The 6200 rpm shift "farts" are GONE!!! - Cherokee SRT8 Forum
post #1 of 17 (permalink) Old 05-15-2007, 11:44 AM Thread Starter
BuilderBill's Avatar
I installed the Stage II B&G PCM that raises the rev limiter and guess what:
  • as we suspected the hesitation and "farts" are gone.
I swear that this has GOT to be worth at least a tenth or two where the engine does not "shut off" at our 6,200 rpm. shifts. This is a NEW beast, exactly what the good General has recently stated after his Stage II install. Damn the Hemi pulls strong on the shifts now.
Bad news now is I need to have the dealer replace the re-flashed TCM with my original TCM. As you remember the TCM re-flash lowered the 1-2 shift rpm down to 5,800 rpm.
Anyone changed out their own TCM??? My dealer said it was very involved inside the dash and you need to drop the steering column to access the thing.
Really, if my Hemi would have run this way out of the factory, I don't think I would have been doing this many mods.....oh hell I would too!
Happy Builder Bill
PS. I do also like the fans coming on a little earlier, but, with the stock cam I don't like to idle at 800 rpm, it feeling like I need to ride the brakes.
BuilderBill is offline
post #2 of 17 (permalink) Old 05-15-2007, 11:56 AM
slow91's Avatar
Happy Builder Bill
Great news.....
Does anyone know if it's possible to have a lower setting for the idle RPM...
.....then have it changed if you do the H/C upgrade later??
slow91 is offline
post #3 of 17 (permalink) Old 05-15-2007, 11:57 AM
cobrakid's Avatar
.....Bill that is great.
I have an inside track on handheld new tuner, so I am waiting, but it
would be so lovely to have the trucks shift hard, and correctly.
I don't understand myself, why they mess with the idle??????
glad your truck is running stronger, thanks again for the informative posts.
cobrakid is offline
post #4 of 17 (permalink) Old 05-15-2007, 12:12 PM Thread Starter
The idle is a variable that B&G can change. It typically is raised when a big cam is installed just to keep the thing running and provide vacuum at idle.
I believe you could talk to Dave at B&G ( I went direct with him) and tell him a Stage II with stock idle (650 rpm if I remember).
The Hemi really pulls hard on the WOT shifts!
Bill
post #5 of 17 (permalink) Old 05-15-2007, 12:44 PM
slow91's Avatar
Bill
Thanks Bill.
slow91 is offline
post #6 of 17 (permalink) Old 05-15-2007, 01:18 PM
Inferno SRT8's Avatar
My 1-2 shifts are at 5955, I still ran high 12's last time at Etown, now with the B&G we will see this weekend. Im going to leave mine alone for now, if its not broken im not fixing it!
2012 300 SRT
2010 Challenger SRT8: SOLD
2008 Charger SRT8: SOLD
2006 Jeep SRT8: SOLD
Inferno SRT8 is offline
post #7 of 17 (permalink) Old 05-15-2007, 01:58 PM
FastSRT8GC's Avatar
Great news Bill, Why dont you drive on down and we can work on your TCM!
I can not wait to drive my jeep again!!! My only problem will be too many mods at once!!! I wont be able to tell what did what.
FastSRT8GC is offline
post #8 of 17 (permalink) Old 05-15-2007, 02:12 PM
SRT-8RAT's Avatar
Did the B&G raise the 1-2 shift to 6200 rpm?
Cause mine is 5800 stock.
Would it be worth it with just an intake and exhaust?
Thanks,
Rich
2006 SRT-8
Grand Cherokee
Mopar cold air intake, Mopar cat back exhaust, Diablosport Predator, Nitto NT05 275/315
06 Hummer H3 (wife's)
06 ZO6 (wife's)
09 C63 AMG
SRT-8RAT is offline
post #9 of 17 (permalink) Old 05-15-2007, 02:44 PM Thread Starter
Thanks,
Rich
Rich,
The 5800 shift is cause by the latest rev "AG" to the TCM (NOT THE PCM). The older versions shifted at 6000rpm, completed by 6,200 rpm.
It may not be worth it for you since at 5,800rpm you don't hit the rev. limiter. Unless, you purchase a aftermarket TCM like General from GSM that will have a higher shift point than 5,800 rpm. Right there though you are into it $1500 - $ 2,000.
Bill
post #10 of 17 (permalink) Old 05-15-2007, 03:53 PM
06BLACKJGCSRT8
Guest
Posts: n/a
I have an 06 and it used to do the "fart" thing when it shifted, but after having the TCM re-flashed per the TSB it does not do that anymore. Does this mean that everything is all good with my jeep?
07's shift hesitation now GONE after new TCM install and latest programming BuilderBill WK1 Suspension / Driveline Discussion 13 04-30-2007 01:14 PM
The 1-2 shift problem finally showed up in my '07 FastJeepSRT8 WK1 SRT8 General Discussion 20 12-29-2006 03:38 AM
Free Flash: The Official SRT8 1-2 delayed shift solution has arrived ResumeSpeed WK1 SRT8 General Discussion 29 12-21-2006 04:58 PM
Manual Shift Over-Rev john WK1 Troubleshooting / Problems Discussion / Dealer Service 6 11-21-2006 04:20 PM
RPM limit at 3800?? larryc7777 WK1 SRT8 General Discussion 4 09-08-2006 07:07 AM
