Anyone considered this head swap? - Cherokee SRT8 Forum
post #1 of 35 (permalink) Old 03-07-2007, 08:52 AM Thread Starter
I was thinking that although the 6.1L HEMI is an amazing engine that although impressive in a 4200lb LX car that maybe it isn't the best candidate for a 4700-4800lb GC. I am willing to bet that a nicely set of ported 5.7 heads when bolted onto a 6.1L shortblock and mated with the GC platform would create pure magic! Just looking at the 6.1 heads and their flow of close to 300 cfm from the factory makes me think RACE head! for a RACECAR! There's a reason Dodge hasn't relinquished the 6.1 to truck duty yet. I was thinking that 5.7 heads when ported, regularly flow 300-315cfm which is still about 20-25cfm more than a factory 6.1 casting.
Hmm---much larger port 6.1L head=290-300cfm
---much smaller port 5.7L head ported=300-315cfm
The smaller the port with the same or better flow at the same valve lifts = VELOCITY!! Velocity= throttle response and TORQUE, which = awesome driveability and FUN FUN FUN! I would have a hard time believing that no one has tried this yet and would love to hear the results if anyone has. Like I said the 6.1 and 5.7 for that matter ARE amazing engines but I think the 6.1 is more race engine than truck engine and it was pure marketing that got them put under the hood of GC's. I am so convinced that this would be THE swap that I will be trying it on my own GC SRT-8 in the very near future.
RAMM is offline
post #2 of 35 (permalink) Old 03-07-2007, 09:02 AM
gculver's Avatar
Re: Anyone considered this head swap?
The smaller the port with the same or better flow at the same valve lifts = VELOCITY!! Velocity= throttle response and TORQUE, which = awesome driveability and FUN FUN FUN! I would have a hard time believing that no one has tried this yet and would love to hear the results if anyone has. Like I said the 6.1 and 5.7 for that matter ARE amazing engines but I think the 6.1 is more race engine than truck engine and it was pure marketing that got them put under the hood of GC's. I am so convinced that this would be [B]THE [B]swap that I will be trying it on my own GC SRT-8 in the very near future.
Doing that steps the compression up into the 11's and some change(trouble on pump gas)The 5.7L pistons are dished,the 6.1L are flat. There is a few companies working on this very idea with a twist, but I'm not telling right now.
2006 GC SRT 8(12.98@105.3-stock)-SOLD
2008 F-150 LIMITED #3449 of #5000
2006 TRAILBLAZER SS(SOLD)
2004 REDLINE SSR (SOLD)
1999 SVT F-150 (SOLD)
1987 GRAND NATIONAL (SOLD)
1996 IMPALA SS (SOLD)
1969 MACH-1 390,C-6 (SOLD)
1970 BUICK GSX, APOLLO WHITE (SOLD)
and various others
gculver is offline
post #3 of 35 (permalink) Old 03-07-2007, 09:05 AM Thread Starter
I was aware of the comp ratio increase and although it wouldn't be a true back to back test in my case as I was going to convert over to E85 (105 octane) at the same time. Should be a killer!
Owner of Robinson Advanced Motive Machine
RAMM is offline
post #4 of 35 (permalink) Old 03-07-2007, 10:03 AM
BuilderBill's Avatar
Damn, this could get expensive!
BuilderBill is offline
post #5 of 35 (permalink) Old 03-07-2007, 06:33 PM
You have a great idea, but there are some things that need to be cleared up.
5.7 head +/- 80cc combustion chamber
6.1 head +/- 70cc combustion chamber
6.1 heads on a 5.7 raise compression (I have done this) and 5.7 heads on a 6.1 would lower comression IF THEY FIT.
You CAN make them work if you:
Machine the 5.7 heads to allow the clearance needed because the 6.1 piston comes out of the bore and would hit the head
Run some custom thick Cometic head gaskets ($200 or more)
You will also need to port match the intakes on the 5.7 heads to fit the 6.1 manifold (no problem either I have done that too).
Also any 04-up 5.7 HEMI uses EGR in the pass side head. You can either find 2003 truck heads (not too hard to find) or just tap and plug the holes (I've done that too).
Also you MIGHT need 5.7 pushrods, but they are super cheap. I know when switching to 6.1 heads on a 5.7 we went to 6.1 pushrods, so the opposite swap might require the same. The 5.7 pushrods are shorter by a little bit.
Another thing to watch out for, the truck heads do not have the holes for the P/S pump on the pass side. It's an easy fix though.
Beast 2 is offline
post #6 of 35 (permalink) Old 03-07-2007, 07:24 PM
gculver's Avatar
So clearancing the 5.7L combustion chamber to work on a 6.1L would lower static compression even further. I wasn't looking at it that way. Is the 5.7L piston flat top are dished(was going on word of mouth), how much of the 6.1L is outta the hole(10cc less or more?)
gculver is offline
post #7 of 35 (permalink) Old 03-07-2007, 08:11 PM
The 5.7 is actaully domed. The 6.1 is flat top. I am not sure exactly how far out of the hole it comes, but I can ask my partner (he does all our engine design and assembly) or measure one.
Beast 2 is offline
post #8 of 35 (permalink) Old 03-07-2007, 08:49 PM
gculver's Avatar
Was Just curious for furture reference. Does the Hemi shop have any plans on a new head casting on the lines of this discussion???.
gculver is offline
post #9 of 35 (permalink) Old 03-07-2007, 09:10 PM
We could probably CNC a combustion chamber on the 5.7 that would work, however I bet our CNC 6.1 head would still outperform our CNC 5.7 head on a 6.1, we know it does on a 5.7.
Beast 2 is offline
post #10 of 35 (permalink) Old 03-07-2007, 09:55 PM
I don't think you're going to make more power. It seems quite a few people claim that the intake ports on the 6.1 heads are too large, but at right around 210cc (from what I've seen), that's really not the case.
GotStroke? is offline
Bundle Head & Tune Sale: $2275 or add Intake for $2975. GET YOURS TODAY Power Ported Performance WK1 General Performance Discussion 0 01-23-2007 07:56 PM
Head room? jaybruce WK1 SRT8 General Discussion 23 10-25-2006 02:39 PM
Navigation head unit ? sacarmic@indiana.edu WK1 Audio/Video/Nav/UConnect/Electronics 2 07-31-2006 04:32 PM
After market head unit users??? Jeff WK1 Audio/Video/Nav/UConnect/Electronics 0 07-14-2006 08:06 PM
Wheel Swap notsag WK1 SRT8 General Discussion 0 06-14-2006 08:01 PM
