in stock part HELP! # 42002. . .
The pics that im posting are actually 2 diff. peices because they only had one 42002.
Ok in our case since we of course have two 02 sensors we will need two packs of the HELP! 42002's. In the packs it will come with two spacers. Also if you dont have one get a 1/2" drill bit.
Then once you have them back were your going to do the work. Drill only ONE of the spacers (this is the one that the 02 sensor will go in). I used a drill press but a hand drill and vice will work too. Once you have one drilled you can screw it into the non drilled spacer and you have one finised! OPTIONAL: If you would like too and have easy access to a welder you can tack the two togther so that way your only screwing one instead of two when your tightning them down into the bung.
Rinse and repeat for the other side! Reset the ECU and no more CEL!
http://i22.photobucket.com/albums/b3...n/100_0234.jpg (screwed together)
http://i22.photobucket.com/albums/b3...n/100_0233.jpg (Drilled hole)
http://i22.photobucket.com/albums/b3...n/100_0232.jpg (The one on the left is the one {2 included} that will come in the pack)
http://i22.photobucket.com/albums/b3...n/100_0231.jpg (Part #)
http://i22.photobucket.com/albums/b3...n/100_0229.jpg (again together)
Ill get some pics of them installed in a little while.
cmn1 is online now
post #3 of 6 (permalink) Old 06-16-2007, 03:08 PM Thread Starter
fine be mean about it!
post #4 of 6 (permalink) Old 06-16-2007, 08:07 PM
We tried it
Most of us tried this last year......over and over and over again......it did not work.
generalconfusion is offline
post #5 of 6 (permalink) Old 06-18-2007, 05:20 PM Thread Starter
that sucks, sorry i couldnt be of help
post #6 of 6 (permalink) Old 06-18-2007, 07:15 PM
cmn1's Avatar
It's the thought that counts.
cmn1 is online now
Fix For Tcm, 1st To 2nd Hesitation JeffsSRT8 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 8 11-20-2007 06:20 AM
Owners Manual ekgsr WK1 SRT8 General Discussion 2 12-12-2006 11:32 AM
Owners Manual whoop72 WK1 SRT8 General Discussion 7 09-12-2006 05:31 PM
Owners Manual (Merged) jerry WK1 SRT8 General Discussion 23 08-06-2006 12:17 PM
REC Navigation Manual? Krush WK1 Audio/Video/Nav/UConnect/Electronics 4 07-26-2006 05:52 PM
