Transfer Case & Differential Fluid Capacities - Page 3 - Cherokee SRT8 Forum
post #21 of 41 (permalink) Old 03-21-2008, 05:40 AM
jayeepee's Avatar
I did my front and rear differentials at home with 4 quarts of synthetic gear lube from Wal Mart for $10.00 per quart. I don't know the brand but it seems to be working. You will need 2 different tools to remove the drain plugs, the rear takes a square drive ratchet but the front has a drain and fill plug that take a big metric allen wrench, for which I had to buy a whole set at Sears for $40.00 just to get the one tool I needed. The fill hole is in a tight place on the front of the front differential and I had to remove the allen part of the tool from the 1/2" socket and turn it with a wrench to use it. It was a pain but I got it done for $80.00, versus almost $300.00 at the dealer!
Black 2006 JGC SRT8, K&N filter, GSM phenolic intake spacer, Sylvania Silverstars, cabin air filter, aluminum stubby antenna, rear fog lights rigged as extra brake lights and turn signals
jayeepee is offline
post #22 of 41 (permalink) Old 03-24-2008, 09:30 PM
Jeep Trick's Avatar
Originally Posted by Jeep Trick View Post
When changing the fluid is there any sealant needed when reinstalling the drain plugs???
Bump!
or do they self seal like the oil drain plug???
Jeep Trick is offline
post #23 of 41 (permalink) Old 03-25-2008, 10:01 AM
SJG3RD's Avatar
Are you guys changing the fluid in the driveway with ramps or jack stands? I can't seem to fit under the jeep without some sort of lifting device.
B Woody intake, B&B Exhaust, 6K HID lows&Fogs, 180 Motorad, Elite Engineering Catch Can, Black side Mouldings, Blacked out tails, All Interior LEDS, MHP antenna, MHP/CMR Tune, R1 rotors/Hawk pads, Stillen headlight covers, B Woody Sway Bar endlinks, Bridgestone dueler runflats 275/315
SJG3RD is offline
post #24 of 41 (permalink) Old 03-25-2008, 10:04 AM
Jeep Trick's Avatar
I personally use two floor jacks and jack stands.
I just put a jack n either side and take it up as evenly as possible than throw some jack stands in for safety.
post #25 of 41 (permalink) Old 08-04-2008, 04:41 PM
I think Inferno's local dealer sold him 2 quarts for $70.
You can get it online cheaper though. I bought 2 quarts from moparstore.com for $56.45 shipped.
If you dont mind a few days wait it is much cheaper to buy it online and do it youself.
i just checked moparstore.com and the prices on the NVG146 xfer case fluid ( item # 68001758AA ) went up. they are now charging $41.60 a quart.
07 Jeep SRT8 // KooKs LT Headers, 1 7/8" / Hi-Flo Cats / Borla S / Volant
promo718 is offline
post #26 of 41 (permalink) Old 09-06-2010, 11:06 AM
so for the diffs and transfer case, do you have to use the Moppar stuff or can we get away with something from Autozone?
morris is offline
post #27 of 41 (permalink) Old 09-06-2010, 03:25 PM
PoPoSRT8's Avatar
I just changed mine. You have to use the Mopar transfer case fluid. For the front/rear diffs, I used that Royal Purple stuff. I can honestly say changing all those fluids really quieted my Jeep down. I used to have this loud muffled noise when I punched it, coming from underneath the Jeep. Now I dont hear a thing, only the engine and exhaust. Hope this helps.
PoPoSRT8 is offline
post #28 of 41 (permalink) Old 09-06-2010, 07:21 PM
Well I am having a heck of a time finding the transfer case oil online does anyone have any suggestions as to where I might find it?
morris is offline
post #29 of 41 (permalink) Old 09-20-2010, 02:14 PM
The STEALership should be able to hook you up.
SRT830 is offline
post #30 of 41 (permalink) Old 01-05-2011, 07:00 PM
So the Royal Purple did not work??? The mopar fluid quieted it down?
ID_NV_it_2 is offline
Tags
diff fluid capacity, fluid capacities, transfer case
SRT Transfer case:Illustration & Discussion BuilderBill WK1 Suspension / Driveline Discussion 67 06-23-2016 02:50 PM
Transfer Case Fluid Capacity 07blksrt8 WK1 Troubleshooting / Problems Discussion / Dealer Service 19 09-10-2012 10:07 AM
Transfer Case Adjustment ibbigc WK1 Troubleshooting / Problems Discussion / Dealer Service 3 02-22-2008 11:30 AM
247 transfer case goolsby Other Chrysler/Dodge/Jeep/Fiat Vehicle Discussion 0 01-31-2008 09:16 PM
Transfer case model # Anyone know?? venomous WK1 Suspension / Driveline Discussion 6 04-18-2007 03:14 PM
