Replaced T-stat but not sure about results - Cherokee SRT8 Forum
post #1 of 26 (permalink) Old 05-26-2007, 08:21 PM Thread Starter
FastJeepSRT8's Avatar
Well I got the T-stat replaced and I don't see much of a change in the operating temp except that it stays rock solid at 224 degrees while driving now and about 212 at idle. With the stock stat it would drift up to 234 and even 240 occasionally but most the time 224 was where it used to be. If the weather improves tomorrow I'm heading down to the track to see how the times look. I'm not too concerned because I like that it's not going over 224 now so that has to be an improvement. Just thought I'd share the results. I know there has been a LOT of disscusion on this lately.
FastJeepSRT8 is offline
post #2 of 26 (permalink) Old 05-26-2007, 08:24 PM
MNBob's Avatar
Do you mean that you got it replaced by the dealer with another 203? Or what temp rating is it?
2006 SRT8 GC Jeep - Inferno Red
Smoke Stone Deflector; 2007 Platinum Grille; Sylvania Silverstar Headlights and Fogs
Rear Fogs for Turns, Brakes, and Tail Lights; Interior LED's;
Twin Snorkel Mod; Air Deflector Mod; K&N Drop In; Jet 180 Thermostat; DashHawk
Memphis Audio 15-PRC3 IP Speakers; CDT Audio ES-600 Front Door Speakers
CDT Audio ES-620 Rear Door Component Speakers; Kenwood KSC-SW1 Compact Sub
BWoody Sway Bar Links; Curt 11103 SRT8 Hitch; BT Catch Can; Hankook RH07 Tires
MNBob is offline
post #3 of 26 (permalink) Old 05-27-2007, 05:19 PM Thread Starter
I replaced it with a Valucraft 180* myself. Now today I had completely different results. I drove the Jeep all around town this afternoon and the temp stayed between 203 and 206 under normal driving conditions. What a difference a couple days makes. I'm very pleased now and very anxious to get it to the track to see how it does under heavy acceleration.
post #4 of 26 (permalink) Old 05-27-2007, 05:43 PM
OurZoo's Avatar
While cruising it should sit at 190 most of the time.
OurZoo is offline
post #5 of 26 (permalink) Old 05-27-2007, 05:56 PM
I have starscanned them and they run right at 190-193 which is the first notch between the 215 and 185.
generalconfusion is offline
post #6 of 26 (permalink) Old 05-27-2007, 05:58 PM Thread Starter
I haven't been anywhere near 190 with this stat. Will temps improve over time or do I maybe have a problem?
post #7 of 26 (permalink) Old 05-27-2007, 06:01 PM
Did you use a scanner or going off the guage?
Also did you dilute the anti freeze?
post #8 of 26 (permalink) Old 05-28-2007, 10:44 AM
Don't forget the water wetter.
GotStroke? is offline
post #9 of 26 (permalink) Old 05-28-2007, 09:03 PM
SilveRT8's Avatar
For the summer, I just dropped one gallon of my coolant and replaced it by one gallon of pure distilled water, it still has a reddish color, do you think I'm OK or do I need the Water wetter ?. Freezing point is now at 5* instead of -50*F.
Claude
SilveRT8 is offline
post #10 of 26 (permalink) Old 05-28-2007, 11:58 PM
Claude
I did nearly the same thing (removed one gallon of the original mix and replaced it with a like amount of distilled water). I added Water Wetter anyway, figuring it can't hurt.
B&G Dyno Results after Irwindale generalconfusion WK1 Tuning/CMR/Dyno/DataLogging/Gauges 11 05-20-2007 01:11 PM
GS Motorsports phenolic spacer results GSM WK1 Intake/ Exhaust Discussion 55 02-28-2007 08:14 PM
Any negative results with the new TCM flash larryc7777 WK1 SRT8 General Discussion 3 12-22-2006 02:00 PM
Goodyear replaced 3 tires only, AWD problems?? SRTinSD WK1 Wheels & Tires Discussion 10 12-16-2006 08:03 PM
Drag Race Results 9/24 SRTJeep WK1 SRT8 General Discussion 26 10-03-2006 01:32 AM
