GSM ESP/Fan Mod - Cherokee SRT8 Forum
post #1 of 12 (permalink) Old 04-26-2006, 08:19 PM Thread Starter
Talking GSM ESP/Fan Mod
I installed the ESP/Fan Mod from GS motorsports today and it's great. You can disable the ESP totally but the down side is the ABS is also disabled. When you disable the ESP with the Mod you realize how much the computer intrudes on aggressive driving. I can burn out as long as I want, I can get sideways on dry pavement, and I leave a 5 foot rubber mark just flooring the gas. I had it in first at about 20 mph and floored it and spun out. It may not be as fast with the ESP off but its fun. I will time some runs with it and let you know.
I still need to hook up the fan mod part.
2006 Jeep Srt8 Inferno
2005 BMW X5 4.4
TX SRT8 is offline
post #2 of 12 (permalink) Old 04-26-2006, 09:07 PM
goldsgym's Avatar
Re: GSM ESP/Fan Mod
How hard was it to install?
goldsgym is offline
post #3 of 12 (permalink) Old 04-26-2006, 09:32 PM
Jerod's Avatar
Re: GSM ESP/Fan Mod
When are you posting the video? Hint, hint
Jerod is offline
post #4 of 12 (permalink) Old 04-26-2006, 09:42 PM
Re: GSM ESP/Fan Mod
For the ESP part of the mod alone it takes about 45 minutes to read the instructions, run the wire, find the abs wire to cut, mount the switch & splice the connection. You will have to run one small wire harness from under the dash to under the hood through a boot in the firewall. Overall it is an extremely easy install. Just be certain you splice into the LIGHT BLUE wire with a PINK stripe, not the Dark Blue wire with the pink stripe at the ABS harness under the hood.
ARH1956 is offline
post #5 of 12 (permalink) Old 04-27-2006, 12:35 AM
Send a message via AIM to 2MCHPSI Send a message via Yahoo to 2MCHPSI
Re: GSM ESP/Fan Mod
I still must be missing something. I pull the ABS Pump fuse under the hood and STILL do not have the ability to "burn out". What do you guys run your tire pressure at? 50 PSI? The most I get is a small "chirp."
Luan Zeqollari
2006 SRT8 Grand Cherokee
- 13.10 @ 106.56 <-- 4" BWoody CAI; 180 T-Stat
Milan Dragway - 600ft Elevation.
2MCHPSI is offline
post #6 of 12 (permalink) Old 04-27-2006, 09:31 AM Thread Starter
Re: GSM ESP/Fan Mod
No, I run 36 psi. But im using the GSM fan mod, not pulling a fuse. When you pull the fuse what warning lights do you get? There should be three if its disabling everything the mod is. The esp abs, abs, and traction control.
TX SRT8 is offline
post #7 of 12 (permalink) Old 04-27-2006, 10:34 AM
Send a message via AIM to radduc
Re: GSM ESP/Fan Mod
does thos mod trigger any errors that the dealer will know about??
radduc is offline
post #8 of 12 (permalink) Old 04-27-2006, 09:00 PM
Re: GSM ESP/Fan Mod
One thing I noticed today, the truck will not break the tires loose when approached form a break-torque method (foot on brake, fott on gas, let go of brake) but when I just simply use 1 foot and move my right foot from the brake to the gas pedal it chirps and goes. Now I am going over everything in my head formthe track yesterday, and I dont think I launched the car once from a single foot method (the 3 pedal pro in me).
2MCHPSI is offline
post #9 of 12 (permalink) Old 04-28-2006, 03:44 AM
Post Re: GSM ESP/Fan Mod
This mod does set a trouble code in the PCM and probably pulling the fuse. A better way is to trick the PCM w/o any codes. I'm working on doing this now? You'll lose traction at the drag strip but pickup on the mph in the 1/4! You'll need a scan tool to remove any trouble codes or big brother may void the warranty? Be careful? MHO Gene
SRTJeep is offline
post #10 of 12 (permalink) Old 09-17-2009, 12:00 PM
I have the same ESP/Fan mod, I am now showing a ESP and traction light with the switch off and when the switch is on it adds the ABS light to the the other 2. Does this mean I have a blown fuse?????? Or is it something else??
2007 Jeep SRT8 Red Rock Crystal Pearl
Vortech V3 supercharger 9 PSI
Kooks long tubes coated
High flow cats
Corsa exhaust
CMR tune
Nitto Invo's 275/315
sam@amelectric is offline
Best Intake mod and HP Results? SRT8 MAFIA WK1 Intake/ Exhaust Discussion 22 07-10-2006 11:07 PM
