temp gauge with 180 t-stat in warm weather - Cherokee SRT8 Forum
post #1 of 32 (permalink) Old 05-17-2007, 12:22 PM Thread Starter
Weather is in 70's to low 80's here now, my temp gauge goes past 215 now frequently even with a/c off & also highway driving not just in town - what is eveyone else seeing -
lemmie know
07 SRT8 "silver" 180 T-stat,K&N,B&G Stage II
the dj is offline
post #2 of 32 (permalink) Old 05-17-2007, 12:37 PM
FastSRT8GC's Avatar
Here in FL i really have not seen higher than 215 220. And with the fan mod it cools right back down!
FastSRT8GC is offline
post #3 of 32 (permalink) Old 05-19-2007, 03:35 PM Thread Starter
appreciate it!
good luck with your goodies coming!
the dj is offline
post #4 of 32 (permalink) Old 05-19-2007, 03:42 PM
AT'sGCSRT8's Avatar
Mine will travel to 215-220 when sitting in traffic with a/c off. Usually will go down once I get moving. With a/c on the fan kicks on more and keeps it below 215 most of the time.
-Adam
URGENT-California gun owners and 2A supporters your help is needed! There are 2 bills on the govanator's desk that need to be vetoed. Calls, emails,faxes and letters are needed! Click link for more info-
Originally Posted by Abraham Lincoln View Post
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
AT'sGCSRT8 is offline
post #5 of 32 (permalink) Old 05-19-2007, 07:19 PM
OurZoo's Avatar
Same here when I'm sitting in traffic. As soon as I get going again, it falls real fast to 200 and then back to 185.
OurZoo is offline
post #6 of 32 (permalink) Old 05-19-2007, 07:46 PM
awdrocks's Avatar
Do your STR's have an electric from factory? What is your fan mod do?
The reason I ask is because my X from factory has a mechanical fan. I took it out and added an electric fan Black Magic 180 Flex-a-light.
The important update that I like is that it has a probe and module that lets you pick what temp your fan turns on. I upgraded my motor with a 180* t-stat and put my fan so it flashes on at 185*. I will hover around 185-190* in traffic and about 183* while driving and usually the fan turns off. With AC ill get to about 195-205*.
It used to see about 210-215 and I would get nervous, so I would turn on the heater at about those temps to cool the motor down.
If you already have the E-Fan you can buy the probe and controller on its own for about $100 and wire it up to your fan.
Heck that might already be your fan mod... lol
2002 EXPLORER
Blown 304 Big Bore by Modular Performance, Fox Lake Stage II heads, small m90 SC, 60lbs injectors, 2400MAF, ported intake, meth injection, custom CAI, JBA headers, true dual 2.5'' exhaust, X pipe, flowmaster super 40's and many more mods... Part-Time 4wd.
Exhaust Clip
FUTURE MODS
Rebuild entire drivetrain & AED 2300ax SC, NOS, Roll cage
awdrocks is offline
post #7 of 32 (permalink) Old 05-19-2007, 08:20 PM
HoustonSRT-8's Avatar
The fan mod is to wire in a switch that allows you to turn on the electric fan manually whenever you like.
Link to probe & controller?
Steve
PITTZ said I am special
HoustonSRT-8 is offline
post #8 of 32 (permalink) Old 05-19-2007, 08:25 PM
Inferno SRT8's Avatar
Its a 2 speed motor. My fan mod at the track is pulling the low speed fan relay, the PCM thinks the low speed relay has failed and starts the high speed fan 100% on until you clear the OBD.
2012 300 SRT
2010 Challenger SRT8: SOLD
2008 Charger SRT8: SOLD
2006 Jeep SRT8: SOLD
Inferno SRT8 is offline
post #9 of 32 (permalink) Old 05-19-2007, 09:12 PM
awdrocks's Avatar
You can just use this.
http://store.summitracing.com/partde...5&autoview=sku
My controller came with my fan as a kit which has a plug for the AC, so the fan turns on when the AC is turned on. I don't use it though. I don't think this controller has that option. I just have my fan turn on at 185*, AC or no AC.
Here are more controllers:
http://store.summitracing.com/egnsea...rdSearch#rstop
awdrocks is offline
post #10 of 32 (permalink) Old 05-19-2007, 11:42 PM Thread Starter
summit
that's cool but it would be harder to hide that stuff if you needed to take your car in for service - the fan mod you've read about here is a little more stealth & if needed easier to connect/disconnect.
the dj is offline
180 tstat and intake manifold temp timster WK1 General Performance Discussion 68 03-24-2008 01:45 PM
Do the fan and/or 180 temp mods void our warranties? ckehl WK1 General Performance Discussion 5 05-15-2007 09:43 PM
