Bill's 426 stroker (sans supercharger) dyno results - Cherokee SRT8 Forum
post #1 of 32 (permalink) Old 05-03-2007, 05:31 PM Thread Starter
BuilderBill's Avatar
The 426 stroker (NO supercharger) was fired up yesterday.
Note that this currently has a STOCK cam and injectors and 9.0 compression ratio.
The engine is in transit to ASM to be torn down to install the new crank tone wheel on the crankshaft for the programmable electronics. I may play a little with camshafts on the ASM dyno since I will be able to adjust idle speed and A/F mixture at all RPM ranges.I believe that I am in the 10 psi supercharger range with the 9.0 compression pistons.
Bill
426 Hemi engine specs.jpg   426 Hemi engine dyno results.jpg   426 Hemi engine dyno graph.jpg
BuilderBill is offline
post #2 of 32 (permalink) Old 05-03-2007, 05:35 PM
ge2
Re: Bill's 426 stroker (sans supercharger) dyno results
About the only words I understood from that was 'fired up yesterday'. Aside from that I don't understand a lick..... but I'm sure it means really cool stuff
ge2 is offline
post #3 of 32 (permalink) Old 05-03-2007, 06:06 PM
Bill
WOW nice crank numbers!!!!!!!.......with those kind of numbers why even supercharge it???
generalconfusion is offline
post #4 of 32 (permalink) Old 05-03-2007, 06:09 PM
MatFab's Avatar
Send a message via AIM to MatFab
theres never enough power...
MatFab is offline
post #5 of 32 (permalink) Old 05-03-2007, 06:11 PM
Blown7's Avatar
Mind if I ask a few questions?
What is the dynamic compression ratio?
I know static is 9-1
What octaine fuel are you going to run?
With a static compression ratio of 9-1 your dynamic should hopefully around 8-1 or less because if all stays the same your final compression ratio with 10 LBS of boost and 9-1 dynamic will be around 15-1. Big octaine numbers.
What are you running for a quench height?
Nice run of torque out running HP!
I'm planning on doing the same just with a Whipple screw.
jeff
John Wayne
Blown7 is offline
post #6 of 32 (permalink) Old 05-03-2007, 06:25 PM Thread Starter
General,
I am so tempted to have the engine shipped to me as soon as the electronics (crank install) are completed. Yes, with the attached sheet, it sure makes a lot of usable power. With the stock 6.1 cam it should idle perfectly. It appears to be pretty decent on torque.
Bill
post #7 of 32 (permalink) Old 05-03-2007, 06:31 PM Thread Starter
jeff
Jeff,
I am sorry as he**. I am going to have to refer the questions to GE2
Fuel = 93 octane, same as now. Hmmm, don't like to here 15-1 compression.
Torque numbers look great as is.
All other questions are WAY over my head...I will have answers though as I proceed along. After all, before I started this project, I couldn't even spell stroker!
Hey guys...what do you think about staying with the stock cam??
Bill
post #8 of 32 (permalink) Old 05-03-2007, 06:43 PM
Blown7's Avatar
Bill
Usually believe it or not stock cams are a great choice if it's not a all out drag machine.
Jeff
Blown7 is offline
post #9 of 32 (permalink) Old 05-03-2007, 07:02 PM
slow91's Avatar
Bill
I for one am a believer in the smooth response and idle that a stock camshaft gives. That being said, it is basically going to be a decision you will need to make jointly with your engine builder. If you have limited knowledge on the subject, he should be able to explain the differences.
Also another another couple of points to factor in is (1) Are you definately going the FI route whether it be SC or turbo and (2) What are your goals?? i.e. Daily-driver boulevard brawler......or weekend track vehicle with consistent 1/4-mile times.
It may just be me, but those are my thoughts on the matter. I'm sure others will have some input as well. GL.
slow91 is offline
post #10 of 32 (permalink) Old 05-03-2007, 07:05 PM
Inferno SRT8's Avatar
I agree with Steve, Bill why supercharge it with those kind of numbers. But I do understand if you do
Insane numbers though!
If you can tune it do the cam what the hell, go for it!
2012 300 SRT
2010 Challenger SRT8: SOLD
2008 Charger SRT8: SOLD
2006 Jeep SRT8: SOLD
Inferno SRT8 is offline
426 stroker updates? FLSRT8 WK1 General Performance Discussion 20 04-26-2007 09:37 PM
Indy's 392 and 426 Stroker Assemblies Power Ported Performance; a better deal Power Ported Performance WK1 General Performance Discussion 0 01-21-2007 12:30 AM
GSM Jeep SRT8 SuperCharger Dyno..! GSM WK1 Engine Performance/Superchargers/Turbos/Nitrous 30 10-04-2006 06:29 PM
Where is the Dyno for the GSM SUpercharger???? recentrisk WK1 Engine Performance/Superchargers/Turbos/Nitrous 55 09-26-2006 10:06 AM
Jeep SRT8 Dynos 355 rwhp John Hennessey WK1 General Performance Discussion 30 05-02-2006 06:26 AM
