Gsm Cam Tuner - Cherokee SRT8 Forum
Closed Thread
post #1 of 16 (permalink) Old 04-24-2007, 06:15 PM Thread Starter
Lightbulb Gsm Cam Tuner
I found out that GSM is looking for a SRT8 vehicle, located in So Cal, with a cam that may be experiencing tuning/vacuum issues. I understand the device will adjust the issues that surface once a cam is installed.
Its a direct plug in type device that get dialed in on the dyno and will solve the cam driveability issues. Please call Scott at GSM directly.
generalconfusion is offline
post #2 of 16 (permalink) Old 04-24-2007, 06:18 PM
tommy25000's Avatar
Re: Gsm Cam Tuner
could this possible resolve the knock sensor issue?
2007 GC SRT 8 (sold)
2004 SRT 4 (sold)
2005 E55 ///AMG
2003 SVT COBRA 660/654wheel
2006 Lincoln mark LT
tommy25000 is offline
post #3 of 16 (permalink) Old 04-24-2007, 09:16 PM
GSM
GSM's Avatar
Re: Gsm Cam Tuner
What knock sensor issue..?
Scott
GS Motorsports
562.777.1075
GSM is offline
post #4 of 16 (permalink) Old 04-24-2007, 09:50 PM
tommy25000's Avatar
Re: Gsm Cam Tuner
Scott
GS Motorsports
562.777.1075
heads, cam and problems.
i want to do heads and a cam but i am nervous. it seem that some hardly gain anything. what will your new program do?
post #5 of 16 (permalink) Old 04-25-2007, 07:40 PM
Grip Grip's Avatar
Re: Gsm Cam Tuner
Scott
GS Motorsports
562.777.1075
A couple weeks ago I had my Jeep dyno'd on two consectutive days on the same tank of gas. The second time is was over much lower, due in part I believe to the knock sesors. We hooked up a scanner and observed a one volt reading on the sensors at idle.
I subsequently removed the sensors, wrapped the threads with teflon tape, and reinstalled them being careful not to overtighten. I don't know if I made a difference, as I havn't had the opportunity to dyno or hook up a scanner.
Any ideas?
Day one: 400 plus HP to the wheels on a AWD mustang dyno
Day two: 370 HP to the wheels on a 2WD Dynojet dyno
Anthony
Grip Grip is offline
post #6 of 16 (permalink) Old 04-26-2007, 03:23 PM
cmn1's Avatar
Re: Gsm Cam Tuner
Any ideas?
Are you sure its not due to using 2 different dynos? I thought they say every dyno is different. Shouldn't you dynoed at the same place to compare?
cmn1 is offline
post #7 of 16 (permalink) Old 04-26-2007, 03:25 PM
tommy25000's Avatar
Re: Gsm Cam Tuner
he should have but dinos shouldnt be off bye over 30hp... seems crazy
I dont know this for sure but i speculate
post #8 of 16 (permalink) Old 04-26-2007, 03:28 PM
cmn1's Avatar
Re: Gsm Cam Tuner
But he used to different types of dynoes. Mustang and Dynojet. Doesn't one always read lower than the other?
cmn1 is offline
post #9 of 16 (permalink) Old 04-26-2007, 03:36 PM
tommy25000's Avatar
Re: Gsm Cam Tuner
a few people have said by this day and age they should all be re-calibrated to be pretty close.
post #10 of 16 (permalink) Old 04-26-2007, 03:38 PM
cmn1's Avatar
Re: Gsm Cam Tuner
He doesn't mention if the #s are corrected or not.
cmn1 is offline
Closed Thread
My experiences with GSM ge2 WK1 SRT8 General Discussion 53 10-29-2007 03:41 PM
cam????? tommy25000 WK1 General Performance Discussion 2 04-02-2007 09:06 PM
All this GSM talk reminded me cumadogg WK1 SRT8 General Discussion 2 01-25-2007 09:38 PM
