Tips for fan/esp mod?? - Cherokee SRT8 Forum
post #1 of 8 (permalink) Old 03-18-2007, 08:25 AM Thread Starter
Goldengreek5's Avatar
I'm gonna attempt to install the GSM kit for the fan/esp mod today. Any install tips?(Besides making sure I have all the parts!! lol) Thanks in advance!
DR Heads-Comp 268 Cam, Zex kit w/plate, Kooks LT's Hi-Flows
Mopar Cat-Back, BWoody CAI, B&G 2/Predator, Spacers, 180 T-Stat, Iridium Plugs,Tinted Tails, Color Matched Brembos and mouldings, 8000k Headlights-Fogs, Toyos, Fan mod, TC and RWD mod, pistol grip shifter--SOLD
FBO 335i 400+whp-SOLD
2010 Ram CC--Daily Driver, patiently awaiting 2nd Gen Jeep SRT8!
Goldengreek5 is offline
post #2 of 8 (permalink) Old 03-18-2007, 08:32 AM
Re: Tips for fan/esp mod??
take some pics of the install if you can. I may do this mod too someday
timster is offline
post #3 of 8 (permalink) Old 03-18-2007, 08:57 AM
BuilderBill's Avatar
Solder the main feed wire to the high speed fan wire! throw out the little tap connector. Running close to 40 amps, you need this to be reliable.
Oh, and throw out most of the GSM stuff & put in decent parts. Using superior parts I used my fan all day when I ran those 100 + runs. Not a problem.
BuilderBill is offline
post #4 of 8 (permalink) Old 03-18-2007, 09:06 AM Thread Starter
Thanks? I think?
post #5 of 8 (permalink) Old 03-18-2007, 09:07 AM
FastSRT8GC's Avatar
ESP, FAN, EDIFF
Does anyone have the EXACT location and the EXACT colors of these wire so we can start making this upgrade with a simple switch purchase and save us some money and time dealing with GSM.
I know you can just remove the fuse, not the answer i am looking 4.
FastSRT8GC is offline
post #6 of 8 (permalink) Old 03-18-2007, 09:21 AM
I would recommend the following parts from http://www.wiringproducts.com/ to replace the GSM stuff:
  • R-50AT 50 amp relay with mounting tab $ 7.95
  • R-73570 Pre-wired relay socket $ 2.95
  • 76750 Auto reset Mid-range 50 amp Circuit breaker $ 17.95
  • "Add a circuit" tap for the relay from the fuse panel (Pepboys)
  • GSM switch...seems to work ok.
a add a circuit tap in to fuse panel.JPG   a automatic circuit breaker and relay installed.JPG   a close up of automatic breaker and 50 amp relay.JPG   a main power tap use existing lug on fuse panel.JPG   a main power tap, bolt to main power lug on fuse panel.JPG
post #7 of 8 (permalink) Old 03-18-2007, 02:22 PM
Yeah lets keep it simple. What we need is a wire diagram of the fan layout. We should be able to just tap into the ecu or where ever it gets it's signal from to turn the fan on and off. That would be just one wire to tap into. Which would be alot better then taping into the main fan wiring which runs a 40 or 50 amp fuse.
Originally Posted by FastSRT8GC
ESP, FAN, EDIFF
GRNENVY is offline
post #8 of 8 (permalink) Old 03-18-2007, 06:35 PM Thread Starter
So, all in all, I finished in about 2 hours. (I had to wait a half hour to get a jack). The only thing is, I couldnt splice into the fan wire. It says the blue wire in the instructions, but I couldnt find a blue wire. I spliced into one that I thought was blue, but the plastic splice thing they include couldnt tap into the wire. I'm supposed to tap into it before the plug right??
GSM ESP/Fan Mod TX SRT8 WK1 General Performance Discussion 11 10-14-2009 09:28 AM
A mod for those that thought there was nothing left to mod... AlexT Off-Topic Discussion 3 02-13-2007 07:15 PM
B&B Exhaust Tips AaronC WK1 Intake/ Exhaust Discussion 4 09-01-2006 02:03 PM
