confused about ESP, and torque management? - Cherokee SRT8 Forum
post #1 of 11 (permalink) Old 04-07-2007, 07:36 PM Thread Starter
cobrakid's Avatar
hi, me again, trying to learn a lot and apply it all in a few short days.
The GSM esp/fan mod switches???????
I did the fan mod myself.
Now the GSM states the ESP switch reduces or eliminates the TM and helps
the tranny functions?
I am confused, is that the same as turning off our traction control button?
I don't want to do the RWD/2WD mod, I just want the torque management
and tranny shifts better.
....IS THERA A WAY WE CAN DO THAT OURSELVES?.....LIKE TONIGHT?
thanks.....AGAIN, you guys are great!
cobrakid is offline
post #2 of 11 (permalink) Old 04-07-2007, 09:09 PM
Re: confused about ESP, and torque management?
No, it's not the same as turning off our traction control (which btw, we can only do 80% of the way opposed to the LXs), and no there's no way to do it by yourself.
GotStroke? is offline
post #3 of 11 (permalink) Old 04-07-2007, 09:10 PM
Inferno SRT8's Avatar
Actually if you pull the ABS pump fuse it will totally disable ESP and torque managment, but do so at your own risk. And yes you get a CEL and when you reinstall the fuse the CEL is still there until you drive about 10' and it clears itself.
2012 300 SRT
2010 Challenger SRT8: SOLD
2008 Charger SRT8: SOLD
2006 Jeep SRT8: SOLD
Inferno SRT8 is offline
post #4 of 11 (permalink) Old 04-07-2007, 09:11 PM
Doesn't that lead to one wheel peel in back and up front?
post #5 of 11 (permalink) Old 04-07-2007, 09:12 PM
Nope, Ive tried this at the track and it makes the launches violent, ITS GREAT!
post #6 of 11 (permalink) Old 04-07-2007, 09:12 PM
FastSRT8GC's Avatar
You know my site, follow the directions or just remove the fuse first to see if you like it.
The ABS/traction Mod will change a few things. It does seem to shift different, no traction management so burn um up, also has more nuts in first, supposedly the throttle plate is limited to 70 or 80% from the factory. SRT engineers say no everyone with a data logger says yes.
I did notice differences but if they are better or worse i am unsure.
The factory traction button is only a reduction in the TCM not full off!
FastSRT8GC is offline
post #7 of 11 (permalink) Old 04-07-2007, 09:14 PM
Damn. I've got to try that. Thanks.
post #8 of 11 (permalink) Old 04-07-2007, 09:15 PM
FastSRT8GC's Avatar
Yea if you torque brake it like crazy(BILL). But otherwise like Inferno said. VIOLENT
post #9 of 11 (permalink) Old 04-07-2007, 09:37 PM
Are you going to have H/C on by next Sunday? How about the B&G?
post #10 of 11 (permalink) Old 04-07-2007, 09:44 PM
FastSRT8GC's Avatar
Depends on my shop. I hope to be done but it still may be in the shop. The B&G.... well i will have it but i guess it doesnt matter w/o the jeep. It will be tested before i drop it off for the install.
B&G tuning tommy25000 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 44 03-24-2007 09:16 AM
Has anyone used these Performance Chips GodfatherSRT8 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 12 10-19-2006 04:05 PM
