My Oil Seperator Install! *TY Sarge & Dave!* - Cherokee SRT8 Forum
post #1 of 26 (permalink) Old 06-13-2007, 06:13 PM Thread Starter
Mango's Avatar
I need to give a HUGE thanks to Sarge (generalconfusion) and Dave (DavesSRT8)!!! Without your help I would not have been able to do this.
So...I ordered the Elite Engineering Oil Catch Can and McMaster adapters thanks to Daves links in this post:
More Oil Seperator MFG's
Link to catch can: http://www.eliteengineeringusa.com/Catch_Can.html
This is what I got!!
VERY well made.
YES it comes with that mounting bracket.
Here it is installed. There is a PERFECT mounting point on the front of the engine block. I don't know what the true purpose of the hole is...but it fits this mounting bracket perfectly.
I followed Sarges advice and purchased throttle body cleaner spray (I bought Valvoline brand) to clean my throttle body and the hose from the PCV valve. You should have seen the BROWN fluid shoot out of the hose. I had the car running, shot some into the top of the throttle body, into the PCV valve, and the car was stuttering like mad. After installing the Catch Can, it fired right up.
JT
Mango is offline
post #2 of 26 (permalink) Old 06-13-2007, 06:15 PM Thread Starter
Mango's Avatar
More pics for you. If you are looking for a screw to use for the hole in the block, I will save you time.
Go to lowes or home depot, and get a Metric "M8 X 25mm", a 13mm rachet works perfectly for it.
Mango is offline
post #3 of 26 (permalink) Old 06-13-2007, 06:19 PM
Nice install....... open it up in 400 miles!!
generalconfusion is offline
post #4 of 26 (permalink) Old 06-13-2007, 06:22 PM Thread Starter
Mango's Avatar
Thanks Sarge!
I do have one question, the catch can is touching that wire loom coming from under my engine cover. I know the can gets pretty hot, does anyone think that will cause a problem? I'm pretty sure it'll be ok, I just want to be 100% sure it won't melt the wires or anything.
Mango is offline
post #5 of 26 (permalink) Old 06-13-2007, 06:31 PM
Q: I just received my mcmaster reducers/adapters, but they are plastic, WTF? Also, where did you get those lines?
GotStroke? is offline
post #6 of 26 (permalink) Old 06-13-2007, 06:36 PM Thread Starter
Mango's Avatar
Whoa...plastic?!?! Mine are brass with the yellow plastic stoppers you can see.
Those lines are actually just 1/2 ID transmission/oil lines from Advance Auto Parts. I covered them with high temp hose wrap, heat shrinked the ends....it really dresses it up!
I'm used to doing that on all of my computer wires, so it took no time at all.
Mango is offline
post #7 of 26 (permalink) Old 06-13-2007, 06:37 PM
Originally Posted by Mango
Thanks Sarge!
It should be.....but eventually I'd move it to a cooler spot. I think a custom bracket behind the coolant reservoir, firewall side would be a nice spot...... until you buy one of the carbon CAI...lol
post #8 of 26 (permalink) Old 06-13-2007, 06:38 PM Thread Starter
Mango's Avatar
I KNOW!! lol
I can't wait till you get that done. I keep looking at the Volant and wishing it was your CF Intake. *sigh*
Mango is offline
post #9 of 26 (permalink) Old 06-13-2007, 06:43 PM
Can you do me a favor and either post or PM me the part #s of the brass adapters you have?
Thanks.
post #10 of 26 (permalink) Old 06-13-2007, 06:48 PM Thread Starter
Mango's Avatar
I'll do you one better: I'll post a picture of my reciept! Gimme a min....
Mango is offline
PCV Oil Seperator generalconfusion WK1 General Performance Discussion 99 05-29-2007 09:10 PM
Oil Change Info Need Help! jordo9998 WK1 Troubleshooting / Problems Discussion / Dealer Service 25 03-29-2007 12:16 PM
Oil Pressure/Oil Temp synoil WK1 Troubleshooting / Problems Discussion / Dealer Service 3 02-21-2007 11:59 AM
For All The DIY Oil Changers *LOOK* Inferno SRT8 WK1 SRT8 General Discussion 9 08-06-2006 07:10 AM
Oil consumption? garyb WK1 SRT8 General Discussion 0 06-26-2006 06:03 PM
